CAD Forums => CAD General => Topic started by: nobody on July 19, 2019, 06:50:02 PM
Title: Where does autocad save the different variable settings?
Post by: nobody on July 19, 2019, 06:50:02 PM
Hey all,
Where does autocad store/save the different variable settings?
Title: Re: Where does autocad save the different variable settings?
Post by: dgorsman on July 21, 2019, 01:50:11 AM
In different places, some in the DWG file, some in the registry, and some are not stored at all.  Look in the documentation,  each system variable will list where (and if) it is stored.
Post by: 57gmc on July 22, 2019, 01:46:35 PM
Also, besides the help, SYSVDLG lists each variable and where it is stored.
Post by: nobody on July 23, 2019, 11:37:52 AM
Thank you
Post by: CAB on July 25, 2019, 12:24:48 PM
This is a great resource  http://www.hyperpics.com/system_variables/index.asp
If (http://www.hyperpics.com/system_variables/index.aspIf) you are registered you can click on each variable & learn where it is stored & much more.
Post by: nobody on July 26, 2019, 04:57:10 PM
Thanks @CAB
Post by: HasanCAD on July 29, 2019, 03:20:48 AM
And if Express installed
try this command
_.sysvdlg
