Hello,
Is there a way to find a block that is nested within another block programmatically in ObjectARX for .Net without iterating through all the blocks? I don't want the user to select the block themselves either. I want a method to get a particular block within a block. The other issue is that there can be multiple parent blocks with the same nested block of the same name in the drawing, so iterating through the block table would find each of the same block. If you have the parent block of the nested block, is there any way to single out this nested block without selecting others of the same name?
Thanks,
cannorth
