Author Topic: Another Linetype  (Read 4638 times)
POCKETS
Another Linetype
« on: October 13, 2008, 05:02:34 PM »
Cab, Ronjomp,
If I could, again, ask a favor.  I would like a linetype with a continuous line with solid circles at given intervals.  ----o----o----
Thanking you in advance, I am
Pockets
Re: Another Linetype
« Reply #1 on: October 13, 2008, 05:15:07 PM »
Like this?
*O, ---- O ----
A,.5,-.2,["O",Standard,S=.125,R=0.0,X=-0.1,Y=-.05],-.15
Gliderider
« Reply #2 on: October 13, 2008, 05:34:03 PM »
I hope I'm not stepping on any toes...
This will give you solid circles; you need to have a textstyle named Arial using the arial.ttf font file, height=0
*DOTS,Dots .___.___.___.___.___
A,.5,-.025,["\U+25CF",ARIAL,S=.1,R=0,X=0,Y=-.045],-.1
« Last Edit: October 13, 2008, 05:44:11 PM by lpseifert »
POCKETS
« Reply #3 on: October 13, 2008, 05:43:27 PM »
Ronjomp,
Thanks. Almost.  I would like solid circles and no space between the circles.
Lpseifert,
I am not allowed to use the Ariel font but thanks anyway.
« Reply #4 on: October 13, 2008, 06:23:15 PM »
Not completely solid...but closer:
*Wheee,--o--
A,.189743,-.000569,["o",Standard,y=-.038774,s=.1125],-.009375,["o",Standard,y=-.02889,s=.084375],-.007031,["o",Standard,y=-.022123,s=.063281],-.005273,["o",Standard,y=-.016202,s=.047461],-.003955,["o",Standard,y=-.012259,s=.035596],
-.002966,["o",Standard,y=-.009203,s=.026697],-.046888,.189743
btw...that was created with the express tool MKLTYPE.
« Last Edit: October 13, 2008, 06:26:17 PM by ronjonp »
POCKETS
« Reply #5 on: October 14, 2008, 08:14:26 AM »
Ronjonp,
Thank you
« Reply #6 on: October 14, 2008, 09:38:17 AM »
I would have opted for a SHAPE. Way to think outside the box there Ron.
« Reply #7 on: October 14, 2008, 10:19:23 AM »
Thanks CAB  8-)
« Reply #8 on: October 14, 2008, 10:27:04 AM »
Here's another version Pockets:
*Snowflake,---*---
A,.5,-.000191,["x",Standard,y=-.015397,s=.125,r=315],-.011157,["x",Standard,y=.041001,s=.125,r=270],-.020833,["x",Standard,y=-.063166,s=.125],-.026935,["x",Standard,y=.072991,s=.125,r=225],-.029463,["x",Standard,y=-.074323,s=.125,r=45],
-.026935,["x",Standard,y=.061834,s=.125,r=180],-.020833,["x",Standard,y=-.042333,s=.125,r=90],-.01053,.000627,["x",Standard,y=.014065,s=.125,r=135],.499373
POCKETS
« Reply #9 on: October 14, 2008, 11:09:02 AM »
Ronjonp,
I like snowflakes Thanks
« Reply #10 on: October 14, 2008, 11:20:43 AM »
The nice thing about using Characters and not Shapes is that you don't have to send the shape files when sending the DWG file.
Problem with characters is that if someone has a differant font for STANDARD text style you can get some unexpected linetypes.
So each has its advantages & disadvantages.
Matt__W
  • I like my water diluted.
« Reply #11 on: October 14, 2008, 11:21:30 AM »
Ronjonp,
Who doesn't??!?   :-)
Autodesk Expert Elite
« Reply #12 on: October 14, 2008, 11:27:53 AM »
On another topic...do any of you have something that will strip out not found shape files for linetypes or know how to suppress the message on drawing startup? I have so many projects where shape files are missing...that's why I've gone away from using them in linetypes.
Ron
« Reply #13 on: October 14, 2008, 11:32:23 AM »
Maybe this:
;;;-------------------- START OF FILE ------------------------
;;;  source
;;;  http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2896848&linkID=2475323
;;; DESCRIPTION
;;; This routine deletes all shapes in the drawing
;;; that do not have a file definition.
;;; RUN
;;; -load this file and run the new command DELSHAPE
Link no longer valid, try this one.
DelShape.lsp
« Last Edit: October 14, 2008, 11:39:23 AM by CAB »
« Reply #14 on: October 14, 2008, 11:57:56 AM »
Thanks CAB...I'll give it a whirl.
