CAD Forums => CAD General => BricsCAD Users => Topic started by: GDF on February 16, 2018, 06:53:42 PM
Starting my wish list:
(1) Block Editor like in AutoCAD
(2) Fixes to DCL controls: (works in AutoCAD)
tabs in popup_list not working
:popup_list {key="commands-list"; width=51.5; tabs="11"; multiple_select=false;}
multiple_select=true in list_box not working
:list_box {key="layer-list"; width=67; height=13; tabs = "18 22 33 40"; multiple_select=true;}
tab_truncate=true in list_box works great
:list_box {key="layer-list"; width=67; height=13; tabs = "18 22 33 40"; multiple_select=true; tab_truncate=true;}
I'd suggest making a similar post on the BricsCAD Forum ... They are more likely able to do something about your wishes.
https://forum.bricsys.com/
Regards,
I'm hoping for improved mleaders, a non modal layer manager, and palettes with auto-hide.
And further down the road, a prettier UI.
@GDF:
Multiple_select works just fine. See the attached zip.
@Atook:
Are you aware of the _LayersPanelOpen (https://www.bricsys.com/bricscad/help/en_INTL/CurVer/CmdRef/source/L/LayersPanelOpen.htm) command?
Thanks Roy
I'm going to have to look again at my code...
Gary
@GDF:
Tabs in a popup_list are also supported (zip attached).
It may be useful to have a look at the Developer Reference (https://www.bricsys.com/bricscad/help/en_US/CurVer/DevRef/source/DCL_OverView.htm).
