Author Topic: Working with dictionaries  (Read 2090 times)
Coder
« on: September 21, 2011, 07:52:39 AM »
Hello everyone ...
I would like to know how many dictionaries which each drawing would have . (e.g Mleaders , dimensions ...... etc )
And the title ( name ) of each dictionary name .
Finally , how to extract the style names of a dictionary in a list ?
Hope that not too much .
Many thanks .
Re: Working with dictionaries
« Reply #1 on: September 21, 2011, 08:11:53 AM »
To get you started, take a look at:
(entget (namedobjdict))
And:
(vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object)))
Also, study the functions:  dictnext, dictsearch
Coder
« Reply #2 on: September 21, 2011, 08:18:33 AM »
Thanks Lee .
I know the basics but my needs are behind or after that .
« Reply #3 on: September 21, 2011, 08:22:15 AM »
The above post will answer your first question, and studying the functions to which I referred will answer your second. Which part of my post was too basic?
Coder
« Reply #4 on: September 21, 2011, 08:48:20 AM »
With these codes I could get the number of Dicts that we have in each dwg session , but how to extract the name of styles in each dictionary ?
(setq Dlst (entget (namedobjdict)))
(setq n (vl-remove-if-not
          '(lambda (st)
             (eq (car st) 3)
          Dlst
(length n)
« Reply #5 on: September 21, 2011, 08:55:58 AM »
Hint:
(dictsearch (namedobjdict) "Your_Dictionary_Name")
Or:
(vlax-for item
    (vla-item
But be aware that the Item method will error if the key doesn't exist.
Coder
« Reply #6 on: September 21, 2011, 09:34:54 AM »
Thanks Lee ,
(setq n (vl-remove-if-not '(lambda (st) (eq (car st) 3))
          (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE")
Or .....
(vlax-for item
    (vla-item
        "ACAD_MLEADERSTYLE"
(setq styls (cons (vla-get-name item)styls))
Thanks a lot Lee for the infos and for the hint which gives the encouragement to look for it .  :-)
« Reply #7 on: September 21, 2011, 09:49:14 AM »
Teach a man to fish and all that  :wink:
