Author Topic: Civil 3D - Xref or Data Shortcut  (Read 2975 times)
MSTG007
« on: June 19, 2014, 08:31:02 AM »
Gotta question. How do you guys usually setup your projects with the 3D Data? Do you usually xref your pipe networks and surface into your sheet files or do you usually use a data shortcut in all drawings (then re-label all the Sheet Files)?
Civil3D 2020
Re: Civil 3D - Xref or Data Shortcut
« Reply #1 on: June 19, 2014, 09:48:01 AM »
Three Words:
Plan Production Tools
MSTG007
« Reply #2 on: June 19, 2014, 09:50:21 AM »
Ok. The point that I see (unless I am unaware) with Data References between Xrefs, is the abilty to Label Something Once and not have to sync / label (re-label) in other sheet files.
Civil3D 2020
