CAD Forums => CAD General => Topic started by: RemoteDrafter on November 27, 2018, 12:26:12 PM
Title: What are people using these days to add XY and Lat Lon grids to their viewports?
Post by: RemoteDrafter on November 27, 2018, 12:26:12 PM
I've recently left a 10 year job where we had custom routines and now have a shiny new install of C3D 2019. I'm needing to make survey asbuilts and was wondering what everyone was using. I cruised the search functions but quickly got too far in to the swamp I think lol.
Thanks in advance :)
Title: Re: What are people using these days to add XY and Lat Lon grids to their viewports?
Post by: mjfarrell on November 27, 2018, 12:55:25 PM
I think if you search in dynamic blocks section you might find a block for such a grid
Otherwise....use that suggestion to build one for yourself
Post by: RemoteDrafter on November 27, 2018, 03:43:07 PM
Maybe I'm not calling it the right thing, attached is an image of what I'm needing to create
Post by: mjfarrell on November 27, 2018, 04:09:32 PM
maybe try this:
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/MAP3D-Use/files/GUID-30F7E71E-5E9D-467C-8630-3795A23193EA-htm.html (https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/MAP3D-Use/files/GUID-30F7E71E-5E9D-467C-8630-3795A23193EA-htm.html)
Post by: Willie on November 28, 2018, 06:37:54 AM
I use a few Civil 3D points.
