Author Topic: can I translate a paperspace point through a mview using objectdbx?  (Read 1999 times)
mkweaver
Given nothing more than an AcDbViewport and it's document object, how would I find the corners of the view in model space?
If the drawing were active and the viewport were active it would be easy using the trans function. I've looked here and on the autodesk newsgroups and can't find a clue.
Any help would be appreciated.
Mike
mkweaver
Re: can I translate a paperspace point through a mview using objectdbx?
« Reply #2 on: October 21, 2008, 11:57:16 AM »
This was of no help?
http://www.theswamp.org/index.php?topic=9461.msg129670#msg129670
That looks like it would have the information needed to solve my problem.  I ended up using vlax-vla-object->ename and entget to get the view center and dimensions.
Thanks for the help.
Mike
