Author Topic: how do i read a list variable?  (Read 4179 times)
andrew_nao
Re: how do i read a list variable?
« Reply #15 on: October 20, 2010, 09:19:26 AM »
thanks everyone for you help
I got what I was after
much appreciated
andrew_nao
« Reply #16 on: January 03, 2011, 12:04:48 PM »
if anyone can shed some light here
been using this code lately and all the sudden today im getting syntax error
anyone see something wrong that im not seeing?
(SETQ lst (VL-DIRECTORY-FILES "O:\\"))
(defun wcmatch_first ( lst pattern flag / result )
    (setq pattern (if flag (strcase pattern) pattern))
    (vl-some
       '(lambda (str) (if  (setq result str)))
        (if flag (mapcar 'strcase lst) lst)
    result
(SETQ var (strcase (GETSTRING "Enter order number: ")))
(if (wcmatch_first lst (strcat "*" var "*") nil)
         (alert "yes") ;if found
         (alert "no") ; not found
