Author Topic: Debugging Attribute  (Read 2532 times)
Glenn R
Debugging Attribute
« on: August 01, 2008, 12:10:53 PM »
May make your debugging life easier.
David Hall
  • Automatic Duh Generator
Re: Debugging Attribute
« Reply #1 on: August 01, 2008, 04:02:24 PM »
« Reply #2 on: August 01, 2008, 08:56:24 PM »
Yes, thanks Glenn. Nice little find.
« Reply #3 on: August 01, 2008, 09:51:56 PM »
great link Glenn
Glenn R
« Reply #4 on: August 02, 2008, 04:53:57 AM »
Taken from the news channel when you start Visual Studio 2008 BTW...first link yesterday. It's very interesting what you can find on it actually.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: August 02, 2008, 09:37:56 AM »
Great find Glenn,
Another useful attribute is ;
[System.Diagnostics.Conditional()]
example;
    [System.Diagnostics.Conditional("DEBUG")]
    internal static void DEBUG_PRINT_VAL(object o)
      DEBUG_PRINT_VAL(string.Empty, o);
    internal static void DEBUG_PRINT_VAL(string varname , object o)
      AcAp.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(varname + o.ToString());
    [CommandMethod("test")]
    public static void test()
      Point3d A = Point3d.Origin;
      //if DEBUG is not defined, the compiler will remove this call
      DEBUG_PRINT_VAL(A);
« Last Edit: August 02, 2008, 09:40:58 AM by Daniel »
