Author Topic: Delete Item from a block  (Read 11974 times)
Re: Delete Item from a block
« Reply #15 on: September 21, 2006, 08:23:02 AM »
Andy,
Just a typo in the latest routine.
Change theses two lines:
   (equal (vla-get-IsXref Blk) :vlax-false)
   (equal (vla-get-IsLayout Blk) :vlax-false)
Needs to be Blk and not Obj.
Also you will need a (regen) to see the results. At least I did.
« Reply #16 on: September 21, 2006, 11:05:53 AM »
Tim,
I stand corrected, Nice example. :-)
Using plain lisp would be messy at best.
Thanks Alan.
When I try to run this lisp, i get an error message
; error: bad argument type: VLA-OBJECT nil
What am I doing wrong. I've typed in (vl-load-com) first but it makes no difference.
Andy,
Correct.  Oops  :oops:
If you need a regen in there, then add this line to the end of the code, before the (princ) line.
(vla-Regen ActDoc acActiveViewport)
