Code Red => AutoLISP (Vanilla / Visual) => Topic started by: dubb on November 04, 2019, 12:36:20 PM
Title: How save a file as unicode
Post by: dubb on November 04, 2019, 12:36:20 PM
When creating a tab delimited text file I
(princ "A\tB\tC\n1\t2\t3 as a .csv file. However when I open it up in excel it doesn't recognize it. So then I found out how to save the file as unicode using notepad. After doing so, it open up correctly in excel.
How do I saveas or make the file a unicode type file in autolisp without actually writing unicode characters?
Title: Re: How save a file as unicode
Post by: Vaidas on November 04, 2019, 01:30:19 PM
Try to convert using iconv https://en.wikipedia.org/wiki/Iconv
Post by: Lee Mac on November 04, 2019, 01:34:15 PM
I'm not sure that this will solve the problem of Excel recognising the file, but nevertheless this thread (https://www.theswamp.org/index.php?topic=39617.0) demonstrates how to read/write Unicode files.
Post by: dubb on November 04, 2019, 06:49:31 PM
You know. I Googled it and led to a similar post. It was a matter of figuring out  how it was used. But this worked.  Thanks for sharing.
Post by: BIGAL on November 04, 2019, 07:34:36 PM
Have you tried this way using the chr method.
(setq fo (open (setq fname "d:\\acadtemp\\testab.txt") "w"))
(write-line (strcat "a" (chr 9) "b" (Chr 9) "c") fo)
(write-line (strcat "a" (chr 9) (chr 9) "b" (Chr 9) (chr 9) "c") fo)
(close fo)
a   b   c
a      b      c
(write-line (strcat "f" (chr 9) (chr 9) "g" (Chr 9) (chr 9) "h" (chr 13) "d" (chr 9) (chr 9) "e") fo)
a   b   c
a      b      c
f      g      h
d      e
Post by: dubb on November 05, 2019, 11:21:22 AM
I haven't. But it looks way complicated. The actual string I'm writing contains a lot of text. Looks like I would have to convert each letter using this method. That's interesting though, I might have use for it.
(close fo)
a   b   c
a      b      c
a   b   c
a      b      c
f      g      h
d      e
Post by: 57gmc on November 05, 2019, 03:39:31 PM
Al isn't converting any text. 9 is the ascii code for tab. He's just using (chr 9) instead of "\t".
Post by: Lee Mac on November 05, 2019, 03:59:42 PM
As such, there will be no difference in the outcome since:
  1. _$ (= "\t" (chr 9))
  2. T
Post by: 57gmc on November 05, 2019, 04:12:33 PM
  2. T
Good point. But since Al is using writeline instead of princ, that should produce the proper format for a txt file, correct?
Post by: BIGAL on November 05, 2019, 08:16:03 PM
Thought I better test and worked in excel, recognised the tabs.
A Bit more
(close fo)
(command "start" "Excel d:\\acadtemp\\testab.txt")
