Author Topic: VB.net extract AutoCAD data  (Read 3058 times)
mikeantosh
« on: July 16, 2010, 10:50:39 AM »
I would like to be able to extract data from a drawing using VB.net.
I would like to avoid opening AutoCAD and sending commands.  I hope to simply have a standalone VB form that simply connects and gathers data.
I am using VB.net 2008 and AutoCAD 2008.
Can anyone help?
mwrfdot
Re: VB.net extract AutoCAD data
« Reply #1 on: July 23, 2010, 01:34:57 PM »
This AU Class on the Data Extraction API might start you in the right direction.
http://images.dcheetah.com/au.autodesk.com/ama/images/media/CP301-2L_Data-Extraction-API.pdf
« Reply #2 on: July 23, 2010, 07:31:49 PM »
Welcome to theSwamp guys.
Michael, I think the Data Extraction API is only available from AC2009 onwards.
