Author Topic: Visual Lisp Console  (Read 1464 times)
Guido Rooms
Visual Lisp Console
« on: September 22, 2016, 05:50:23 AM »
Hello to all,
When I enter the following at the prompt without quoting : (1 . 2)
then nothing at all happens, at least nothing that I can see.
The prompt just reappears as if nothing at all was read.
Doing this should throw an exception,  I think...
Can anybody explain this to me?
I don't understand.
Thanks in advance.
Re: Visual Lisp Console
« Reply #1 on: September 22, 2016, 08:05:34 AM »
Is anything printed at the AutoCAD command-line?
In my experience, VLIDE console errors are sometimes printed at the console and sometimes at the AutoCAD command-line.
Guido Rooms
« Reply #2 on: September 22, 2016, 09:04:13 AM »
Lee,
That's it, the error message seems to go to the wrong place.
At the prompt it says "bad syntax of function call: (1 . 2)".
Thanks a lot.
Do you know of any other jokes like that?
Grrr1337
« Reply #3 on: September 22, 2016, 01:59:45 PM »
_$ (list (1 . 2))
; bad syntax of function call: (1 . 2)  ; <- this is printed in autocad's command prompt
_$ '((1 . 2))
((1 . 2))
_$ (list (cons 1 2))
((1 . 2))
_$ (1 . 2)
_$ (cons 1 2)
(1 . 2)
Conclusion: you must use apostrophe/quote for the list, for the "handmade" dotted pairs, otherwise AutoCAD reads them as a function calls.
I'm not a pro-lisper so my conclusion might be wrong or not full.
(apply ''((a b c)(a b c))
vevo.bg
