Author Topic: ElevationAt Killing Me  (Read 2418 times)
bchapman
« on: February 02, 2013, 02:02:04 AM »
Anyone have example using elevationAt in C#?
bchapman
Re: ElevationAt Killing Me
« Reply #1 on: February 02, 2013, 02:21:31 AM »
Nevermind :)
BlackBox
« Reply #2 on: February 02, 2013, 09:05:09 AM »
Nevermind :)
You might consider posting your solution, the tutorial you found, an illustrative example, etc. for others to find.  :-)
bchapman
« Reply #3 on: February 02, 2013, 05:51:29 PM »
Not the greatest, but this is what I did:
    Profile profile = ts.GetObject(profileId, OpenMode.ForRead) as Profile;
                var FNLELEV = profile.ElevationAt(FNLSTA);
                ed.WriteMessage("\nElev={0}", FNLELEV);
I'd prefer it to select the profile by name... but don't know how to do that :/
« Last Edit: February 02, 2013, 07:03:28 PM by BC_in_NV »
BlackBox
« Reply #4 on: February 02, 2013, 06:29:11 PM »
Code - C#: [Select]
  1. Profile profile = ts.GetObject(profileId, OpenMode.ForRead) as Profile;
  2. var FNLELEV = profile.ElevationAt(FNLSTA);
  3. ed.WriteMessage("\nElev={0}", FNLELEV);
In lieu of Var FNELEV... You might consider the default ElevationAt() returned type of double (followed by ToString()?).
... This may just be personal preference.
Perhaps there's fruit to be had from the Alignment.GetProfileIds() Method?
P.S. - Don't forget [CODE ] Tags.  :wink:
bchapman
« Reply #5 on: February 02, 2013, 10:15:20 PM »
This is what I've done after getting the object collection... has to be better way...any thoughts?
foreach (ObjectId objid in BCCPROFILECOLLECTION)
                    Profile profile = ts.GetObject(objid, OpenMode.ForRead) as Profile;
                    ed.WriteMessage("\nProfile Name={0}",profile.Name);
                    var profilename = profile.Name as string;
                    var wantname = BCCPROFILENAMESET as string;
                    if (profilename.Equals(wantname))
                    break;
