Author Topic: DeSelect current selectin set from Tool Palette  (Read 11576 times)
Glenn R
Re: DeSelect current selectin set from Tool Palette
« Reply #15 on: June 13, 2007, 01:11:14 AM »
Something like this perhaps:
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedSSSetFirst")]
private static extern int acedSSetFirst(long[] pset, long[] unused);
[CommandMethod("SetFirstTest", CommandFlags.UsePickSet | CommandFlags.Redraw | CommandFlags.Modal)]
static public void SetFirstTestCommand( ) {
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
try {
PromptSelectionResult prs = ed.SelectImplied();
if(prs.Status != PromptStatus.OK)
return;
SelectionSet ss = prs.Value;
ed.WriteMessage("\nNumber of selected objects: {0}", ss.Count);
acedSSetFirst(null, null);
} catch(System.Exception ex) {
ed.WriteMessage(ex.Message);
Completely untested of course :)
Cheers,
Glenn.
Paul Richardson
« Reply #16 on: June 13, 2007, 08:34:52 AM »
try {
return;
Cheers,
Glenn.
Glenn, Do you know why most of the names are mangled but some not?
Thanks.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: June 13, 2007, 08:58:04 AM »
I know you asked Glenn, but… :-P
The function was probably exported as a global function for ARX, but not yet wrapped for .NET
Glenn R
« Reply #18 on: June 13, 2007, 09:07:58 AM »
It has to do with the c++ compiler, function exports and name collisions wrt the vtable AFAIK.
Cheers,
Glenn.
Paul Richardson
« Reply #19 on: June 13, 2007, 09:40:04 AM »
Well... I meant anyone with the answer...~) Thanks...
Paul Richardson
« Reply #20 on: June 13, 2007, 09:41:33 AM »
Cheers,
Glenn.
Danka... Just curious.
« Reply #21 on: June 13, 2007, 11:19:51 AM »
For now you could try this - until you master P/Invoke...:)
This doesn't look like it will happen anytime soon.  :-)  I didn't understand the article on first read, so I have to reread it when I have more time to comprehend it.
object o = AcadApp.GetSystemVariable("Pickfirst");
 AcadApp.SetSystemVariable("Pickfirst", o);
This worked nicely.  I will post the full code in the other thread as that is where it is posted now.
Thanks Paul!
« Reply #22 on: June 13, 2007, 11:33:47 AM »
try {
return;
Cheers,
Glenn.
Thanks for the example Glenn.  I will try and understand it when I have more time later today.
Edit: May take more time than I originally thought. =D  Need to study up on DllImport.
« Last Edit: June 13, 2007, 05:43:27 PM by T.Willey »
« Reply #23 on: June 13, 2007, 06:56:31 PM »
Thanks Glenn that worked with one small correction.  The function name is 'SSSetFirst', with three 's'.
I have the program 'depends', and I see the call to 'SSSetFirst' within there, but the entry point is a number.  How do I know which one to use (for future situations)?
Glenn R
« Reply #24 on: June 13, 2007, 07:11:33 PM »
Tim,
The function name was correct in my code (look at the entrypoint)...I just dropped an 'S' in my alias of it, which doesn't matter (you could it anything you want).
I use "Dumpbin /E" on the file and redirect it's output to a text file...that will give you all the names.
Glenn.
« Reply #25 on: June 13, 2007, 07:22:38 PM »
Tim,
I thought I looked there first.  Must have thought you named them all the same.  :wink:
Glenn.
I think that is how Kean said to do it on his blog (nope, but something like this method).  I was hoping there would be an easier way.
Thanks again.
Paul Richardson
« Reply #26 on: June 13, 2007, 10:11:58 PM »
Tim,
Glenn.
Thanks again.
To use Fenton's method save the batch as findfile.bat (or whatever you like) to your acad root. Using VS comamnd prompt call as such - findfile.bat functionname If you want to write to a text file use the redirection operator as stated findfile.bat functionname > text.txt. This is slow so be patient...
Edit: Browse (cd) to the acad root in the command line tool before running.
« Last Edit: June 13, 2007, 10:25:00 PM by Paul Richardson »
