Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Vikram on February 01, 2021, 05:05:55 AM
Title: Lisp or method to break circle in two or more parts
Post by: Vikram on February 01, 2021, 05:05:55 AM
I need a lisp or a method to break the circle in 2 or more parts. I used to use AutoCAD previously so Lee Mac's circle break lisp was very helpful for me. Now my company have started using ProgeCAD/IntelliCAD and that lisp is not compatible with that lisp as it partially supports visual functions. You can see the combability on this link. https://www.progesoft.com/products/progecad-professional/manual?mp=understanding-autocad-compatibility/programming-progecad/understanding-autolisp-compatibility (https://www.progesoft.com/products/progecad-professional/manual?mp=understanding-autocad-compatibility/programming-progecad/understanding-autolisp-compatibility)
Whenever I use cbrk command and select the two points to break my IntelliCAD crashes.
I have attached Lee Macs lisp to break circle.
 My project is stuck due to this! :sick:
Title: Re: Lisp or method to break circle in two or more parts
Post by: Dahzee on February 01, 2021, 05:55:29 AM
Hi Vikram,
Not sure if the below will work in Progecad, but it uses native commands, so could work.
"If you convert a circle to a polyline and then explode it, you're left with 2 arcs -- a top arc and a bottom arc. If you select both arcs, you can drag the left and right endpoints of those arcs to the points on the circle where you wanted it broken"
Post by: d2010 on February 01, 2021, 07:59:48 AM
RE: "If you convert a circle to a polyline and then explode it, you're left with 2 arcs -
You see my Demo. Circle2Polyline .
(Defun dfn_cmd_circlebreak(en1 /  cls nop xlm p obj ctr dia occ prv ra3 old)  (asserte "A232")
  (setq;|a13812|;
nam (car en1)
xlm (entget nam)
p (cadr en1)
old (entlast)
obj (cdr (assoc 0 xlm))) (if (=  obj "CIRCLE") (progn  (setq;|a13986|;
occ (cdr (assoc 62 xlm))
ra3 (cdr (assoc 40 xlm))
ctr (cdr (assoc 10 xlm))
xlm (if (/= occ nil) (subst (cons 62 11) (cons 62 occ) xlm) (subst (cons 62 12) nil xlm))
xlm (subst (cons 40 (* ra3 0.78)) (cons 40 ra3) xlm)) (entmakex (cdr xlm)))) (if (/= old (entlast)) (progn  (setq;|a14372|;
dia (* 2.0 ra3)
cls (dfn_getx_readkey "[YN]" "Pline-toClose(y.yes)(n.no): ")) (if (=  cls "Y") (command "_.break" p (polar p (/ kpi 4) 0.001) "_.pedit" p "_y" "_c" "_x") (command "_.break" p (polar p (/ kpi 4) 0.001) "_.pedit" p "_y" "_x"))))
You execute (dfn_cmd_circlebreak (entsel)) at line-command.
The "0.78" is decrease of radius. You replace with 1.0 for same-radius with circle/s.
For quickUnderstand you replace ~cls (dfn_getx_readkey "[YN]" ~ with
(setq cls "Y"),.
Post by: Vikram on February 01, 2021, 11:53:39 AM
Thanks for your time appreciate your help but It dint work on ProgeCAD. But making it polyline and breaking it worked for me.
Post by: BIGAL on February 01, 2021, 05:40:34 PM
The other alternative is 1st principals know radius, know centre pt, erase circle, make an arc angle 0-PI, 2nd arc pi-2*pi using command or entmake should work with any cad.
