Author Topic: Need help with routine  (Read 2514 times)
PT
« on: February 08, 2005, 09:06:12 AM »
I noticed some time ago that a request was made for draing an arc between two circles and then the arc was trimmed from within the circle.
I cam across this routine and and it does just that except it would be nice to select a circle within a block and do the same thing, but when I try it with this routine it does not place the arc in the correct position. The routine is listed below. Can someone assist me?
Thank you..............
(defun C:3PA()
  ;;;--- Turn the command echo off
  (setvar "cmdecho" 1)
  ;;;--- Save the osnap settings
  (setq oldOs(getvar "osmode"))
  ;;;--- Turn osnaps off
  (setvar "osmode" 0)
  ;;;--- Let the user select the circles
  (setq ent1(nentsel "\n Select First Circle: "))
  (setq ent2(nentsel "\n Select Second Circle: "))
  ;;;--- If two entities were selected
  (if (and ent1 ent2)
      ;;--- Get the entities again using ssget to see if the circle is part of a block
      (if(setq eset1(ssget (cadr ent1) (list(cons 0 "INSERT"))))
          (setq blkEn(ssname eset1 0))
          (setq blkList(entget blkEn))
          (setq InsPt1(cdr(assoc 10 blkList)))
          (setq rot1(cdr(assoc 50 blkList)))
        (setq rot1 0)
      (if(setq eset2(ssget (cadr ent2) (list(cons 0 "INSERT"))))
          (setq blkEn(ssname eset2 0))
          (setq InsPt2(cdr(assoc 10 blkList)))
          (setq rot2(cdr(assoc 50 blkList)))
        (setq rot2 0)
      ;;;--- Get the entity names of the circles
      (setq en1(car ent1))
      (setq en2(car ent2))
      ;;;--- Get the DXF group codes from the entities
      (setq enlist1(entget en1))
      (setq enlist2(entget en2))
      ;;;--- If both entities selected were circles...
      (if(and (= "CIRCLE" (cdr(assoc 0 enlist1)))(= "CIRCLE" (cdr(assoc 0 enlist2))))
          ;;;--- Get the center points of the circles
          (setq cpt1 (cdr(assoc 10 enlist1)))
          (setq cpt2 (cdr(assoc 10 enlist2)))
          ;;;--- Get the radii of the circles
          (setq rad1(cdr(assoc 40 enlist1)))
          (setq rad2(cdr(assoc 40 enlist2)))
          ;;;--- Apply the insertion points if a block was present
          (if eset1
            (setq cpt1(polar cpt1 (angle (list 0 0) insPt1) (distance (list 0 0) insPt1)))
          (if eset2
            (setq cpt2(polar cpt2 (angle (list 0 0) insPt2) (distance (list 0 0) insPt2)))
          ;;;--- Apply the block rotations
          (if(/= 0 rot1)
            (setq cpt1(polar insPt1 (+ rot1 (angle insPt1 cpt1)) (distance insPt1 cpt1)))
          (if (/= 0 rot2)
            (setq cpt2(polar insPt2 (+ rot2 (angle insPt2 cpt2)) (distance insPt2 cpt2)))
          ;;;--- Draw the arc temporarily to find it's properties
          (command "arc" cpt1 "E" cpt2 "D" pause)
          ;;;--- Get the entity name of the arc
          (setq en(entlast))
          ;;;--- Get the DXF group codes of the arc
          (setq enlist(entget en))
          ;;;--- Get the center point of the arc
          (setq cpt(cdr(assoc 10 enlist)))
          ;;;--- Delete the arc
          (entdel en)
          ;;;--- Work on the first circle selected
          ;;;--- Find the distance from the center of the circle to the center of the arc
          (setq slp(distance cpt cpt1))
          ;;;--- The rise should be half of the radius
          (setq ris(/ rad1 2.0))
          ;;;--- Get the run from the rise and slope
          (setq run(sqrt(- (* slp slp)(* ris ris))))
          ;;;--- Get the angle of the triangle
          (setq ang(atan(/ ris run)))
          ;;;--- The arc will bisect the circle twice, get both intersection points
          (setq anga(+ ang ang (angle cpt cpt1)))
          (setq npta(polar cpt anga slp))
          (setq angb(- (angle cpt cpt1) ang ang))
          (setq nptb(polar cpt angb slp))
          ;;;--- Work on the second circle selected
          (setq slp(distance cpt cpt2))
          (setq ris(/ rad2 2.0))
          (setq anga(+ ang ang (angle cpt cpt2)))
          (setq nptc(polar cpt anga slp))
          (setq angb(- (angle cpt cpt2) ang ang))
          (setq nptd(polar cpt angb slp))
          ;;;--- Get the correct intersection points on each circle
          (if(< (distance npta nptd)(distance nptb nptc))
             (setq pt1 npta pt2 nptd)
             (setq pt1 nptb pt2 nptc)
          ;;;--- Check for clockwise counter-clockwise directions
          (if (not c:cal)(arxload "geomcal"))
          (setq myAng1 (cal "ang(cpt,pt1,pt2)"))
          (setq myAng2 (cal "ang(cpt,pt2,pt1)"))
          ;;;--- Draw the arc
          (if(< myang1 myAng2)
            (command "arc" "C" cpt pt1 pt2)
            (command "arc" "C" cpt pt2 pt1)
        (alert "Select two circles please!")
    (alert "You must select two circles!")
  (setvar "osmode" oldOs)
;; ^C^Cosmode;16;^C^C-layer;set;E-PWR-CON;;arc;\\\
(defun c:ea ()
  (command "osmode" 16)
  (command "-layer" "set" "E-PWR-CON" "" "")
  (command "arc")
(defun c:ea2 (/ usrosm clayer)
  (setq usrosm (getvar "osmode")
        clayer (getvar "clayer")
  (setvar "osmode" 16)
  (command "arc" pause pause pause)
  (setvar "osmode" usrosm)
  (setvar "clayer" clayer)
(defun c:ea3 (/ usrosm clayer)
  (setvar "clayer" "E-PWR-CON")
(defun c:ea4 (/ usrosm clayer)
   (command "_.layer" "M" "E-PWR-CON" "")
   (setvar "osmode" 512)
   (command "_.arc" pause pause pause)
