Author Topic: _image Demand load failed due to missing module: !!!SOLVED!!!  (Read 2510 times)
mhillis
I am running autocad 14 and 2004 lt on windows XP and when I try to import a raster image into Autocad 14 I get the following message.
Description: ISM
Module Path:
Unknown command "IMAGE".  Press F1 for help.
Any suggestions on what will help?
« Last Edit: April 26, 2006, 09:00:42 AM by mhillis »
Yoland
mhillis
Re: _image Demand load failed due to missing module:
« Reply #2 on: April 26, 2006, 08:59:10 AM »
Thank you yolanda, that was the solution I needed.
