what I was trying, and which failed was
(setq it (subst (assoc 72 txt) (assoc 72 it) it)
it (subst (assoc 73 txt) (assoc 73 it) it)
it (subst (cons 11 (cdr (assoc 10 it))) (assoc 11 it) it)
(entmod it)
I grabbed a piece of text whose justification as bottom left, and one which I created as middle center.
the first I setq'd as it, and the second as txt.
entupd was tried as well. no joy.
I searched here and found a routine with some vl commands which ran, but the text moved when I ran it.
I don't groc the vl commands yet.
something is telling me I have succeeded with a similar task in the past, but I cannot find my own code, and I begin to doubt my memory. I have a couple hundred text entities I can select programatically very easily, but the would be far more useful to me if they were middle center justified. and this is the first of several files that need "tweeking".
thanks.
roy
