Code Red => AutoLISP (Vanilla / Visual) => Topic started by: ribarm on April 27, 2020, 09:39:52 AM
Title: ---={ Challenge }=--- Find inverse function
Post by: ribarm on April 27, 2020, 09:39:52 AM
Hi all...
Long time no challenges asked... This one is really tough and I think that IMHO is still impossible to be solved...
Now to get to the point. Through long period of time I coded in ALISP and very often I came into situation where I have to use math or some programming skills to write and translate real formula or pseudo code to ALISP defined function either by using (defun), (lambda) - defun-q I use rarely... Now if you take this simple formula A=B+3 and you translate it into this :
(defun a ( b )
  (+ b 3)
Result of (a 2) would be 5... That's fine... But what if formula is very complex and not so evident and you still have USUBR a which will operate the same (a 2) => 5... Now the goal of this challenge is to get USUBR ainv which will give (ainv 5) => 2 ...
So you have defined function - it could be as simple as (chr 65) => "A" ... Now we need to get (ascii) function from (chr), so that (chrinv "A") => 65 - the same as (ascii "A") => 65...
Let's see if some eminent person like Lee Mac, or MP can do it... For a start I am narrowing things to only pure math and math formula where you define function with 1 number argument and 1 return as number and the goal is to get inverse function also with 1 number argument and 1 return as number...
Thanks for reply in advance...
Regards, M.R.
Title: Re: ---={ Challenge }=--- Find inverse function
Post by: JohnK on April 27, 2020, 10:47:13 AM
I posted a few routines called HOOK and LET many years ago that was related to this subject. -i.e. should be simple enough to build a function to construct functions.
  1. (defun hook (name arg func)
  2.   (eval (list 'defun name (list arg) func)))
  3.
  4. (hook 'foo 'arg '(+ arg 3))
  5. (hook 'fooinv 'arg '(- arg 3))
Command: (hook 'foo 'arg '(+ arg 3))
FOO
Command: (hook 'fooinv 'arg '(- arg 3))
FOOINV
Command: (foo 2)
5
Command: (fooinv 5)
2
Post by: ribarm on April 27, 2020, 11:26:57 AM
My simple solution considers involving global variables like *r*
  1. (defun f ( a / b )
  2.   (setq b (+ a a (/ a 2.0) (expt a 2))) ; place your formula with a
  3.   (setq *r* (- b a))
  4.   b
  5. )
  6.
  7. (defun finv ( b )
  8.   (- b *r*)
  9. )
  10.
But this is not what I was looking for in generalized terms... This is just math approach like I proposed in my finishing statement, but the problem is (chr 65) => "A" and (chrinv "A") => 65 in general
Post by: VovKa on April 27, 2020, 11:50:03 AM
(f 2)
(finv 9)
(finv 26)
(f 4)
Post by: ribarm on April 27, 2020, 12:07:44 PM
(f 2)
(finv 9)
(finv 26)
(f 4)
I don't get it... What do you want to say?
Post by: JohnK on April 27, 2020, 12:20:58 PM
I'm very confused by this thread.
Post by: ribarm on April 27, 2020, 12:50:02 PM
(f 2)
(finv 9)
(finv 26)
(f 4)
I see the point... (finv) is not real inverse function of (f), but it's attempt to make connection between user defined function and return value... It works as inverse only if (f) is executed firstly and BTW. If (f) was never executed *r* would be nil and therefore and (finv) would break with error and fail...
Post by: ribarm on April 27, 2020, 12:56:36 PM
No, the topic is very useful if solution is to be found... It looks complicated, but in fact solution should be simple - someone should be able to create USUBR of already defined USUBR in the way that it operates reversed then it should... No need for formulas - just crack of foo to fooinv...
Post by: VovKa on April 27, 2020, 01:32:06 PM
I see the point...
yep
that's what i've meant
Post by: VovKa on April 27, 2020, 01:33:41 PM
(setq f_backup f)
(defun f (a) (setq *r* a) (f_backup a))
(defun f_inv () *r*)
Post by: ribarm on April 27, 2020, 01:33:52 PM
Here is another one based on *r*... Maybe this one is better...
  2.   (setq b (chr a)) ;; Place your formula with a here...
  3.   (setq *r* (list b a))
  4.   b
  5. )
  6.
  8.   (if (equal b (car *r*))
  9.     (cadr *r*)
  10.   )
  11. )
  12.
(f 65) => "A"
(finv "A") => 65
(f 85) => "U"
(finv "U") => 85
Also (f) must be firstly initialized for (finv) to work as desired...
Post by: Lee Mac on April 27, 2020, 01:47:07 PM
This is impossible in general.
A simple example would be attempting to write an inverse hashing function.
Post by: VovKa on April 27, 2020, 01:59:51 PM
i guess Marko just wants to know with what argument a function was called
Post by: ribarm on April 27, 2020, 02:00:32 PM
I was not referring to inverse function of complex function that is composed of other functions, just straight forward function with single formula and single argument and single return...
Post by: ribarm on April 27, 2020, 02:02:09 PM
Not exactly... That among other things, but I really want inverse function of function...
Post by: JohnK on April 27, 2020, 02:12:53 PM
As in: vl-bb-ref/set?
Still very confusing!
Post by: VovKa on April 27, 2020, 02:18:11 PM
it is also possible that Marko has a compiled lisp and wants to know what is happening inside it during the execution
Post by: ribarm on April 27, 2020, 02:40:30 PM
No, I have no particular needs... I just want this solved as challenge and like I said I often use formulas inside LISPS and I wanted to know is there a way to reverse formula... Not to bang my head by using arithmetics and algebra I just guessed that there must be simple way through LISP defuns and by using PC (AutoCAD)...
Post by: MP on April 27, 2020, 03:04:14 PM
Not to bang my head by using arithmetics and algebra ...
If I understand what you're saying the arithmetics / algebra would instead be delegated to a non trivial, clever, auto heuristic function - authoring the adaptive arithmetics and algebra therein would dwarf the effort to write hundreds of specific 'inverse functions'.
tl;dr: While I salute the notion can't see it coming to fruition ... then again it's likely I don't understand the intent.
Post by: ribarm on April 27, 2020, 03:42:05 PM
With all respect to those that wrote inverse functions by using math or other techniques, I still can't imagine that with using PC there is no way to reverse operations of straight forward function... Simply if you have a=b+2, you have to write b=a-2... I imagine that for every input there is output in every formula... Isn't it true that every function with formula can be represented as curve in XY coordinate system... So can AutoCAD generate that curve and then just swap XY to YX and read that curve from YX as if it's function in XY (so formula is reversed)... Now outputs would become inputs and inputs outputs if we are to get values, but solution is just formula of that curve but in YX... In other words when you look it all just in XY, there is formula and curve and there should be formula for curve symetrical to function y=x... Shouldn't AutoCAD be capable of getting that curve function, or even there shouldn't even be need for getting formula - there is initial formula and corresponding Y^-1 (but no need for that - just normal Y function of curve is enough), so for every y coordinate there is x one read diractly from that curve...
Post by: VovKa on April 27, 2020, 03:58:01 PM
try it with a parabola :)
Post by: ribarm on April 27, 2020, 04:02:25 PM
With functions like (chr) - (ascii) the principle is the same just in list form built in initial function for ex. (chr)... For every number 65 there is "A" letter and opposite for every letter there is number - isn't that list already built-in (chr) function... So can list be reversed ((num letter) (65 "A") (85 "U") ...) and this is read as ((letter num) ("A" 65) ("U" 85) ...)... Basically we just need (defun invres ( chrlst ) (mapcar '(lambda ( x ) (list (cadr x) (car x))) chrlst))... (defun chrinv ( a ) (cadr (assoc a (invres chrlst))))
Post by: MP on April 27, 2020, 04:05:11 PM
That would be a pain in the latus rectum.
Post by: Stefan on April 27, 2020, 04:47:07 PM
It's only possible if the function is bijective, that means for each x there is only one y and vice-versa. Linear functions are like this.
So you know the f(x) function (not really the expression of the function, but only it's output) and you want to solve the x in y=f(x) .
Plot the function as spline with (x, f(x)) points and draw a horizontal Xline at (0,y,0). If you are lucky and it intersect the plot, the inverse is the x coordinate of the intersection.
Of course, the spline is finite, from a,f(a) to b,f(b). If it doesn't intersect, change the interval.
Post by: Grrr1337 on April 27, 2020, 04:57:12 PM
Similar thought here, if the returns are exponentially growing or decaying, pseudocode -
  1. (defun f ( a )
  2.   (* 0.25 (+ 10 (* a a a) (* 2 (+ 5 a))))
  3. )
  4.
  5.
  6. _$ (mapcar 'f '(1 2 3 4 5 6 7 8 9 10)) ; observation
  7. (5.75 8.0 13.25 23.0 38.75 62.0 94.25 137.0 191.75 260.0)
  8.
  9. (defun fE ( a )
  10.   ; replicate 'f as exponential
  11.   ; ..
  12. )
  13.
  14. _$ (mapcar 'fE '(1 2 3 4 5 6 7 8 9 10)) ; observation and modify till reaching the results of 'f
  15. (5.75 8.0 13.25 23.0 38.75 62.0 94.25 137.0 191.75 260.0)
  16.
  17. (defun fEinv ( b )
  18.   ; write out inverse exponential for 'fE
  19. )
  20.
  21. _$ (mapcar 'fEinv '(5.75 8.0 13.25 23.0 38.75 62.0 94.25 137.0 191.75 260.0))
  22. '(1 2 3 4 5 6 7 8 9 10)
This (https://www.chilimath.com/lessons/advanced-algebra/inverse-of-exponential-function/) might be of help.
But I don't think this approach would handle 'parabola jumps' - for special cases like: (if (< 5 a 10) (setq a 1)).
The ultimate would be machine-learning approach, collecting all of the data and acting from there with a tremendous amounf of if statements.  :uglystupid2:
EDIT: I mean if you want to inverse something that you don't know how its defined, the first step would be to attempt to replicate the definition and then come-up with a inversion.
Post by: Grrr1337 on April 27, 2020, 05:53:22 PM
Here is some initial code related to the above comment :
  1. (defun f ( a )
  3. )
  4.
  5. ;|
  6. (f 4.5)
  7. >> 30.0313 ; the result we're looking for
  8. (fooInv f 4.5 '(1 2 3 4 5 6 7 8 9 10))
  9. >> 29.6683
  10. (fooInv f 4.5 '(1 2 3 4.3 4.8 5 6 7 8 9 10))
  11. >> 29.9508
  12. (fooInv f 4.5 '(1 2 3 4 4.5 5 6 7 8 9 10)) ; here the actual 'b' arg is suppled for running, hence (f b) is invoked and that makes 'fooInv' pointless
  13. >> 30.0312 ; close enough
  14. _$ (fooInv f 4.5 '(1 4.5 100))
  15. >> 30.0313
  16. |;
  17. (defun fooInv ( f b args / L r )
  18.   (cond
  19.     ( (vl-some 'not (list f b args)) (prompt "\nInvalid arguments supplied.") )
  20.     (
  21.       (progn
  22.         (and
  23.           (not (vl-some (function (lambda (x) (equal b x 1e-4))) args))
  24.           (prompt
  25.             "\nThe argument 'b' is not contained within 'args',
  26.            \nwhich may lead to not enough accurate result
  27.            \nalthough that would make this sub useless."
  28.           )
  29.         ); and
  30.         nil
  31.       ); progn
  32.     )
  33.     ( (vl-catch-all-error-p (vl-catch-all-apply (function (lambda nil (setq L (mapcar '(lambda (x) (list x (f x) 0)) args))))))
  34.       (prompt "\nThe supplied function 'f' errors out on some of the provided arguments.")
  35.     )
  36.     (
  37.       (vl-catch-all-apply
  38.         (function
  39.           (lambda ( / spl xl )
  40.             (and
  41.               (setq spl (AddSpline L))
  42.               (setq xl (AddXline (list (float b) 0.0 0.0)))
  43.               (setq r (cadr (vlax-invoke spl 'InterSectWith xl acExtendNone)))
  44.             )
  45.             (mapcar 'vla-Delete (list spl xl))
  46.           )
  47.         )
  48.       )
  49.     )
  50.   ); cond
  51.   r
  52. ); defun
  53.
  54.
  55.
  56.
  57. (defun AddSpline ( 3DPtLst / r )
  58.   (cond
  59.     ( (not (vl-consp 3DPtLst)) )
  60.     ( (not (vl-every 'vl-consp 3DPtLst)) )
  61.     ( (progn (setq 3DPtLst (mapcar '(lambda (x) (if (= 2 (length x)) (append x '(0.0)) x)) 3DPtLst)) nil) )
  62.     (
  63.       (setq r
  64.           (vlax-safearray-fill
  65.             (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length (apply 'append 3DPtLst)))))
  66.             (apply 'append 3DPtLst)
  67.           )
  68.           (vlax-3d-point '(0. 0. 0.))
  69.           (vlax-3d-point '(0. 0. 0.))
  70.         )
  71.       ); setq r
  72.     )
  73.   ); cond
  74.   r
  75. ); defun
  76.
  77. ; (AddXline (getpoint))
  78. (defun AddXline ( p )
  79.     p (mapcar '+ '(0.0 1.0 0.0) p)
  80.   )
  81. )
Post by: JohnK on April 27, 2020, 10:03:32 PM
> ("A" 65) ("U" 85)
That's an assocation list (or data structure). What's wrong with that? You don't need to reorder/reverse/clean/etc. the list at all; why would you?! The access to a list strucutre (via assoc, car, cdr, etc. is far, far faster then anything you could ever build). Frankly, people spend far too much time messing with lists; your functions should *NOT* care if the list is full of "nil" and/or "0's". And most times, your list doesn't need to be in ascending or alphabetical order; just let the built-in tools like ASSOC find them for you.
Post by: ribarm on April 28, 2020, 12:44:48 AM
@Grrr, very well coded... Thanks for your functions...
I actually modified it to represent fooInv like it should... (if you read my comment and Stefan's about inversion)
  1. (defun f ( a )
  3. )
  4.
  5. (defun _sin ( x / __sin k r ) ;; x - angle in radians
  6.
  7.   (defun __sin ( x n / factorial )
  8.
  9.     (defun factorial ( n )
  10.       (if (/= (float n) 1.0) (* (float n) (factorial (1- n))) 1.0)
  11.     )
  12.
  13.     ((if (= (rem n 2) 0) + -) (/ (expt x (1+ (* 2 n))) (factorial (1+ (* 2 n)))))
  14.   )
  15.
  16.   (setq k 0 r 0.0)
  17.   (while (<= (setq k (1+ k)) 200) ;; Tyler order - 200 expressions
  18.     (setq r (+ r (__sin x k)))
  19.   )
  20.   (+ x r)
  21. )
  22.
  23. ;|
  24. (f 1)
  25. >> 5.75 ; minimal value of chosen interval
  26. (f 4.5)
  27. >> 30.0313 ; the result we're looking for
  28. (f 10)
  29. >> 260.0 ; maximal value of chosen interval
  30. (fooInv f 30.0313) ; a=1, b=10, n=9 ['(1 2 3 4 5 6 7 8 9 10)]
  31. >> 4.5231
  32. (fooInv f 30.0313) ; a=1, b=10, n=18 ['(1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 8.5 9 9.5 10)] ; here the actual 'b' arg is suppled for running, hence (f b) is invoked and that makes 'fooInv' near exact function
  33. >> 4.5 ; exactly
  34. (fooInv f 30.0313) ; a=1, b=8, n=2 ['(1 4.5 8)]
  35. >> 4.50001 ; close enough
  36.
  37. Using fooInv between min and max values of looking interval
  38. (fooInv f 50.0) ; a=1, b=10, n=9 ['(1 2 3 4 5 6 7 8 9 10)]
  39. >> 5.51922
  40. (fooInv f 50.0) ; a=1, b=10, n=99
  41. >> 5.52816 ; this result should be more accurate
  42.
  43. Proof
  44. (f 5.52816)
  45. >> 50.0 ; exactly
  46. |;
  47.
  48. ;|
  49. (_sin (/ pi 2.0))
  50. >> 1.0
  51. (rtos (/ pi 2.0) 2 20)
  52. "1.570796326794896"
  53. Interestingly I have this number from here : http://ronleigh.com/autolisp/ales15.htm
  54. 3.1415926535897932385 / 2 = 1.57079632679489661925
  55. (rtos (fooInv _sin 1.0) 2 20) ; a=1.570796326794891, b=1.570796326794901, n=10000
  56. Command: (rtos (fooInv _sin 1.0) 2 20)
  57. Specify minimal X value of looking interval : 1.570796326794891
  58. Specify maximal X value of looking interval : 1.570796326794901
  59. Specify segmentation of looking interval <100> : 10000
  60. "1.570796326794900" - but there is probably mistake as 00 were repeating at the end (it looks like (rtos) rounded last 6 digit up to 10) :
  61. Command: (rtos 1.57079632679489661925 2 20)
  62. "1.570796326794896" from this output it looks that that isn't the case...
  63. => PI = (rtos (* 2.0 1.570796326794900) 2 20) >> "3.141592653589800" - but there is probably mistake as 00 were repeating at the end
  64. |;
  65.
  66. (defun fooInv ( f b / args genargslst AddSpline AddLine L r )
  67.
  68.
  69.   (defun genargslst ( / a b n dx k r )
  70.     (setq a (getreal "\nSpecify minimal X value of looking interval : "))
  71.     (setq b (getreal "\nSpecify maximal X value of looking interval : "))
  72.     (initget 6)
  73.     (setq n (getint "\nSpecify segmentation of looking interval <100> : "))
  74.     (if (null n)
  75.       (setq n 100)
  76.     )
  77.     (while (= n 1)
  78.       (prompt "\nYou specified number 1 - that's not allowed...")
  79.       (initget 6)
  80.       (setq n (getint "\nSpecify segmentation of looking interval <100> : "))
  81.       (if (null n)
  82.         (setq n 100)
  83.       )
  84.     )
  85.     (setq dx (/ (- b a) (float n)))
  86.     (setq k -1)
  87.     (repeat (1+ n)
  88.       (setq r (cons (+ a (* dx (setq k (1+ k)))) r))
  89.     )
  90.     (reverse r)
  91.   )
  92.
  93.   (defun AddSpline ( 3DPtLst / r )
  94.     (cond
  95.       ( (not (vl-consp 3DPtLst)) )
  96.       ( (not (vl-every 'vl-consp 3DPtLst)) )
  97.       ( (progn (setq 3DPtLst (mapcar '(lambda ( x ) (if (= 2 (length x)) (append x '(0.0)) x)) 3DPtLst)) nil) )
  98.       (
  99.         (setq r
  100.             (vlax-safearray-fill
  101.               (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length (apply 'append 3DPtLst)))))
  102.               (apply 'append 3DPtLst)
  103.             )
  104.             (vlax-3d-point '(0. 0. 0.))
  105.             (vlax-3d-point '(0. 0. 0.))
  106.           )
  107.         ); setq r
  108.       )
  109.     ); cond
  110.     r
  111.   ); defun
  112.
  113.   (defun AddLine ( p1 p2 )
  114.       p1 p2
  115.     )
  116.   )
  117.
  118.   (setq args (genargslst))
  119.   (cond
  120.     ( (vl-some 'not (list f b args)) (prompt "\nInvalid arguments supplied.") )
  121.     (
  122.       (progn
  123.         (and
  124.           (not (vl-some (function (lambda ( x ) (equal b (f x) 1e-2))) args))
  125.           (prompt
  126.             "\nThe argument 'b' is not contained within f(x),
  127.             \nwhich may lead to not enough accurate result
  128.             \nalthough that would make this sub useless.
  129.             \n"
  130.           )
  131.         ); and
  132.         nil
  133.       ); progn
  134.     )
  135.     ( (vl-catch-all-error-p (vl-catch-all-apply (function (lambda nil (setq L (mapcar '(lambda ( x ) (list x (f x) 0)) args))))))
  136.       (prompt "\nThe supplied function 'f' errors out on some of the provided arguments.")
  137.     )
  138.     (
  139.       (vl-catch-all-apply
  140.         (function
  141.           (lambda ( / spl li )
  142.             (and
  143.               (setq spl (AddSpline L))
  144.               (setq li (AddLine (list (car args) (float b) 0.0) (list (last args) (float b) 0.0)))
  145.               (setq r (car (vlax-invoke spl 'InterSectWith li acExtendNone)))
  146.             )
  147.             (mapcar 'vla-Delete (list spl li))
  148.           )
  149.         )
  150.       )
  151.     )
  152.   ); cond
  153.   r
  154. ); defun
  155.
Post by: ribarm on April 28, 2020, 09:10:29 AM
As you can see, I tried to get lastly digits of number PI by using custom (_sin) function based on Tyler order and this method - inverse function - that would be arcsin... But unfortunately there is probably some mistake - look into comments of my code I posted in previous reply...
[EDIT : Probably (rtos) rounded last digit which is initially 6 to up 10, so that result is correct, but not what I wanted...]
[EDIT : It seems that (rtos) is fine : (rtos 1.57079632679489661925 2 20) => "1.570796326794896"]
Post by: jtoverka on April 30, 2020, 12:03:58 PM
How complex are you willing to go? A two variable function can yield the same result with multiple inputs.
