Author Topic: VLA only select blocks in current space  (Read 2841 times)
ChrisCarlson
« on: November 13, 2014, 08:25:36 AM »
http://www.lee-mac.com/selsetprocessing.html
Will select all blocks in model space / paper space. My google-fu is not up to par this morning in finding the vla methods to only select blocks in the current space eg; model space, paper space, within a viewport.
Re: VLA only select blocks in current space
« Reply #1 on: November 13, 2014, 08:41:25 AM »
I use the following ssget filter:
(ssget "_X" (if (= 1 (getvar 'cvport)) (list (cons 410 (getvar 'ctab))) '((410 . "Model"))))
If you necessary require a VLA method, the above filter would need to be converted to an appropriate safearray variant and supplied to the vla-select function, along with the acselectionsetall enum.
ChrisCarlson
« Reply #2 on: November 13, 2014, 09:14:36 AM »
So selecting block variable A, only in the current space would go something like this?
(ssget "_X" (if (= 1 (getvar 'cvport))(list (cons 410 (getvar 'ctab))(cons 0 "INSERT")(cons 2 A)) '((410 . "Model")(cons 0 "INSERT")(cons 2 A))))
Makes sense to me, CVPORT returns 1 or 2 based on model space or paper space. If it returns 1 the selection set filters based on 410 to the layout name and if it returns 2 the line filters based on 410 being named Model?
« Reply #3 on: November 13, 2014, 09:26:16 AM »
Correct, though the code could be condensed to:
(ssget "_X" (list '(0 . "INSERT") (cons 2 a) (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))))
to avoid repeating the list items.
Just be aware that anonymous block references will need to be included if the block whose name is assigned to variable 'a' is dynamic.
Correct - the CVPORT system variable returns the ID of the active viewport - this is always 1 for the paperspace viewport.
