Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Marc'Antonio Alessi on May 20, 2019, 04:25:54 PM
Title: Fatal error on very simple DWG
Post by: Marc'Antonio Alessi on May 20, 2019, 04:25:54 PM
Another very strange fatal error, symptoms:
AutoCAD2020> fatal error on copy/paste one block
BricsCAD V19> fatal error on move by grips
older versions OK  :gum:
see DWG.
Title: Re: Fatal error on very simple DWG
Post by: ronjonp on May 21, 2019, 10:35:10 AM
No crashing here...
Post by: Marc'Antonio Alessi on May 21, 2019, 11:13:53 AM
No crashing here...
V19... only click on grip
Post by: ronjonp on May 21, 2019, 12:04:05 PM
I have AutoCAD 2020 and no crashing on copy paste. First thing I'd do would be open the DWG with recover and see if that fixes the issue.
Post by: Marc'Antonio Alessi on May 21, 2019, 01:01:23 PM
Thanks for test, maybe I send the wrong file… try before recover.
Grazie.  :-)
Post by: ronjonp on May 21, 2019, 01:51:55 PM
Still no errors here.
Post by: Master_Shake on May 21, 2019, 02:31:45 PM
Unload all of your routines, it might be a reactor failing out.
Post by: MP on May 21, 2019, 03:08:02 PM
What happens with the attached Marc?
Post by: Matthew H on May 21, 2019, 03:53:30 PM
Marc'Antonio Alessi's & MP's CAD file both Crash BricsCAD when touching the grip.
BricsCAD Ultimate Beta V19.201 (x64) Revison 60248 Beta
Post by: Marc'Antonio Alessi on May 21, 2019, 03:56:18 PM
Thanks Michael for test: BricsCAD V19 / AutoCAD 2020 same error  :-(
Post by: Marc'Antonio Alessi on May 21, 2019, 04:01:01 PM
I'm using a "Vanilla" profile in V19/A2020 ...I think that these are dynamic blocks created with AutoCAD and then imported into BricsCAD V14 (unfortunately I have a client that still uses this version)...
Post by: Marc'Antonio Alessi on May 21, 2019, 04:08:34 PM
Thanks Matthew, I have V19.2.07 rev.61634
Post by: MP on May 21, 2019, 04:10:32 PM
Thanks for testing.
Started with lite abuse.
Next level abuse attached.
Please try; thanks.
Post by: ronjonp on May 21, 2019, 04:13:34 PM
Could this be part of it?
Non Autodesk DWG.  This DWG file was saved by a software application that was not developed or licensed by Autodesk.  Autodesk cannot guarantee the application compatibility or integrity of this file.
Post by: Marc'Antonio Alessi on May 21, 2019, 04:16:24 PM
Thanks for testing.
Please try; thanks.
:-) V19/A2020 all ok now!  :yes:
Post by: Matthew H on May 21, 2019, 04:16:46 PM
Thanks for testing.
Please try; thanks.
MP, Works as expected. No fatal errors.
Post by: MP on May 21, 2019, 04:18:43 PM
I tried a couple things, let's start with the easiest.
In AutoCAD Use -EXPORTTOAUTOCAD to a new file. Does it crash? If so I'll share more.
Post by: Marc'Antonio Alessi on May 21, 2019, 04:19:21 PM
To clean that try -EXPORTTOAUTOCAD (in AutoCAD)...
Post by: ronjonp on May 21, 2019, 04:23:01 PM
Does this attached drawing crash?
Post by: Matthew H on May 21, 2019, 04:30:07 PM
ronjonp, It does crash BricsCAD.
Post by: Marc'Antonio Alessi on May 21, 2019, 04:33:11 PM
EXPORTTOAUTOCAD > Fatal error
Recover (not audit)   > Fix it for AutoCAD but not for BricsCAD...
Post by: Marc'Antonio Alessi on May 21, 2019, 04:37:56 PM
ronjonp, It does crash.
Post by: ronjonp on May 21, 2019, 04:39:10 PM
DOH! .. I still wonder why my CAD does not crash?
Post by: Marc'Antonio Alessi on May 21, 2019, 04:44:16 PM
Right now I'm using 2020 Mechanical (Vanilla)… maybe the only solution is a WBlock "*"
Post by: MP on May 21, 2019, 04:49:56 PM
level 1
(   (lambda ( nop blocks killitwithfire )
        (vlax-for b blocks
            (and
                (eq :vlax-false (vla-get-islayout b))
                (eq :vlax-false (vla-get-isxref b))
                (eq :vlax-true (vla-get-hasextensiondictionary b))
                (killitwithfire (vla-getextensiondictionary b))
    (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (lambda ( x / e )
        (foreach p (entget (vlax-vla-object->ename x))
            (and
                (eq 360 (car p))
                (eq 'ename (type (setq e (cdr p))))
                (wcmatch (cdr (assoc 0 (entget e))) "*PURGEPREVENTER*")
                (vl-catch-all-apply 'entdel (list e))
Then -exporttoautocad.
Crash, no crash?
Post by: Marc'Antonio Alessi on May 21, 2019, 05:00:22 PM
level 1
        (vlax-for b blocks
            (and
    (lambda ( x / e )
            (and
                (eq 360 (car p))
Crash, no crash?
crash  :-(
Post by: MP on May 21, 2019, 05:05:05 PM
level 2
        (vlax-for b blocks
            (and
    (lambda ( x / e )
            (and
                (eq 360 (car p))
        (vl-catch-all-apply 'vla-delete (list x))
Post by: Marc'Antonio Alessi on May 21, 2019, 05:18:05 PM
GRANDE!  :-) all is ok in B/A no need ExportToAutocad… now I have to run, it's late here in my little state ...my wife pulled me by the hair I don't have anymore. (sorry for google transl.) see you about 8 hours.
Thanks MP  :smitten:
        (vlax-for b blocks
            (and
    (lambda ( x / e )
            (print p) (princ " p ")
            (and
                (eq 360 (car p))
        (print x) (princ " x ")
(-1 . <Entity name: 3cc7e870>)  p
(0 . "DICTIONARY")  p
(5 . "9438")  p
(330 . <Entity name: 3cc7f770>)  p
(100 . "AcDbDictionary")  p
(280 . 1)  p
(281 . 1)  p
(3 . "ACAD_ASSOCNETWORK")  p
(360 . <Entity name: 3cc7e970>)  p
(3 . "ACAD_SORTENTS")  p
(360 . <Entity name: 3cc7f670>)  p
#<VLA-OBJECT IAcadDictionary 000000003CE58A70>  x
(-1 . <Entity name: 3cc7f2b0>)  p
(5 . "9444")  p
(330 . <Entity name: 3cc7ea70>)  p
(280 . 1)  p
(281 . 1)  p
(360 . <Entity name: 3cc7ee70>)  p
#<VLA-OBJECT IAcadDictionary 000000003CE585F0>  x
Post by: MP on May 21, 2019, 05:21:30 PM
You’re most welcome my friend; cheers.
Post by: Marc'Antonio Alessi on May 22, 2019, 07:48:04 AM
Thanks again to Michael Puckett (my friend from Canada  :-) ) for solving the problem.
If anyone wants to play with another puzzle see: http://www.theswamp.org/index.php?topic=54337.msg589061#msg589061
Tested with Open/Recover/Inser + DxfOut/DxfIn:
AutoCAD 2017/18/19/20 + ODBX AutoCAD > Fatal error
AutoCAD 2013 open OK > if copy or move the hatch > Fatal error
> FATAL ERROR:  Unhandled Access Violation Reading 0xffffffd0 Exception at F3DE3C27h
Bricscad (all) > OK
P.S.: lately I'm having a lot of strange problems with DWG going through conversions from/to Microstation / AutoCAD / BricsCAD
