Author Topic: Close all open drawings  (Read 8105 times)
ArgV
Re: Close all open drawings
« Reply #15 on: September 07, 2009, 11:45:08 AM »
Ok you lisp guru's, is there a way to open drawings in a directory using Tim's "mynext" and "myprevious" without vba?
It would be great to have these functions for autocad 2010, since it does not support vba.
Acad 2010 doesn't support VBA?
alanjt
  • Standby for witty remark...
« Reply #16 on: September 07, 2009, 11:59:42 AM »
you have to install it, no longer standard.
Dropbox
Crank
« Reply #17 on: September 07, 2009, 12:11:41 PM »
Autodesk will continue to support VBA now and into the foreseeable future in the AutoCAD product line. They have a transition plan to .NET and VSTA and expect to support VBA until research shows most customers have migrated their code (which could take years.)
At the moment Autodesk is offering VBA for download on their website, but I've read the 64bit version is very slow (haven't tried it).
VB(A) doesn't have a future because everyone is moving to 64bit and Microsoft doesn't support VB any more.
taner
« Reply #18 on: September 11, 2009, 04:34:39 AM »
Here's two for you  :-)
Open All Drawings in a Directory:
;; Open_all by Lee McDonnell
(defun c:open_all (/ path dwg)
  (if (setq path (Directory-Dia "Select Directory: "))
      (foreach dwg (mapcar
                     (function
                       (lambda (file)
                         (strcat path file)))
                     (vl-directory-files path "*.dwg" 1))
      (if (vl-catch-all-error-p
            (vl-catch-all-apply
              (function
                (lambda ( )
                  (vla-open
                    (vla-get-Documents
                      (vlax-get-acad-object)) dwg :vlax-false)))))
        (princ (strcat "\n** " dwg " Failed to Open **")))))
    (princ "\n*Cancel*"))
  (princ))
(defun Directory-Dia  (Message / sh folder folderobject result)
  ;; By Tony Tanzillo
  (setq sh (vla-getInterfaceObject
             (vlax-get-acad-object) "Shell.Application"))
  (setq folder (vlax-invoke-method sh 'BrowseForFolder
                 (vla-get-HWND
                   (vlax-get-Acad-Object)) Message 0))
  (vlax-release-object sh)
  (if folder
      (setq folderobject (vlax-get-property folder 'Self)
            result (vlax-get-property FolderObject 'Path))
      (vlax-release-object folder)
      (vlax-release-object FolderObject)
      (if (/= (substr result (strlen result)) "\\")
        (setq result (strcat result "\\"))
        result))))
Open Latest Drawing in a Directory:
;; Open_last by Lee McDonnell
(defun c:open_last (/ path lst dwg)
                     (function
                       (lambda (file)
        (setq lst
               (cons
                 (list dwg (remove_nth (vl-file-systime dwg) 2)) lst)))
            (vl-catch-all-apply
              (function
                (lambda ( )
                  (vla-open
                    (vla-get-Documents
                    (setq dwg (dSort lst)) :vlax-false)))))
  (princ))
  ;; By Tony Tanzillo
                 (vla-get-HWND
  (if folder
        result))))
; Stig
(defun remove_nth (lst i / a)
  (setq a -1)
  (vl-remove-if
    (function
      (lambda (n) (= (setq a (1+ a)) i))) lst))
(defun dSort (lst / lst)
  (while
      (cond ((not
               (vl-remove-if 'null
                 (mapcar 'cadr lst)))
             (setq lst nil))
            ((apply '=
               (vl-sort
                 (mapcar 'caadr lst)
                   (function
                     (lambda (a b) (< a b)))))
             (setq lst (mapcar
                         (function
                           (lambda (x)
                             (list (car x) (cdadr x)))) lst)))
            (t (setq lst (caar lst)) nil))))
  lst)
Enjoy :P
Can't open the "lt version" dwg.
Joe Burke
« Reply #19 on: September 11, 2009, 08:57:14 AM »
I'm not sure this applies to the issue, but it works well for me.
;; JB 12/5/2008
;; Save and close all open documents.
(defun c:SaveCloseAll ( / *acad* ad)
  (setq *acad* (vlax-get-acad-object)
        ad (vla-get-ActiveDocument *acad*)
  (vlax-for x (vla-get-documents *acad*)
    (if (not (equal x ad))
        (vlax-invoke x 'Save)
        (vlax-invoke x 'Close)
  (command "._close" "yes")
) ;end
;shortcut
(defun c:SCA () (c:SaveCloseAll))
GDF
« Reply #20 on: September 11, 2009, 11:04:23 AM »
Thanks guys.
taner
« Reply #21 on: September 11, 2009, 08:02:08 PM »
Here is mine.  Pretty much the same thing, but mine doesn't try and save them.  It hasn't locked up my Acad though.
(defun c:CloseAllButActive(/ tmpList)
    (vlax-for item (vla-get-documents (vlax-get-acad-object))
        (if (= (vla-get-active item) :vlax-false)
            (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-close (list item :vlax-false)))
                (setq tmpList (cons item tmpList))
    (foreach item tmpList
        (prompt (strcat "\n Drawing could not be closed \"" (vla-get-name item) "\"."))
Chang:
(defun c:CloseAllButActive (/ tmpList)
(vl-catch-all-apply
  'vla-close
       (vla-get-name item)
« Last Edit: September 11, 2009, 08:06:39 PM by Tsec2nd »
jxphklibin
« Reply #22 on: September 13, 2009, 03:48:20 AM »
Here is my routine:
;;不保存关闭所有文档
(defun c:USave-CloseAll ( / ACADOBJ DOCS DOC)
   (SETVAR "SDI" 0)
   (setq ACADOBJ (vlax-get-acad-object)
  DOCS (vla-get-documents ACADOBJ)
  DOC (vla-get-activedocument ACADOBJ)
   (vlax-for d DOCS
     (if (not (equal DOC d))
       (vla-close d :vlax-false)
   (command "vbastmt"  "AcadApplication.activeDocument.close false ")
   ;;最后关闭当前活动的文档,这样就把所有的文档都关闭了 false 不保存关闭当前文档,true 保存然后关闭当前文档
;;保存并关闭所有文档
(defun c:Save-CloseAll ( / ACADOBJ DOCS DOC)
   (SETVAR "SDI" 0)
   (vlax-for d DOCS
       (vla-close d :vlax-true) ;_改为:vlax-true表示保存后关闭
   (command "vbastmt"  "AcadApplication.activeDocument.close true ")
Krushert
  • FREE BEER Tomorrow!!
« Reply #23 on: September 15, 2009, 02:43:13 PM »
2010 has this feature built right in.  :roll: :evil: :lol:
antistar
« Reply #24 on: June 27, 2012, 07:14:22 AM »
;; JB 12/5/2008
) ;end
;shortcut
I want to take the theme of this post to ask:
 Does anyone know how to close all drawings without saving?
« Reply #25 on: June 27, 2012, 07:25:50 AM »
Using Joe's method:
  1. (defun c:ca ( / app acd )
  2.           acd (vla-get-activedocument app)
  3.     )
  4.     (vlax-for doc (vla-get-documents app)
  5.         (if (not (equal doc acd))
  6.             (vla-close doc)
  7.         )
  8.     )
  9.     (command "_.close" "_Y")
  10.     (princ)
  11. )
Or, simply the 'closeall' command (Express Tools).
