Author Topic: Zoom and Objects Disappear (visually)  (Read 17477 times)
Re: Zoom and Objects Disappear (visually)
« Reply #30 on: October 24, 2007, 11:11:28 AM »
Ron, are you on subscription?  If so, log it w/ adesk
We are on subscription. I will log it...thanks.
« Reply #31 on: October 24, 2007, 11:14:47 AM »
I zoom with the wheel.
Sounds like and MS vs hardware issue.  What happens when you use the zoom command??
I'll have to get back to you on that...it's hard for me to type in "Z" to zoom when the functionality is built into the mouse wheel.  :-D
Thanks for the reply.
Ron
CADaver
« Reply #32 on: October 24, 2007, 11:23:05 AM »
Ron
I understand, the stinkin' wheel is just way too easy.   But I've had issues with hardware display instructions getting boggled up in AutoCAD.  When we chased it down it was an old mouse driver causing the trouble.
« Reply #33 on: October 24, 2007, 11:26:28 AM »
Ron
Randy,
What do you mean by "I've had issues with hardware display instructions" ... are you referring to the same issue I'm seeing here (disappearing objects..etc)?
CADaver
« Reply #34 on: October 24, 2007, 05:42:55 PM »
Ron
Randy,
   I've seen screens go blank and require a drawing close to restore (which may be your issue), I've seen crosshairs go haywire and duplicate themselves all over the screens, I've seen large shaded files just crash, and a few other anomalies.  Most of which were resolved by getting newer mouse drivers (or newer mice and drivers) or newer video cards.
   The only one that remains a “regular” issue is crashing very large models that have been shaded.  There seems to be some magic point where a hardware driven display change (wheel zoom or pan or 3dorbit) just can’t handle the load.  For R2002 that was around a files of twenty megabytes or more (XREF’d or otherwise) that had been open and edited for some time.  I first thought it was a memory issue, but that didn’t help, neither did virtual memory increases or paging or anything else we tried.  It got better with each release, so far in 2008 I haven’t been able to make it crater, even with fifty megabyte files
« Reply #35 on: October 24, 2007, 05:49:01 PM »
"I've seen screens go blank and require a drawing close to restore (which may be your issue), I've seen crosshairs go haywire and duplicate themselves all over the screens, I've seen large shaded files just crash, and a few other anomalies.  Most of which were resolved by getting newer mouse drivers (or newer mice and drivers) or newer video cards."
Interesting...I see this fairly regularly. I'm going to have to drive the mouse drivers. Thanks for the input.
Ron
craigr
« Reply #36 on: October 24, 2007, 05:50:29 PM »
50MB AutoCad files!!!!
I've never seen any NEAR that size!
craigr
Josh Nieman
« Reply #37 on: October 24, 2007, 05:52:23 PM »
Well boy howdy... maybe some of the problems I've had with my model files is mouse drivers then.  Next time I'm on a particularly problmeatic file, maybe I'll take out the razer, and put in the Dell mouse and see if it still happens...  *mental note*
CADaver
« Reply #38 on: October 24, 2007, 06:04:53 PM »
craigr
Now you have.  Some of the pipe models in the racks are around fifty, some of the vessel models are well over forty.  That view represents probably a gig of data and that's just half of one out of three adjacent units.
« Reply #39 on: October 24, 2007, 06:06:44 PM »
craigr
Holds up hand "I have, and then some".
« Reply #40 on: October 24, 2007, 06:13:38 PM »
Slightly back on topic ... there's only a remote chance this will change anything, but just maybe ...
(defun c:HiRes ( / _HiRes )
    (defun _Hires ( )
        (foreach pair
           '(   (regenmode     . 1)
                (hideprecision . 1)
                (facetres      . 10)
                (facetratio    . 1)
                (dispsilh      . 1)
            (setvar (car pair) (cdr  pair))
        (command ".viewres" "_yes" 20000)
    (setvar 'cmdecho 0)
        (   (eq 1 (getvar "tilemode"))
            (_HiRes)
        (   (eq 1 (getvar "cvport"))
            (_HiRes)
                (   (< 1 (length (vports)))
                    (command ".mspace")
                    (_HiRes)
                    (command ".pspace")
        (   t
            (_HiRes)
            (command ".pspace")
            (_HiRes)
            (command ".mspace")
    (setvar 'cmdecho 1)
CADaver
« Reply #41 on: October 24, 2007, 06:43:16 PM »
craigr
Then there's this
