Code Red => AutoLISP (Vanilla / Visual) => Topic started by: HasanCAD on October 20, 2019, 11:10:07 AM
Title: How to check if list a part of list?
Post by: HasanCAD on October 20, 2019, 11:10:07 AM
Hi all
How to check if list pt a part of list lst
(setq lst ((505.434 294.582 0.0) (630.636 386.387 0.0) (755.837 478.191 0.0)))
(setq pt (505.434 294.582 0.0))
Title: Re: How to check if list a part of list?
Post by: kpblc on October 20, 2019, 11:36:54 AM
(member pt lst)
Post by: Lee Mac on October 20, 2019, 11:44:54 AM
If you need some tolerance -
  1. (vl-some '(lambda ( x ) (equal x pt 1e-8)) lst)
Post by: well20152016 on October 20, 2019, 06:55:10 PM
  1. (vl-remove-if-not '(lambda (x) (equal pt x 0)) lst)
Post by: HasanCAD on October 21, 2019, 04:50:47 AM
Working perfect
Thanks All
Post by: MP on October 21, 2019, 08:58:57 AM
Using vl-remove-if-not will realize a HUGE unnecessary performance penalty.
List length 1024:
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...)......1188 / 9.26 <fastest>
    (VL-REMOVE-IF-NOT (QUOTE (LAMBDA (X)...).....11000 / 1.00 <slowest>
List length 8192:
Elapsed milliseconds / relative speed for 8192 iteration(s):
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).......375 / 56.00 <fastest>
    (VL-REMOVE-IF-NOT (QUOTE (LAMBDA (X)...).....21000 / 1.00 <slowest>
Post by: kpblc on October 21, 2019, 10:15:37 AM
  1. ((lambda (/ i)
  2.    (setq i   '(0. 0. 0.)
  3.          lst nil
  4.          ) ;_ end of setq
  5.    (repeat 8192 (setq lst (cons (setq i (mapcar (function +) i '(0.25 0.25 0.25))) lst)))
  6.    (princ)
  7.    ) ;_ end of lambda
  8.  )
  9. (setq pt '(30. 30. 30.))
  10. (benchmark '((member pt lst)
  11.              (vl-some '(lambda (x) (equal x pt 1e-8)) lst)
  12.              (vl-remove-if-not '(lambda (x) (equal pt x 0)) lst)
  13.              )
  14.            ) ;_ end of benchmark
  15.
  16. Benchmarking ..............Elapsed milliseconds / relative speed for 2048 iteration(s):
  17.
  18.     (MEMBER PT LST)..............................1388 / 4.26 <fastest>
  19.     (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....5179 / 1.14
  20.     (VL-REMOVE-IF-NOT (QUOTE (LAMBDA (X)...).....5913 / 1 <slowest>
Post by: roy_043 on October 21, 2019, 10:39:08 AM
... Apples and pears.. , but how about vl-position?
Post by: Lee Mac on October 21, 2019, 01:20:28 PM
  1. Benchmarking ..............Elapsed milliseconds / relative speed for 2048 iteration(s):
  2.
  3.     (MEMBER PT LST)..............................1388 / 4.26 <fastest>
  4.     (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....5179 / 1.14
  5.     (VL-REMOVE-IF-NOT (QUOTE (LAMBDA (X)...).....5913 / 1 <slowest>
If I didn't require a tolerance on the point comparison I'd use member/vl-position too, but doubles are rarely exactly equal  :-)
Post by: MP on October 22, 2019, 11:14:58 AM
Surprising result, illuminates the impact data diversity can have upon performance. That said, using a remove type function to determine membership triggers my OCD. O.o
Post by: Marc'Antonio Alessi on October 22, 2019, 03:54:48 PM
  2.     (MEMBER PT LST)..............................1388 / 4.26 <fastest>
  3.     (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....5179 / 1.14
  4.     (VL-REMOVE-IF-NOT (QUOTE (LAMBDA (X)...).....5913 / 1 <slowest>
    (VL-POSITION PT LST)..........................1485 / 8.39 <fastest>
    (MEMBER PT LST)...............................4594 / 2.71
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....11875 / 1.05
    (VL-REMOVE-IF-NOT (QUOTE (LAMBDA (X)...).....12453 / 1 <slowest>
Post by: MP on October 22, 2019, 04:43:06 PM
In real world use I don’t believe vl-position or member are practical for floats or lists of floats.
Post by: Marc'Antonio Alessi on October 22, 2019, 04:47:02 PM
:yes: :-)
Post by: kpblc on October 22, 2019, 04:48:03 PM
The question was "How to check if list pt a part of list lst". We answered this question :)
Post by: Lee Mac on October 22, 2019, 05:05:50 PM
Completely agree. Whenever working with AutoLISP reals, fuzzy comparisons are a must IMO; using member/vl-position to perform tests against what are essentially numerical approximations is like building a house on sand.
Post by: Marc'Antonio Alessi on October 22, 2019, 05:25:40 PM
Another a little bit slover…
(benchmark '(
(vl-member-if '(lambda (x) (equal x pt 1e-8)) Lst)
elapsed milliseconds / relative speed for 1024 iteration(s):
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1484 / 1.04 <fastest>
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1500 / 1.03
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1531 / 1.01
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1547 / 1 <slowest>
Post by: MP on October 22, 2019, 08:56:01 PM
Diminishing returns, how do they work?
Post by: MP on October 22, 2019, 09:01:33 PM
... like building a house on sand.
:nodding:
Post by: Marc'Antonio Alessi on October 23, 2019, 03:00:00 AM
I hope I understood the question well...
with vl-member-if there is the advantage of having a return value with more information
((lambda (/ i)
   (setq i   '(0. 0. 0.)
         lst nil
         ) ;_ end of setq
   (repeat 8192 (setq lst (cons (setq i (mapcar (function +) i '(0.25 0.25 0.25))) lst)) => )
   ) ;_ end of lambda
(setq pt (nth    0 lst)) =>  (2048.0 2048.0 2048.0)
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1171 / 1 <fastest>
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1172 / 1 <slowest>
(setq pt (nth   10 lst)) => (2045.5 2045.5 2045.5)
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1218 / 1 <fastest>
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1219 / 1 <slowest>
(setq pt (nth   50 lst)) => (2035.5 2035.5 2035.5)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1437 / 1 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1438 / 1 <slowest>
(setq pt (nth  100 lst)) => (2023.0 2023.0 2023.0)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1797 / 1 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1797 / 1 <slowest>
(setq pt (nth  500 lst)) => (1923.0 1923.0 1923.0)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1015 / 1.03 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1047 / 1 <slowest>
(setq pt (nth 1000 lst)) => (1798.0 1798.0 1798.0)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1781 / 1.02 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1813 / 1 <slowest>
(setq pt (nth 2000 lst)) => (1548.0 1548.0 1548.0)
Elapsed milliseconds / relative speed for 4096 iteration(s):
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1610 / 1.03 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1656 / 1 <slowest>
(setq pt (nth 3000 lst)) => (1298.0 1298.0 1298.0)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1156 / 1.04 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1203 / 1 <slowest>
(setq pt (nth 4000 lst)) => (1048.0 1048.0 1048.0)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1516 / 1.04 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1578 / 1 <slowest>
(setq pt (nth 5000 lst)) => (798.0 798.0 798.0)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1859 / 1.04 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1937 / 1 <slowest>
(setq pt (nth 6000 lst)) => (548.0 548.0 548.0)
Elapsed milliseconds / relative speed for 1024 iteration(s):
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1109 / 1.04 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1156 / 1 <slowest>
(setq pt (nth 7000 lst)) => (298.0 298.0 298.0)
    (VL-SOME (QUOTE (LAMBDA (X) (EQUAL X...).....1312 / 1.05 <fastest>
    (VL-MEMBER-IF (QUOTE (LAMBDA (X) (EQ...).....1375 / 1 <slowest>
(setq pt (last lst)) => (0.25 0.25 0.25)
