Author Topic: Why isn't my osmode setting changing?  (Read 2211 times)
bman
« on: June 21, 2005, 09:15:09 PM »
Why isn't my osmode changing to intersection @ line 12? Do I have it in the wrong place? I want it to change prior to issuing the rotate command.
(defun c:cir (/ osmd rw bldg pad padendp dist)
  (setq osmd (getvar "osmode"))
  (setvar "cmdecho" 0)
  (setvar "osmode" 4)
  (setq rw (getpoint "\nSnap to Center of R/W Arc: "))
  (setvar "osmode" 1)
  (setq bldg (getpoint "\nSelect Endpoint of Bldg. Front: "))
  (setq dist (distance rw bldg))
  (command "circle" rw dist)
  (setq pad (entsel "\nSelect Bldg. Pad: "))
  (setq padendp (getpoint "\nSelect Pad Endpoint Near Lot Line: "))
  (setvar "osmode" 32)
  (command "rotate" pad "" rw "r" rw padendp)
  (setvar "osmode" osmd)
bman
« Reply #1 on: June 21, 2005, 09:49:39 PM »
nevermind I just figured it out
daron
« Reply #2 on: June 22, 2005, 08:27:09 AM »
I don't know if you'd like it, but if you'd like a rubber-band line from pad point to padendp you could do this:
(setq padendp (getpoint (cadr pad) "\nSelect Pad Endpoint Near Lot Line: "))
« Reply #3 on: June 22, 2005, 09:18:05 AM »
How about some error checking.
If you abort or fail to pick it will quit and remove the circle.
You may need to tweak to suite you specific needs but it is a start.
(defun c:cir (/ *error* osmd rw bldg pad padendp dist)
  ;; error function & Routine Exit
  (defun *error* (msg)
      (not
        (member
          msg
          '("console break" "Function cancelled" "quit / exit abort" "")
    ) ; endif
    ;;reset all variables here
    (if cir (entdel cir))
    (setq cir nil)
  (setvar "osmode" 4)
    (and
      (setvar "osmode" 1)
      (setvar "osmode" 0)
      (not (command "circle" rw dist))
      (setq cir (entlast))
      (setvar "osmode" 1)
      (setq
      (not (command "rotate" pad "" rw "r" rw padendp pause))
     (prompt "\n***  Command complete  ***")
       (prompt "\n***  Command Aborted  ***")
  (*error* "")
(prompt "\nCircle Loaded, Enter Cir to run.")
bman
« Reply #4 on: June 22, 2005, 10:34:25 AM »
Sweet! Thanks for the tips.
bman
« Reply #5 on: June 22, 2005, 10:49:59 AM »
How do I get the rubber band effect  between these two points?
I tried this but it didn't work:
      (setq bldg (getpoint (cadr rw) "\nSelect Endpoint of Bldg. Front: "))
David Hall
  • Automatic Duh Generator
« Reply #6 on: June 22, 2005, 10:52:32 AM »
i think you only need :
      (setq bldg (getpoint rw "\nSelect Endpoint of Bldg. Front: "))
David Hall
« Reply #7 on: June 22, 2005, 10:54:37 AM »
The cadr from Daron's example was because you used entsel to grab the building.  In this case, your are using an existing point your just defined, rw.
bman
« Reply #8 on: June 22, 2005, 11:25:25 AM »
Thanks for the tip!
daron
« Reply #9 on: June 22, 2005, 12:09:56 PM »
If you want a rectangular rubber-banding effect for any reason, just repleace the second points getpoint with getcorner.
