Author Topic: toggle for dashboard panels in acad 08?  (Read 4055 times)
andrew_nao
« on: August 30, 2007, 08:36:29 AM »
is there a variable to toggle between dashboard panels for acad 08?
for example, if i have 5 panels created, is there a variable i can toggle on and off to control what panels i want displayed
instead of having to right click the dashboard selecting what i want shown
Guest
Re: toggle for dashboard panels in acad 08?
« Reply #1 on: August 30, 2007, 08:56:45 AM »
Workspaces
KewlToyZ
« Reply #2 on: August 30, 2007, 09:56:01 AM »
Here is a list I am building of interface specific controls.
I keep surfing web pages for alternative lists and I'm trying to more or less set them up into an excel spreadsheet to use as a data base. I think there are close to 530 setvars in MEP now.
DASHBOARDSTATE   - Indicates whether the Dashboard window is open or closed.
DTEXTED   -   Specifies the user interface displayed for editing single-line text.
DWFFRAME   -   Determines whether the DWF underlay frame is visible.
DWFOSNAP   -   Determines whether object snapping is active for geometry in DWF underlays that are attached to the drawing.
DXEVAL   -   Controls when data extraction tables are compared against the data source, and if the data is not current, displays an update notification
DYNDIGRIP   -   Controls which dynamic dimensions are displayed during grip stretch editing. The DYNDIVIS system variable must be set to 2, which displays all dynamic dimensions.
DYNDIVIS   -   Controls how many dynamic dimensions are displayed during grip stretch editing. DYNDIGRIP controls which dynamic dimensions are displayed during grip stretch editing.
DYNMODE   -   Turns Dynamic Input features on and off. When all features are on, the context governs what is displayed.
DYNPICOORDS   -   Controls whether pointer input uses relative or absolute format for coordinates.
DYNPIFORMAT   -   Controls whether pointer input uses polar or Cartesian format for coordinates. This setting applies only to a second or next point.
DYNPIVIS    -   Controls when pointer input is displayed.
DYNPROMPT   -   Controls display of prompts in Dynamic Input tooltips.
DYNTOOLTIPS   -   Controls which tooltips are affected by tooltip appearance settings.
ERSTATE   -   Determines whether the External References palette is open or closed.
FIELDDISPLAY   -   Controls whether fields are displayed with a gray background. The background is not plotted.
FIELDEVAL   -   Controls how fields are updated. The setting is stored as a bitcode using the sum of the following values:
FILEDIA   -   Suppresses display of file navigation dialog boxes.
GRIPBLOCK   -   Controls the display of grips on nested objects in blocks when selected.
HIDETEXT   -   Specifies whether text objects created by the TEXT, DTEXT, or MTEXT command are processed during a HIDE command.
HIGHLIGHT   -   Controls object highlighting; does not affect objects selected with grips.
LAYEREVAL   -   Controls when the Unreconciled New Layer filter list in the Layer Properties Manager is evaluated for new layers.
LAYERFILTERALERT   -   Deletes excessive layer filters to improve performance. When a drawing has 100 or more layer filters, and the number of layer filters exceeds the number of layers, LAYERFILTERALERT provides a method for deleting layer filters to improve performance.
LAYERNOTIFY   -   Specifies when an alert displays for new layers that have not yet been reconciled.
LAYLOCKFADECTL   -   Controls the dimming for objects on locked layers
LOCKUI   -   Locks the position and size of toolbars and dockable windows such as DesignCenter and the Properties palette. Locked toolbars and windows can still be opened and closed and items can be added and deleted. To unlock them temporarily, hold down CTRL.
LOGINNAME   -   Displays the user's name as configured or as input when the program starts. The maximum length for a login name is 30 characters.
LTSCALE   -   Sets the global linetype scale factor. The linetype scale factor cannot equal zero. This system variable has the same name as a command. Use the SETVAR command to access this system variable.
LUNITS   -   Sets linear units.
MBUTTONPAN   -   Controls the behavior of the third button or wheel on the pointing device.
MEASUREINIT   -   Controls whether a drawing you start from scratch uses imperial or metric default settings. Specifically, MEASUREINIT controls which hatch pattern and linetype files are used. The Drawing1.dwg that opens when you start the program is a drawing that is started from scratch.
MENUCTL   -   Controls the page switching of the screen menu.
MENUECHO   -   Sets menu echo and prompt control bits. The value is the sum of the following:
MODEMACRO   -   Displays a text string on the status line, such as the name of the current drawing, time/date stamp, or special modes.
MSMSTATE   -   Stores a value that indicates whether the Markup Set Manager is open or closed.
MSLTSCALE   -   Scales linetypes displayed on the model tab by the annotation scale
MTEXTED   -   Sets the application for editing multiline text objects. You can specify a different text editor for the MTEXT command. If you set MTEXTED to internal or to null (.), the In-Place Text Editor is displayed. If you set MTEXTED to “OldEditor”, the Multiline Text Editor is displayed. If you specify a path and the name of the executable file for another text editor or word processor, that path and file name instead are displayed instead.
MTJIGSTRING   -   Sets the content of the sample text displayed at the cursor location when the MTEXT command is started. The text string is displayed in the current text size and font. You can enter any string of up to ten letters or numbers or enter . (period) to display no sample text.
OBSCUREDCOLOR   -   Specifies the color of obscured lines. Value 0 designates byBlock, value 256 designates byLayer, and value 257 designates ByEntity. Values 1-255 designate an AutoCAD Color Index (ACI).
OBSCUREDLTYPE   -   Specifies the linetype of obscured lines. Obscured linetypes are independent of zoom level, unlike regular linetypes. The linetype values are defined as follows:
OLEFRAME   -   Controls whether a frame is displayed and plotted on all OLE objects in the drawing. The frame on an OLE object must be displayed in order for grips to be visible.
OLEQUALITY   -   Sets the default plot quality for OLE objects. When OLEQUALITY is set to 3, the quality level is assigned automatically based on the type of object. For example, spreadsheets and tables are set to 0, color text and pie charts are set to 1, and photographs are set to 2.
OLESTARTUP   -   Controls whether the source application of an embedded OLE object loads when plotting. Loading the OLE source application may improve the plot quality.
OPMSTATE   -   Stores a value that indicates whether the Properties palette is open, closed or hidden.
ORTHOMODE   -   Constrains cursor movement to the perpendicular. When ORTHOMODE is turned on, the cursor can move only horizontally or vertically relative to the UCS and the current grid rotation angle.
OSMODE   -   Sets running object snaps. The setting is stored as a bitcode using the sum of the following values:
OSNAPCOORD   -   Controls whether coordinates entered on the command promptoverride running object snaps.
OSNAPNODELEGACY   -   Controls whether the Node object snap can be used to snap to multiline text objects.
OSNAPZ   -   Controls whether object snaps are automatically projected onto a plane parallel to the XY plane of the current UCS at the current elevation.
OSOPTIONS   -   Automatically suppresses object snaps on hatch objects and geometry with negative Z values when using a dynamic UCS.
PALETTEOPAQUE   -   Controls whether windows can be made transparent. When transparency is unavailable or turned off, all palettes are opaque. Transparency is unavailable when palettes or windows are docked, when transparency is not supported by the current operating system, and when hardware accelerators are in use.
PAPERUPDATE   -   Controls the display of a warning dialog when attempting to print a layout with a paper size different from the paper size specified by the default for the plotter configuration file.
PEDITACCEPT   -   Suppresses display of the Object Selected Is Not a Polyline prompt in PEDIT. The prompt is followed by “Do you want it to turn into one?” Entering y converts the selected object to a polyline. When the prompt is suppressed, the selected object is automatically converted to a polyline.
PICKADD   -   Controls whether subsequent selections replace the current selection set or add to it.
PICKAUTO   -   Controls automatic windowing at the Select Objects prompt.
PICKBOX   -   Sets the object selection target height, in pixels.
PICKDRAG   -   Controls the method of drawing a selection window.
PICKFIRST   -   Controls whether you select objects before (noun-verb selection) or after you issue a command.
PICKSTYLE   -   Controls the use of group selection and associative hatch selection.
PLQUIET     -   Controls the display of optional plot-related dialog boxes and nonfatal errors for scripts.
POLARANG   -   Sets the polar angle increment. Values are 90, 45, 30, 22.5, 18, 15,10, and 5.
POLARDIST   -   Sets the snap increment when the SNAPTYPE system variable is set to 1 (PolarSnap).
POLARMODE   -   Controls settings for polar and object snap tracking. The setting is stored as a bitcode using the sum of the following values:
POPUPS   -   Displays the status of the currently configured display driver.
PREVIEWEFFECT   -   Specifies the visual effect used for previewing selection of objects.
PREVIEWFILTER   -   Excludes specified object types from selection previewing. The setting is stored as a bitcode using the sum of the following values:
PROJMODE   -   Sets the current Projection mode for trimming or extending.
PROXYGRAPHICS   -   Specifies whether images of proxy objects are saved in the drawing.
PROXYNOTICE   -   Displays a notice when a proxy is created. A proxy is created when you open a drawing containing custom objects created by an application that is not present. A proxy is also created when you issue a command that unloads a custom object's parent application.
PROXYSHOW   -   Controls the display of proxy objects in a drawing.
PROXYWEBSEARCH   -   Specifies how the program checks for object enablers.
PSLTSCALE   -   Controls linetype scaling of objects displayed in paperspace viewports.
PSTYLEMODE   -   Indicates whether the current drawing is in a Color-Dependent or Named Plot Style mode.
continued...
« Last Edit: August 30, 2007, 10:08:44 AM by KewlToyZ »
KewlToyZ
« Reply #3 on: August 30, 2007, 10:07:06 AM »
PSTYLEPOLICY   -   Controls the plot style mode, Color-Dependent or Named, that is used when opening a drawing that was created in a release prior to AutoCAD 2000 or when creating a new drawing from scratch without using a drawing template.
PSVPSCALE   -   Sets the view scale factor for all newly created viewports. The view scale factor is defined by comparing the ratio of units in paper space to the units in newly created model space viewports. The view scale factor you set is used with the VPORTS command. A value of 0 means the scale factor is Scaled to Fit. A scale must be a positive real value.
PUBLISHALLSHEETS   -   Controls how the Publish dialog box list is populated when the PUBLISH command is issued.
PUBLISHCOLLATE   -   Controls whether sheets are published as a single job
PUCSBASE   -   Stores the name of the UCS that defines the origin and orientation of orthographic UCS settings in paper space only.
QCSTATE   -   Determines whether the QuickCalc calculator is open or closed.
QTEXTMODE   -   Controls how text is displayed.
RASTERPREVIEW   -   Controls whether BMP preview images are saved with the drawing.
RECOVERYMODE   -   Controls whether drawing recovery information is recorded after a system failure.
REFEDITNAME   -   Displays the name of the reference being edited.
REGENMODE   -   Controls automatic regeneration of the drawing.
RE-INIT   -   Reinitializes the digitizer, digitizer port, and acad.pgp file. The setting is stored as a bitcode using the sum of the following values:
REMEMBERFOLDERS   -   Controls the default path displayed in standard file selection dialog boxes.
REPORTERROR   -   Controls whether an error report can be sent to Autodesk if the program closes unexpectedly.
ROAMABLEROOTPREFIX   -   Stores the full path to the root folder where roamable customizable files were installed. If you are working on a network that supports roaming, when you customize files that are in your roaming profile they are available to you regardless of which machine you are currently using.
RTDISPLAY   -   Controls the display of raster images and OLE objects during Realtime ZOOM or PAN.
SAVEFIDELITY   -   Controls whether the drawing is saved with visual fidelity
SAVEFILE   -   Stores the current automatic save file name.
SAVEFILEPATH   -   Specifies the path to the directory for all automatic save files for the current session. You can also change the path on the Files tab in the Options dialog box.
SAVENAME   -   Displays the file name and directory path of the most recently saved drawing.
SAVETIME   -   Sets the automatic save interval, in minutes.
SCREENBOXES   -   Stores the number of boxes in the screen menu area of the drawing area. If the screen menu is turned off, SCREENBOXES is zero. On platforms that permit the drawing area to be resized or the screen menu to be reconfigured during an editing session, the value of this variable might change during the editing session.
SCREENMODE   -   Indicates the state of the display. The setting is stored as a bitcode using the sum of the following values:
SCREENSIZE   -   Stores current viewport size in pixels (X and Y).
SELECTIONANNODISPLAY   -   Controls whether alternate scale representations are temporarily displayed in a dimmed state when an annotative object is selected
SELECTIONAREA   -   Controls the display of effects for selection areas. Selection areas are created by the Window, Crossing, WPolygon, and CPolygon options of SELECT.
SELECTIONAREAOPACITY   -   Controls the transparency of the selection area during window and crossing selection. The valid range is 0 to 100. The lower the setting, the more transparent the area. A value of 100 makes the area opaque. The SELECTIONAREA system variable must be on.
SELECTIONPREVIEW   -   Controls the display of selection previewing. Objects are highlighted when the pickbox cursor rolls over them. This selection previewing indicates that the object would be selected if you clicked. The setting is stored as a bitcode using the sum of the following values:
SETBYLAYERMODE   -   Controls which properties are selected for SETBYLAYER
SHORTCUTMENU   -   Controls whether Default, Edit, and Command mode shortcut menus are available in the drawing area. The setting is stored as a bitcode using the sum of the following values:
SHOWLAYERUSAGE   -   Displays icons in the Layer Properties Manager to indicate whether layers are in use. Setting this system variable to Off improves performance in the Layer Properties Manager.
SHPNAME   -   Sets a default shape name that must conform to symbol- naming conventions. If no default is set, it returns "". Enter a period (.) to set no default.
SIGWARN   -   Controls whether a warning is presented when a file with an attached digital signature is opened. If the system variable is on and you open a file with a valid signature, the digital signature status is displayed. If the variable is off and you open a file, the digital signature status is displayed only if a signature is invalid. You can set the variable using the Display Digital Signature Information option on the Open and Save tab of the Options dialog box.
SKETCHINC   -   Sets the record increment for the SKETCH command.
SKPOLY   -   Determines whether the SKETCH command generates lines or polylines.
SNAPANG   -   Sets the snap and grid rotation angle for the current viewport. The angle you specify is relative to the current UCS.
SNAPBASE   -   Sets the snap and grid origin point for the current viewport relative to the current UCS.
SNAPISOPAIR   -   Controls the isometric plane for the current viewport.
SNAPMODE   -   Turns the Snap mode on and off.
SNAPSTYL   -   Sets the snap style for the current viewport.
SNAPTYPE   -   Sets the type of snap for the current viewport.
SNAPUNIT   -   Sets the snap spacing for the current viewport. If SNAPSTYL is set to 1, the X value of SNAPUNIT is adjusted automatically to accommodate the isometric snap.
SOLIDCHECK   -   Turns the solid validation on and off for the current session.
SOLIDHIST   -   Controls the default History property setting for new and existing objects. When set to 1, composite solids retain a “history” of the original objects contained in the composite.
SSFOUND   -   Displays the sheet set path and file name if a search for a sheet set is successful.
SSLOCATE   -   Controls whether the sheet set associated with a drawing is located and opened when the drawing is opened.
SSMAUTOOPEN   -   Controls the display behavior of the Sheet Set Manager when a drawing associated with a sheet is opened.
SSMPOLLTIME   -   Controls the time interval between automatic refreshes of the status data in a sheet set.
SSMSHEETSTATUS   -   Controls how the status data in a sheet set is refreshed.
SSMSTATE   -   Determines whether the Sheet Set Manager window is open or closed.
STANDARDSVIOLATION   -   Specifies whether a user is notified of standards violations in the current drawing when a nonstandard object is created or modified.
STARTUP   -   Controls whether the Create New Drawing dialog box is displayed when a new drawing is started with NEW or QNEW. Also controls whether the Startup dialog box is displayed when the application is started.
SYSCODEPAGE   -   Indicates the system code page, which is determined by the operating system. To change the code page, see Help in your operating system.
TABLEINDICATOR   -   Controls the display of row numbers and column letters when the In-Place Text Editor is open for editing a table cell.
TABLETOOLBAR   -   Controls the display of the Table toolbar.
TASKBAR   -   Controls how drawings show up in windows taskbar between sessions.
TBCUSTOMIZE   -   Controls whether tool palette groups can be customized.
TDCREATE   -   Stores the local time and date the drawing was created.
TDINDWG   -   Stores the total editing time, which is the total elapsed time between saves of the current drawing. The format is:
TDUCREATE   -   Stores the universal time and date that the drawing was created.
TDUPDATE   -   Stores the local time and date of the last update/save.
TDUSRTIMER   -   Stores the user-elapsed timer.
TDUUPDATE   -   Stores the universal time and date of the last update/save.
TEMPOVERRIDES   -   Turns temporary override keys on and off. A temporary override key is a key that you can hold down to temporarily turn on or turn off one of the drawing aids that are set in the Drafting Settings dialog box; for example, Ortho mode, object snaps, or Polar mode.
TEMPPREFIX   -   Contains the directory name (if any) configured for placement of temporary files, with a path separator appended.
TEXTEVAL   -   Controls how text strings entered with TEXT (using AutoLISP) or with -TEXT are evaluated.
TEXTFILL   -   Controls the filling of TrueType fonts while plotting and rendering.
TEXTOUTPUTFILEFORMAT   -   Provides Unicode options for plot and text window log files.
TEXTQLTY   -   Sets the resolution tessellation fineness of text outlines
TEXTSIZE   -   Sets the default height for new text objects drawn with the current text style. TEXTSIZE has no effect if the current text style has a fixed height.
TEXTSTYLE   -   Sets the name of the current text style.
THICKNESS   -   Sets the current 3D thickness.
TILEMODE   -   Makes the Model tab or the last layout tab current.
TIMEZONE   -   Sets the time zone for the sun in the drawing. The values in the table are expressed as hours and minutes away from Greenwich Mean Time. The geographic location you set also sets the time zone. If the time zone is not accurate, you can correct it in the Geographic Location dialog box or set the TIMEZONE system variable.
TOOLTIPMERGE   -   Combines drafting tooltips into a single tooltip. The appearance of the merged tooltip is controlled by the settings in the Tooltip Appearance dialog box.
TOOLTIPS   -   Controls the display of tooltips on toolbars.
TPSTATE   -   Determines whether the Tool Palettes window is open or closed.
TRACEWID   -   Sets the default trace width.
TRACKPATH   -   Controls the display of polar and object snap tracking alignment paths.
TRAYICONS   -   Controls whether a tray is displayed on the status bar.
TRAYNOTIFY   -   Controls whether service notifications are displayed in the status bar tray.
TRAYTIMEOUT   -   Controls the length of time (in seconds) that service notifications are displayed. Valid values are 0 to 10.
TREEDEPTH   -   Specifies the maximum depth, that is, the number of times the tree-structured spatial index can divide into branches.
TREEMAX   -   Limits memory consumption during drawing regeneration by limiting the number of nodes in the spatial index (oct-tree).
TRIMMODE   -   Controls whether selected edges for chamfers and fillets are trimmed.
TSPACEFAC   -   Controls the multiline text line-spacing distance measured as a factor of text height. Valid values are 0.25 to 4.0.
TSPACETYPE
TSTACKALIGN   -   Controls the vertical alignment of stacked text.
TSTACKSIZE   -   Controls the percentage of stacked text fraction height relative to selected text's current height. Valid values are from 25 to 125.
UNDOCTL   -   Indicates the state of the Auto, Control, and Group options of the UNDO command. The setting is stored as a bitcode using the sum of the following values:
UNDOMARKS   -   Stores the number of marks placed in the UNDO control stream by the Mark option. The Mark and Back options are not available if a group is currently active.
UNITMODE   -   Controls the display format for units. By default, the format for displaying measured values differs slightly from the format used for entering them. (You cannot include spaces when entering measured values.)
UPDATETHUMBNAIL   -   Controls updating of the thumbnail previews in the Sheet Set Manager. The setting is stored as a bitcode using the sum of the following values:
USERI1-5   -   Provides storage and retrieval of integer values. There are five system variables: USERI1, USERI2, USERI3, USERI4, and USERI5.
USERR1-5   -   Provides storage and retrieval of real numbers. There are five system variables: USERR1, USERR2, USERR3, USERR4, and USERR5.
USERS1-5   -   Provides storage and retrieval of text string data. There are five system variables: USERS1, USERS2, USERS3, USERS4, and USERS5.
VIEWMODE   -   Stores the View mode for the current viewport. The setting is stored as a bitcode using the sum of the following values:
VIEWSIZE   -   Stores the height of the view displayed in the current viewport, measured in drawing units.
VIEWTWIST   -   Stores the view rotation angle for the current viewport measured relative to the WCS.
VISRETAIN   -   Controls the properties of xref-dependent layers. Controls visibility, color, linetype, lineweight, and plot styles.
VPLAYEROVERRIDES   -   Indicates if there are any layers with viewport (VP) property overrides for the current layout viewport.
VPLAYEROVERRIDESMODE   -   Controls whether layer property overrides associated with layout viewports are displayed and plotted.
VPMAXIMIZEDSTATE   -   Stores a value that indicates whether the viewport is maximized. The maximized viewport state is canceled if you start the PLOT command.
VSBACKGROUNDS   -   Controls whether backgrounds are displayed in the visual style applied to the current viewport.
VSEDGECOLOR   -   Sets the color of edges in the visual style in the current viewport.
VSSTATE   -   Stores a value that indicates whether the Visual Styles window is open or closed.
VTDURATION   -   Sets the duration of a smooth view transition, in milliseconds. The valid range is 0 to 5000.
VTENABLE   -   Controls when smooth view transitions are used. Smooth view transitions can be on or off for panning and zooming, for changes of view angle, or for scripts. The valid range is 0 to 7.
VTFPS   -   Sets the minimum speed of a smooth view transition, in frames per second. When a smooth view transition cannot maintain this speed, an instant transition is used. The valid range is 1 to 30.
WINDOWAREACOLOR   -   Controls the color of the transparent selection area during window selection. The valid range is 1 to 255. SELECTIONAREA must be on.
WMFBKGND   -   Controls the background display when objects are inserted in Windows metafile (WMF) format. The objects may be inserted using any of the following methods:
WMFFOREGND   -   Controls the assignment of the foreground color when objects are inserted in Windows metafile (WMF) format. The objects may be inserted using any of the following methods:
WORLDUCS   -   Indicates whether the UCS is the same as the WCS.
WORLDVIEW   -   Determines whether input to the DVIEW and VPOINT commands is relative to the WCS (default) or the current UCS.
WRITESTAT   -   Indicates whether a drawing file is read-only or can be written to. For developers who need to determine write status through AutoLISP.
WSCURRENT   -   Returns the current workspace name in the command line interface and sets a workspace to current.
XCLIPFRAME   -   Controls the visibility of xref clipping boundaries.
XEDIT   -   Controls whether the current drawing can be edited in-place when being referenced by another drawing.
XFADECTL   -   Controls the fading intensity percentage for references being edited in-place. Valid values are from 0 to 90
XLOADCTL   -   Turns xref demand-loading on and off, and controls whether it opens the referenced drawing or a copy.
XLOADPATH   -   Creates a path for storing temporary copies of demand-loaded xref files. For more information, see XLOADCTL.
XREFCTL   -   Controls whether external reference log (XLG) files are created.
XREFNOTIFY   -   Controls the notification for updated or missing xrefs.
XREFTYPE   -   Controls the default reference type when attaching or overlaying an external reference.
ZOOMFACTOR   -   Controls how much the magnification changes when the mouse wheel moves forward or backward. Accepts an integer between 3 and 100 as a valid value. The higher the number, the more the change.
ZOOMWHEEL   -   Toggles the direction of transparent zoom operations when you scroll the middle mouse wheel.
Guest
« Reply #4 on: August 30, 2007, 10:15:19 AM »
What have you got for MEP?  Any "undocumented" vars?  Could you post a PDF?
KewlToyZ
« Reply #5 on: August 30, 2007, 10:42:28 AM »
Tell you what Matt I have 4 text docs I am still just putting in the definitions for before I build the xls file.
After that I wanted to add the possible settings if they are bitwise with those definitions.
When I get the xls with the initial definitions I'll post it for the swamp.
I got really irritated this day in age there hasn't been one made by Autodesk.
Like so many so called "standards" committees that want people to adopt them but never offer their volumous lists etc.. in anything useful but a pdf rather than xls.
Guest
« Reply #6 on: August 30, 2007, 10:44:25 AM »
Sounds good.  Thanks.
KewlToyZ
« Reply #7 on: August 30, 2007, 12:55:12 PM »
That reminded me of the one obscure variable used to control explode.
Do you remember that one?
Guest
« Reply #8 on: August 30, 2007, 01:21:11 PM »
For ABS/MEP??
KewlToyZ
« Reply #9 on: August 30, 2007, 01:35:57 PM »
For ABS/MEP??
Nah it was QAFLAGS
One that nagged many folks with explode.
http://manusoft.com/Resources/AcadExposed/index.stm
« Last Edit: August 30, 2007, 01:37:29 PM by KewlToyZ »
KewlToyZ
« Reply #10 on: August 30, 2007, 02:15:43 PM »
Ran a (command "setvar" "?" "*")
and got 583 setvar's so far available in my default template.
It had been a few months since I had counted.
could anyone possibly run the above command in 2000i, 2004, 2006 for me and paste the entire contents to a text file for me. I wanted to get an idea of versions to assess whats new.
« Last Edit: August 30, 2007, 02:18:00 PM by KewlToyZ »
Guest
« Reply #11 on: August 30, 2007, 02:20:09 PM »
Do you have any way of getting ALL of the undocumented commands - the ones that DON'T show up when doing (command "setvar" "?" "*")??
Tim started something a while back...not sure where he ended up with that?
KewlToyZ
« Reply #12 on: August 30, 2007, 02:53:59 PM »
I keep thinking there was a way to get a dump but whether that was commands or setvars I can't remember.
I'm lucky if I remember where my car keys are most days  :ugly:
Autodesk forums gave me this list http://www.hyperpics.com/system_variables/index.asp
Looks to be 654 setvars... decent start to getting this list finalized.
The Manusoft site appears to leave off around 2K?
KewlToyZ
« Reply #13 on: August 30, 2007, 03:16:12 PM »
Wow never saw that SYSVDLG in action, nice little express tool I may have to get crazy with soon.
MP's Atoms Family was way kewl too!
« Last Edit: August 30, 2007, 03:22:29 PM by KewlToyZ »
