Author Topic: Steering Findfile search  (Read 1923 times)
Krushert
  • FREE BEER Tomorrow!!
« on: July 06, 2011, 11:08:51 AM »
How do I steer findfile search to look for the needle that is only under haystack "U" and not for the needle that is under haystack "C"?
(setq MyDocPrefx (getvar "MYDOCUMENTSPREFIX"))
(setq OldUserFolder1 (vl-filename-directory (findfile (strcat MyDocPrefx "acad.pgp"))))
BlackBox
Re: Steering Findfile search
« Reply #1 on: July 06, 2011, 11:11:49 AM »
Not sure I understand you fully, but you might try this adaptation:
(setq OldUserFolder1 (vl-filename-directory (findfile (strcat MyDocPrefx "\\acad.pgp"))))
Note the "\\" prefix in front of "acad.pgp" now.
Krushert
« Reply #2 on: July 06, 2011, 11:18:00 AM »
Tried that.  It upchuck a "bad argument type:  stringp nil"  :x
BlackBox
« Reply #3 on: July 06, 2011, 11:26:15 AM »
That's because your findfile returned nil (meaning acad.pgp was not found).
Perhaps this is a more appropriate test:
(if (setq
      path (findfile
             (strcat (setq MyDocPrefx (getvar "MYDOCUMENTSPREFIX"))
                     "\\acad.pgp")))
  (setq OldUserFolder1 (vl-filename-directory path))
  (alert (strcat "ACAD.pgp cannot be found at :"
                 "\n\n"
                 MyDocPrefx)))
Krushert
« Reply #4 on: July 06, 2011, 11:53:53 AM »
Okay that did not upchuck but it did return your alert message.
That being said, now I know (or believe) that find file is not looking in the sub-folders.  For this particular user, his PGP file is located 2 folders down in his Mydocs folder.
  Each my users ACAD user files are in folders with different names and I am try to correct that with code when I install 2012.
« Reply #5 on: July 06, 2011, 12:01:39 PM »
Maybe this might help?
« Reply #6 on: July 06, 2011, 12:23:47 PM »
A few of ElpanovEvgeniy's file routines have helped me several times.
Link:
https://www.theswamp.org/index.php?topic=15186.msg184298#msg184298
Krushert
« Reply #7 on: July 06, 2011, 01:25:53 PM »
Thanks Guys!
Thanks helped!
