Dan,
As Keith mentioned, it is very easy to create elevations and sections but another reason (well, many reasons ...), and it's easier done than said;
lets describe our way through creating a room.
The first way, we'll call board drafting. The second, cad drafting.
Ok ... so, ... with board drafting you draw a line the length you need.
You offset that line the width of the wall you need.
You close the ends so you can hatch the wall with the pattern to describe the type of wall you have.
You pick the hatch, set the scale and hatch the wall.
With cad drafting, you place a wall.
You stretch the wall the length you need.
(Your done at this point. The hatch, the ends, the heighth, already taken care of)
With board drafting, you draw a line perpendicular to the wall to represent the outside face of the door.
You offset that line the width of the door.
You close the ends.
You draw an arc to represent the swing of the door.
You trim the wall for the opening of the door.
You re-hatch the wall.
With cad drafting, you pick the wall where you want the door.
you specify the type of door.
(Your done at this point. The wall, the door, the hatch, everything.)
Keith, That is currently what we have, a set of roughly six stl stud walls of different widths. We use it as a template more or less, just drop it into the drawing and designate the wall we want then purge the others when the project is near completion. It gets to making a bulky dwg and a bit confusing when you have several types of walls as well as types of sizes or widths. I'm trying to consolidate it but can't find a solution for steel stud walls.
