Author Topic: LISP Learning Resources - AutoCAD  (Read 3074 times)
e_luvins
« on: July 28, 2015, 12:11:59 PM »
I'm new to programming and I'm interested in learning how to create LISP routines for AutoCAD.  I understand how to create and use scripts along with very simple lisp routines, but I want to know more.  My main goal is to automate common tasks within our firm (force standardization) to help guide users.  Currently, I'm interested in understanding and learning how to automate the following process:
1. QSELECT any block references with a Scale X=1
2. Explode
3. QSELECT any block references with a Scale X≠1
4. Change Scale X=1
Any direction to beginner resources is greatly appreciated!
Thanks,
Eric Vallejo, LSI
Missman, Inc.
ericv@missman.com
Re: LISP Learning Resources - AutoCAD
« Reply #1 on: July 28, 2015, 12:27:13 PM »
Welcome to theSwamp. You're in the right place for questions (theSwamp is an amazing resource of programmers).
May I suggest you start off by creating a post for a specific question you are having in specific areas (post the problem, and any code you have up to that point). Then get ready to sift through many good examples and offers to help.
77077
« Reply #2 on: July 28, 2015, 01:12:01 PM »
e_luvins
1-2
  1. (setq ss (ssget ":S" '((0 . "INSERT") (41 . 1))))
  2. (command "_.explode"ss "")
  3.
3-4
  1. (setq ss (ssget ":S" '((0 . "INSERT") (-4 . "/=")(41 . 1))))
  2. (setq dxf (entget (ssname ss 0)))
  3. (setq dxf (subst (cons 41 1) (assoc 41 dxf) dxf))
  4. (entmod dxf)
  5.
« Last Edit: July 28, 2015, 10:39:44 PM by ANJALI »
77077
« Reply #3 on: July 28, 2015, 09:39:34 PM »
Hi e_luvins ,can you understand ?
e_luvins
« Reply #4 on: July 29, 2015, 06:47:36 PM »
I will give the code a shot, though I don't understand it.....hence, my initial request for direction.  Thanks for putting it together; I will let you know the result and perhaps "learn a lesson".
Thanks,
Eric Vallejo, LSI
Missman, Inc.
ericv@missman.com
« Reply #5 on: July 30, 2015, 10:40:52 AM »
Thanks,
Eric Vallejo, LSI
Missman, Inc.
ericv@missman.com
Note that each one of the functions in blue is a hyperlink to a description .. you've got some reading to do :)
Peter2
« Reply #6 on: July 30, 2015, 02:11:12 PM »
...and I'm interested in learning how to create LISP routines for AutoCAD...
Of course there are many tutorials in the web - here you find a list of some of them:
http://lee-mac.com/tutorials.html
Peter
BricsCAD V23
« Reply #7 on: July 30, 2015, 03:45:02 PM »
Of course you will find many *more* tutorial here (pick a thread and start reading).
BIGAL
  • 40 + years of using Autocad
« Reply #8 on: August 08, 2015, 09:58:12 PM »
A bit more detail
(setq ss (ssget ":S" '((0 . "INSERT") (-4 . "/=")(41 . 1)))) ; a selection set of blocks INSERT with a not equal to dxf item 41 is 1
(setq dxf (entget (ssname ss 0))) ; get the 1st value of the selection set starts at 0 in this case ssget has only one
(setq dxf (subst (cons 41 1) (assoc 41 dxf) dxf)) ; swap the value of dxf code 41 to 1
(entmod dxf) ; update the block
danglar
  • Read My Li(s)(p)
« Reply #9 on: August 09, 2015, 08:44:26 AM »
Here you find a bunch of PDF AutoLisp Learning books:
https://lispbox.wordpress.com/books/
