Author Topic: DXF Code - Layer Description  (Read 884 times)
Matthew H
« on: July 27, 2022, 02:39:48 PM »
Does anyone know what the DXF code is for a Layer's Description?
I was using the following to view the properties of a specific layer.
I am viewing the layer through AutoCAD's Symbol Table.
"https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-7B91F774-B0CD-4F5B-9FFA-1130443E659B"
  1. (entget (tblobjname "Layer" "LAYERNAME"))
  1. (
  2. ;APP: entity name.
  3. (-1 . <Entity name: 1b71cbbcea0>)
  4. ;Entity type (table name)
  5. (0 . "LAYER")
  6. ;Soft-pointer ID/handle to owner object
  7. (330 . <Entity name: 1b71cb6b020>)
  8. ;Handle (all except DIMSTYLE
  9. (5 . "D7A")
  10. ;Subclass marker (AcDbSymbolTable)
  11. (100 . "AcDbSymbolTableRecord")
  12. ;Subclass marker (AcDbSymbolTable)
  13. (100 . "AcDbLayerTableRecord")
  14. ;Name (attribute tag, block name, and so on)
  15. (2 . "Layeraaa")
  16. ;State Flag (1=Frozen, 2=Frozen in New Viewport, 4=Locked)
  17. (70 . 0)
  18. Color Number (If Negative, Layer is Off)
  19. (62 . 7)
  20. ;Linetype name (fixed)
  21. (6 . "Continuous")
  22. ;Plotting Flag (0=don't plot ,1=plot)
  23. (290 . 1)
  24. ;Lineweight enum value (AcDb::LineWeight).
  25. (370 . -3)
  26. ;Hard-pointer ID/handle of PlotStyleName object
  27. (390 . <Entity name: 1b71cb6b0f0>)
  28. ;Hard-pointer ID/handle to Material object
  29. (347 . <Entity name: 1b71cb6b600>)
  30. ;Hard-pointer ID/handle to visual style object (optional)
  31. (348 . <Entity name: 0>)
  32. )
I do not see any DXF codes regarding layer description.
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-3F0380A5-1C15-464D-BC66-2C5F094BCFB9#!
https://forums.autodesk.com/t5/net/finding-dxf-codes/td-p/2386631?attachment-id=491553
http://docs.autodesk.com/ACD/2011/ENU/filesDXF/WS1a9193826455f5ff18cb41610ec0a2e719-7a51.htm
Though, I do see DXF code "#1003 - Extended Layer Name". When is this code used?
If anyone knows where the layer description is stored, that would be much appreciated.
Thanks,
Matthew H.
« Last Edit: July 28, 2022, 07:58:27 AM by Matthew H »
Re: DXF Code - Layer Description
« Reply #1 on: July 27, 2022, 02:58:14 PM »
This was in my notes. Sorry my notes on the layer topic is very short (this is it) and void of any links to further reading.
  1. ;; LAYER group codes
  2. ;;
  3. ;; Group codes -   Description
  4. ;;
  5. ;; 100 - Subclass marker (AcDbLayerTableRecord)
  6. ;;
  7. ;; 2  -   Layer name
  8. ;;
  9. ;; 70 - Standard flags (bit-coded values):
  10. ;; 1  = Layer is frozen; otherwise layer is thawed
  11. ;; 2  = Layer is frozen by default in new viewports
  12. ;; 4  = Layer is locked
  13. ;; 16 = If set, table entry is externally dependent on an xref
  14. ;; 32 = If both this bit and bit 16 are set, the externally
  15. ;;      dependent xref has been successfully resolved
  16. ;; 64 = If set, the table entry was referenced by at least
  17. ;;      one entity in the drawing the last time the drawing
  18. ;;      was edited. (This flag is for the benefit of AutoCAD
  19. ;;      commands. It can be ignored by most programs that
  20. ;;      read DXF files and need not be set by programs that
  21. ;;      write DXF files)
  22. ;;
  23. ;; 62 - Color number (if negative, layer is off)
  24. ;;
  25. ;; 6 - Linetype name
  26. ;;
  27. ;; 290 - Plotting flag. If set to 0, do not plot this layer
  28. ;;
  29. ;; 370 - Lineweight enum value
  30. ;;
  31. ;; 380 - Ploy Style Name
  32. ;;
  33. ;; 390 - Hard-pointer ID/handle of PlotStyleName object
  34.
  35.            '(0 . "LAYER")
  36.            '(100 . "AcDbSymbolTableRecord")
  37.            '(100 . "AcDbLayerTableRecord")
  38.            (cons 2 "G-Anno-Note") ; layername
  39.            (cons 70 0) ; stuff
  40.            (cons 62 141); color number
  41.            ;; (cons 290 ; plot
  42.            (cons 6 "Continuous") ;; linetype
  43.            (cons 370 050)
  44.            ;;  LAYER LINEWEIGHT
  45.            ;;  this should be an integer representing one of the standard lineweight
  46.            ;;  values multiplied by 100 (i.e. 2.11mm becomes 211). Use -3 to specify the
  47.            ;;  'Default' lineweight.
  48.
  49.            ;; (cons 390 "Normal")
  50.
  51.            (list -3 (list "AcAecLayerStandard" '(1000 . "") (cons 1000 "This is a description")))
  52.          )
  53. )
Matthew H
« Reply #2 on: July 27, 2022, 03:10:40 PM »
John,
Thank you for posting your notes.
I was able to read the information with
  1. (entget(tblobjname "LAYER" "LAYERNAME")'("AcAecLayerStandard"))
Which add the following to the entgent.
  1. (-3 ("AcAecLayerStandard" (1000 . "") (1000 . "Sample Description Info"))
My Swamp searching skills need better work.
I have found this as a reference.
https://www.theswamp.org/index.php?topic=53135.0
Thanks,
Matthew H.
« Last Edit: July 27, 2022, 03:35:19 PM by Matthew H »
« Reply #3 on: July 27, 2022, 06:17:57 PM »
In general, whenever attempting to ascertain where particular data is stored within the DXF data for an entity, I would always suggest creating an entity (be it graphical or non-graphical, such as a layer) with the target properties, and then inspect the DXF data using a utility such as my Entity List function (or a similar function of the same nature).
For your case, you might observe data such as the following:
  1. _$ (elist (tblobjname "layer" "0"))
  2.
  3. (
  4.     (-1 . <Entity name: 7ff434803900>)
  5.     (0 . "LAYER")
  6.     (5 . "10")
  7.     (102 . "{ACAD_XDICTIONARY")
  8.     (360 . <Entity name: 7ff4348051e0>)
  9.     (102 . "}")
  10.     (330 . <Entity name: 7ff434803820>)
  12.     (100 . "AcDbLayerTableRecord")
  13.     (2 . "0")
  14.     (70 . 0)
  15.     (62 . 7)
  16.     (6 . "Continuous")
  17.     (290 . 1)
  18.     (370 . -3)
  19.     (390 . <Entity name: 7ff4348038f0>)
  20.     (347 . <Entity name: 7ff434803e00>)
  21.     (348 . <Entity name: 0>)
  22.     (-3
  23.         (
  24.             "AcAecLayerStandard"
  25.             (1000 . "")
  26.             (1000 . "Layer 0 Description")
  27.         )
  28.     )
  29. )
Note also that you may need to use regapp to register the AcAecLayerStandard xdata application ID if such ID is not already registered in the drawing.
