Author Topic: Help with this part of code  (Read 2265 times)
HasanCAD
« on: July 21, 2014, 09:03:26 AM »
I am createing, this part gives correct answer at first time but second time gives blank
(setq *str (cond ( (getstring (strcase (strcat "\nWhat is Stirrup Dia And repeatation? <" (setq *str (cond ( *str ) ( "T10@200" ))) ">: ")))) ( *str )))
Re: Help with this part of code
« Reply #1 on: July 21, 2014, 09:12:06 AM »
I would do it this way.
(setq *str (cond (*str) ("T10@200")))
(setq *str (if (= "" (setq tmp (strcase (getstring (strcat "\nWhat is Stirrup Dia And repeatation? <" *str  ">: ")))))
             *str tmp)
Edit:
Found the problem.
getstring returns "" on ENTER and not nil
« Last Edit: July 21, 2014, 10:20:30 AM by CAB »
HasanCAD
« Reply #2 on: July 21, 2014, 09:19:36 AM »
The same
(setq *str nil)
(setq *str (cond ((getstring (strcat "\nWhat is Stirrup Dia And repeatation? <" *str  ">: ")))))
when press Enter (without typing any data) the result is
nil
"T10@200"
« Reply #3 on: July 21, 2014, 09:24:16 AM »
Sorry i update code again, try that.
« Reply #4 on: July 21, 2014, 09:30:07 AM »
Also I question the placement of strcase? what is your intent?
HasanCAD
« Reply #5 on: July 21, 2014, 09:55:56 AM »
in case of the user types small letter and all letters should be ib capital
oopps I belive that it should be like this
(setq *str (if (= "" (setq tmp (strcase (getstring (strcat "\nWhat is Stirrup Dia And repeatation? <" *str  ">: "))))) *str tmp))
« Reply #6 on: July 21, 2014, 10:21:03 AM »
OK in that case I updated the code again.
Is it working for you?
« Reply #7 on: July 21, 2014, 12:21:53 PM »
Here is how I would approach it:
  1. (if (null *str)
  2.     (setq *str "T10@200")
  3. )
  4. (if (/= "" (setq tmp (strcase (getstring (strcat "\nWhat is Stirrup Dia And repeatation? <" *str ">: ")))))
  5.     (setq *str tmp)
  6. )
Not dissimilar to those already posted...
HasanCAD
« Reply #8 on: July 22, 2014, 05:45:14 AM »
Thanks CAB
Thnaks LEE
both working perfect
« Reply #9 on: July 22, 2014, 01:22:06 PM »
You're welcome Hasan  :-)
