Author Topic: Is there a way to insert & update multiple blocks at a time?  (Read 8524 times)
Re: Is there a way to insert & update multiple blocks at a time?
« Reply #15 on: October 24, 2007, 12:16:07 PM »
What's wrong with using the plan old INSERt command?
From the Help file on INSERT command
Updating a Block Path: If you enter a block name without a path name, AutoCAD
first searches the current drawing data for an existing block definition by that
name. If no such block definition exists in the current drawing, AutoCAD
searches the library path for a file of the same name. If AutoCAD finds such a
file, it uses the file name for the block name upon insertion of the block
definition. AutoCAD uses the same block definition for subsequent insertions of
that block. You can replace an existing block definition with an external file
by entering the following at the Enter Block Name prompt:
block name=file name
You can simply use the command line version of the INSERT command like this:
(command "-INSERT" "YourBlockName=YourBlockName")
(command)
Your block name must be in the path else use this:
(command "-INSERT" (strcat "YourBlockName="  path "YourBlockName") )
(command)
The (command) aborts the INSERT but not before the block definition has been updates.
You can process a list of block names like this:
(foreach name '("b1" "b2" "b3")
  (command "-INSERT" (strcat name "=" name)
  (command)
You can add this to a script. The problem comes when the block is not found.
An error occurs and your script is stopped.
« Reply #16 on: October 24, 2007, 12:33:19 PM »
...The problem comes when the block is not found.
Here is one to check if the block definition exists before trying to insert:
  (if (tblsearch "block" name)
    (command "-INSERT"
FengK
« Reply #17 on: October 24, 2007, 01:10:37 PM »
Thanks Alan & ronjonp, i didn't know about this one:
(command)
CADaver
« Reply #18 on: October 24, 2007, 05:30:51 PM »
(command)
Just a suggestion, but the names can be different as well
(command "-INSERT" "YourBlockName=c:/MyDirOfSomeName/peanut/butter/SomeOtherDwgName")
(command)
FengK
« Reply #19 on: October 24, 2007, 09:55:41 PM »
Thanks Randy.
CADaver
« Reply #20 on: October 24, 2007, 11:25:14 PM »
Thanks Randy.
You're quite welcome.
Luke
« Reply #21 on: April 11, 2008, 03:30:32 PM »
OK so my code is as follows:
(command "-INSERT" "YourBlockName1=c:/MyDirOfSomeName/peanut/butter/YourBlockName1")
(command)
I'm almost embarrassed asking (but will anyhow..) how do i add a second line to get it to replace old block2 with newblock2?
