I have done a couple of things....and this why I am puzzled....first ....
windows is setup to see hidden files and folders....so you would think that under
C:\Documents and Settings\Username\Application Data\Autodesk\AutoCAD\Recent...there would be a template folder...not here....so I did a wildcard search *.* in the whole Recent folder....nothing...
C:\Documents and Settings\Username\Local Settings\Application Data....no Autdesk folder
C:\Documents and Settings\Username\Templates.....no Autodesk folder....
so I went back to C:\Program Files\Autodesk Architectural Desktop 3\Template and there is no tpg.dwt to be found....
so I went into Autocad "Options\Files\Drawing Template File Location....nothing there...but 4 autocad files....
my problem is this....when someone double clicks the autocad icon on their desktop....a file is created with the same layer combinations....which is weighing down the file and then they have to be purged....I am trying to clean this up from the get go....and fix other things with in this mysterious template file....
