Code Red => AutoLISP (Vanilla / Visual) => Topic started by: GDF on February 25, 2006, 07:34:13 PM
Title: ObjectDBX Plotting
Post by: GDF on February 25, 2006, 07:34:13 PM
ObjectDBX Plotting. So why can't this be done? If not I wish Autodesk had a way to do it.
Gary
Title: Re: ObjectDBX Plotting
Post by: Kerry on February 25, 2006, 07:43:49 PM
Any particular reason why you want to use DBX for Plotting Gary ?
Post by: whdjr on February 26, 2006, 02:58:05 PM
Gary,
What I was told from someone (I think it was on the AUGI Lisp Guild) a while back was the only way to use ObjectDBX to plot is to have a Liscenced version of ObjectDBX, not what we use it our Acad versions.
Post by: GDF on February 27, 2006, 10:52:25 AM
Just looking for a faster way to plot. We are using Acroplot for plotting and it runs from a script. Sets sdi to 1 a it is slooooooow.
From what I have seen from playing with objectdbx, its faaaaaaaaaaast.
Gary
Post by: CAB on February 27, 2006, 11:20:04 AM
Not sure if this will help you speed things up but there was a feature of PlotTabs where you can call it without the dialog box.
http://www.theswamp.org/forum/index.php?topic=1916.msg37939#msg37939
There were many changes to the routine and this feature may not be up to date with all the options.
i have not tested after the many updates to the routine as no one seemed to use that feature.
It's intent was to be able to call PlotTabs from a script or other lisp routine.
Post by: GDF on February 27, 2006, 11:52:38 AM
Allen
Thanks for the heads up. I will check into it.
I am just supprised that AutoCAD does not have a builtin objectdbx plotting.
I want to plot fast, without the need to open up each drawing. We only use
one layout per drawing.
Gary
Post by: Crank on February 27, 2006, 02:06:11 PM
Isn't 'background plotting' using objectdbx?
Post by: whdjr on February 27, 2006, 02:43:27 PM
Gary,
Have you tried using the publish command?  Ya know..."just set it and forget it"... :-)
Post by: GDF on February 27, 2006, 03:29:38 PM
I'm going to have to get back to you on the publish command. I think we always want the output to be in a pdf file.
No one here in our office has used publish.
Gary
Post by: whdjr on February 27, 2006, 03:39:24 PM
Gary,
If you have a PDF driver installed you can then make you a .pc3 file for AutoCad to use and therefore you can publish to it.
Post by: GDF on February 27, 2006, 05:13:44 PM
I will look into this. I am not the plotting guy in our office. I will get him to test out all of the tips.
Gary
