Code Red => AutoLISP (Vanilla / Visual) => Topic started by: renkor on June 25, 2019, 06:46:07 AM
Title: Automatic dimensioning lines
Post by: renkor on June 25, 2019, 06:46:07 AM
Hello all,
I must dimension thousands of plans using reference lines in them. Those lines cut walls and I have to dimension them.
I would like to select all reference lines in one time and auto dimesion all spaces between lines.
I am attaching a sample drawing.
Thanks all
Title: Re: Automatic dimensioning lines
Post by: renkor on July 02, 2019, 06:52:30 AM
Hello all,
Any ideas for the issue?
Post by: VovKa on July 02, 2019, 09:19:29 AM
it can not be done automatically with standard acad commands
so
the most obvious idea is... write a function which will analyze your drawing and insert dimensions
Post by: Dahzee on July 02, 2019, 11:56:56 AM
Would this program be of any use to you?
https://www.woopaloo.com/en/apps/dimbycutline (https://www.woopaloo.com/en/apps/dimbycutline)
Post by: renkor on July 10, 2019, 04:21:01 AM
so
Hello,
Yes I know i will need a function, but I do not know much
Post by: renkor on July 10, 2019, 04:23:31 AM
Hello,
Yes it's a interesting code. You select the line and make the dimensions.
But my issue is a little bit more complicated. I draw all lines and then I select them in order to create dimensions (eve if lines are swerved, as shown in drawing)
Post by: ChrisCarlson on July 11, 2019, 02:27:32 PM
Should preface that the DWG file was created with a student edition of AutoCAD. If you're truly doing thousands of drawings it does not immediately sound like a "student".
Would "continuing" or "chaining" the dimension be similar to what you are after? There is going to be a bit of manual labor still required.
Post by: renkor on July 11, 2019, 06:12:28 PM
Hello,
I made the drawing at home. I cant make it at office hehe (obviously)
Anyway, dimensions must be continuing with each other. if possible, as showed in the sample.
Thanks,
Post by: BIGAL on July 12, 2019, 12:46:35 AM
Yes it can be done pick say left, pick right pick where do you want dimensions. Its available but not free very cheap. Post if you want more info.
Post by: renkor on July 21, 2019, 05:50:29 AM
Hello,
Could I test your code once?
Post by: BIGAL on July 22, 2019, 01:44:20 AM
I will put something together for you to try, are you metric or feet.
Post by: renkor on July 22, 2019, 05:14:30 PM
Hello,
I am metric.
Post by: MP on July 22, 2019, 05:30:34 PM
Hello,
I am metric.
(http://i.imgflip.com/369ph8.jpg)
Post by: m4rdy on July 26, 2019, 06:09:26 AM
Maybe this :
Lee Mac on https://www.cadtutor.net/forum/topic/22726-dimension-intersection/page/2/#comments
BeekeeCZ on ://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-for-creating-dimension-at-intersections-of-selected-lines/td-p/6800455
Post by: GDF on July 26, 2019, 01:16:14 PM
Lee
I like your dimensioning routine. Thanks for sharing...
