Author Topic: Howto join adjacent LWpolylines with VBA?  (Read 11474 times)
LE
Re: Howto join adjacent LWpolylines with VBA?
« Reply #15 on: May 25, 2006, 10:52:15 PM »
No need, use it like you would the express polylinejoin command. It does that and a little more. So you can have some arcs and lines and polys and join them.
I see, thanks, I was in another radio station, then.
« Last Edit: May 26, 2006, 10:05:10 AM by Robert Zimmerman »
havano
« Reply #16 on: May 26, 2006, 10:42:09 AM »
I hesitate to use your mighty solution for my simple problem (which I allready solved in a quick and dirty way that has nothing to do with VBA). I don't even possess any drawing that would help me judge your "beast" for its merits. Maybe if you made a drawing available that does, I would appreciate that very much....
The code looks very impressive anyway (to me, anyway).
