There is copy multiple in express tools....it's copym.lsp
In your code you didn't have an enter ("") after the object was selected then you set multiple and pick point to copy from.
(defun c:cm() (command "copy" pause "" "m" pause) (princ))
;; Copym.lsp - Multiple copy command with measure, divide and array capabilities.
;; Copyright © 1999 by Autodesk, Inc.
;; Your use of this software is governed by the terms and conditions
;; of the License Agreement you accepted prior to installation of this
;; software. Please note that pursuant to the License Agreement for this
;; software, "[c]opying of this computer program or its documentation
;; except as permitted by this License is copyright infringement under
;; the laws of your country. If you copy this computer program without
;; permission of Autodesk, you are violating the law."
;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;; UNINTERRUPTED OR ERROR FREE.
(defun c:copym ( / ss p1 cmd snaptp ucshold )
(acet-error-init
(list (list "cmdecho" 0
"snaptype" 0
"snapmode" nil
"gridmode" nil
"snapunit" nil
"gridunit" nil
);list
0
'(progn
(acet-sysvar-set (list "cmdecho" 0))
(if ss
(acet-ss-redraw ss 4)
(if ucshold
(acet-ucs-set ucshold)
(acet-sysvar-restore)
);progn
);list
);acet-error-init
(setq ucshold (acet-ucs-get nil))
(if (setq ss (ssget))
(acet-ss-redraw ss 3)
(setq p1 (getpoint "\nBase point: "))
(if p1
(acet-copym ss p1)
);if
);progn then
);if
(acet-error-restore)
);defun c:copym
(defun acet-copym ( ss p1 / na p2 n d lst j p3 )
(setq p2 T)
(setq n 0)
(while p2
(setq na (entlast))
(if (not lst)
(setq lst (list (list ss p1)))
);if
(setvar "lastpoint" p1)
(initget 128 "Repeat Divide Measure Array Undo eXit")
(setq p2 (acet-ss-drag-move
ss
p1
"\nSecond point or \n[Repeat (last)/Divide/Measure/Array (dynamic)/Undo] <exit>: "
nil
);acet-ss-drag-move
);setq
(if (= p2 "eXit")
(setq p2 nil)
);if
((= p2 "Undo")
(if (= n 0)
(princ "\nNothing to undo.")
(command "_.undo" "1")
(setq n (- n 1)
lst (cdr lst)
ss (car lst)
p1 (cadr ss)
ss (car ss)
);setq
);progn else
);if
);cond #1
((= p2 "Repeat")
(if (= n 0)
(princ "\nNothing to repeat.")
(setq p2 (cadr (car lst))
p1 (cadr (cadr lst))
d (list (- (car p2) (car p1))
(- (cadr p2) (cadr p1))
(- (caddr p2) (caddr p1))
);list
);setq
(command "_.copy" ss "" d "")
(setq n (+ n 1)
ss (acet-ss-new na)
p1 (list (+ (car p2) (car d))
(+ (cadr p2) (cadr d))
(+ (caddr p2) (caddr d))
);list
lst (cons (list ss p1) lst)
);setq
);progn else
);if
);cond #2
((equal 'LIST (type p2))
(command "_.copy" ss "" p1 p2)
(setq n (+ n 1)
ss (acet-ss-new na)
p1 p2
);setq
);cond #3
((and (= "Divide" p2)
(setq p3 (getpoint p1 "\nSelect division ending point: "))
(initget 6)
(setq j (getint "\nNumber of copies: "))
);progn
);and
(setq ss (acet-copym-divide ss p1 p3 j)
p1 p3
n (+ n 1)
);setq
);cond #4
((and (= "Measure" p2)
(setq p3 (getpoint p1 "\nSelect measure ending point: "))
(initget 6)
(setq d (getdist "\nDistance between copies: "))
);progn
);and
(setq ss (acet-copym-measure ss p1 p3 d) ;returns selset and base point
p1 (cadr ss)
ss (car ss)
n (+ n 1)
);setq
);cond #5
((= "Array" p2)
(setq ss (acet-copym-array ss p1)
p1 (cadr ss)
ss (car ss)
n (+ n 1)
);setq
);cond #6
(p2
(princ "\nInvalid input.")
);cond #7
);cond close
);while
);defun acet-copym
(defun acet-copym-array ( ss p1 / a )
(initget "Pick Measure Divide")
(setq a (getkword "\nPick (dynamic)/Measure/Divide <Pick>: "))
((or (not a)
(= a "Pick")
);or
(setq a (acet-copym-array-dynamic ss p1))
);cond #1
((= a "Measure")
(setq a (acet-copym-array-measure ss p1))
);cond #2
((= a "Divide")
(setq a (acet-copym-array-divide ss p1))
);cond #3
);cond close
a
);defun acet-copym-array
(defun acet-copym-array-dynamic ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy lst ss2 na a )
(acet-undo-begin)
(setq p2 (getangle p1 "\nSpecify angle <0>: "))
(if p2
(setq p2 (polar p1 p2 1.0)) ;convert angle to a point
(setq p2 (polar p1 0.0 1.0));use default of 0 and convert to point
);if
(setq p3 (polar p1 (+ (angle p1 p2) (/ pi 2.0)) 1.0)
p1 (trans p1 1 0)
p2 (trans p2 1 0)
p3 (trans p3 1 0)
);setq
(acet-ucs-cmd (list "_3p" (trans p1 0 1) (trans p2 0 1) (trans p3 0 1)))
(setq p1 (trans p1 0 1)
p2 (trans p2 0 1)
p3 (trans p3 0 1)
);setq
(setq p2 (acet-copym-getcorner p1 "\nPick a corner point to establish COLUMN and ROW distances: " T)
dx (- (car p2) (car p1))
dy (- (cadr p2) (cadr p1))
lst (list p1)
p4 T
);setq
(acet-sysvar-set
(list
"snapunit" (list (abs dx) (abs dy))
"gridunit" (list (abs dx) (abs dy))
"snapmode" 1
"gridmode" 1
);acet-sysvar-set
(while p4
(setvar "snapmode" 1)
(setvar "gridmode" 1)
;(setq p4 (getpoint p1 "\nPick location for array element or <enter> when done: "))
(setq p4 (acet-ss-drag-move
ss
p1
nil
);acet-ss-drag-move
);setq
((not p4) T);cond #1
((member p4 lst)
(princ "\n*invalid* You already picked that point!")
);cond #2
(T
(setq na (entlast)
lst (cons p4 lst)
);setq
(command "_.copy" ss "" p1 p4)
);cond #3
);cond close
);while
(if na
(setq p1 (trans (getvar "lastpoint") 1 0)
ss2 (acet-ss-new na)
);setq
(setq ss2 ss);setq else
);if
(acet-ucs-cmd (list"_prev"))
(setq p1 (trans p1 0 1))
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-dynamic
(defun acet-copym-getcorner ( p1 msg nozero / flag p2 na )
(while (not flag)
(setq na (entlast))
(command "_.rectang" p1)
(while (wcmatch (getvar "cmdnames") "*RECTANG*")
(princ msg)
(command pause)
);while
(setq p2 (getvar "lastpoint"));setq
(if (not (equal na (entlast)))
(entdel (entlast))
);if
((not nozero)
(setq flag T)
);cond #1
((and (equal (car p1) (car p2) 0.00000001)
(equal (cadr p1) (cadr p2) 0.00000001)
);and
(princ "\n*Points cannot be equal*")
);cond #2
((= (car p1) (car p2))
(princ "\n*X coords cannot be equal*")
);cond #3
((= (cadr p1) (cadr p2))
(princ "\n*Y coords cannot be equal*")
);cond #4
(T
(setq flag T)
);cond #5
);cond close
);while
p2
);defun acet-copym-getcorner
(defun acet-copym-array-measure ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy
ss2 na a n j k m x y
(acet-undo-begin)
(if p2
);if
p1 (trans p1 1 0)
p2 (trans p2 1 0)
p3 (trans p3 1 0)
);setq
p2 (acet-copym-getcorner p1 "\nPick a corner point to establish ROW and COLUMN distances: " T)
p4 T
);setq
(acet-sysvar-set
(list
"snapmode" 1
"gridmode" 1
);acet-sysvar-set
(setq p2 (acet-copym-getcorner p1 "\nOther corner for array fill: " T))
(if (> (car p2) (car p1))
(setq dx (abs dx))
(setq dx (* -1.0 (abs dx)))
);if
(if (> (cadr p2) (cadr p1))
(setq dy (abs dy))
(setq dy (* -1.0 (abs dy)))
);if
(setq k (/ (abs (- (car p2) (car p1)))
(abs dx)
m (/ (abs (- (cadr p2) (cadr p1)))
(abs dy)
k (+ 1 (atoi (rtos k 2 0)))
m (+ 1 (atoi (rtos m 2 0)))
);setq
(setq n 0)
(repeat m ;; rows
(setq y (+ (cadr p1) (* dy n)))
(setq j 0)
(repeat k ;; columns
(setq x (+ (car p1) (* dx j)))
(setq na (entlast))
(if (not (and (= n 0)
(= j 0)
);and
);not
(command "_.copy" ss "" p1 (list x y (caddr p1)))
);if
(setq j (+ j 1));setq
);repeat
(setq n (+ n 1))
);repeat
(if na
);setq
);if
(acet-ucs-cmd (list "_prev"))
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-measure
(defun acet-copym-array-divide ( ss p1 / p2 dx dy ss2 na a n j k m x y p3 )
(acet-undo-begin)
(if p2
);if
p1 (trans p1 1 0)
p2 (trans p2 1 0)
p3 (trans p3 1 0)
);setq
p2 (acet-copym-getcorner p1 "\nOther corner for array fill: " nil)
);setq
(initget 6)
(setq k (getint "\nEnter number of columns: "))
(initget 6)
(setq m (getint "\nEnter number of rows: "))
(setq dx (/ (- (car p2) (car p1)) k)
dy (/ (- (cadr p2) (cadr p1)) m)
);setq
(setq n 0)
(repeat m ;; rows
(setq j 0)
(setq na (entlast))
(= j 0)
);and
);not
);if
);repeat
(setq n (+ n 1))
);repeat
(if na
);setq
);if
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-divide
;Takes a selection set, two points and the distance between
;consecutive copies.
;Returns a list containing a selection set the most
;recent copy and a base point.
(defun acet-copym-measure ( ss p1 p3 d / j n na p2 )
(acet-undo-begin)
(setq j (fix (/ (distance p1 p3) d))
n 1
);setq
(repeat j
(setq p2 (polar p1 (angle p1 p3) (* d n))
na (entlast)
);setq
(if (= n j)
(setq ss (acet-ss-new na))
);if
(setq n (+ n 1))
);repeat
(acet-undo-end)
(list ss p2)
);defun acet-copym-measure
;takes a selection set, two points and the number of copies to
;make of the selection between the two points.
;returns a selection set the most recent copy
(defun acet-copym-divide ( ss p1 p3 j / d n na p2 )
(acet-undo-begin)
(setq d (/ (distance p1 p3) j)
n 1
);setq
(repeat j
na (entlast)
);setq
(if (= n j)
);if
(setq n (+ n 1))
);repeat
(acet-undo-end)
ss
);defun acet-copym-divide
