CAD Forums => CAD General => The Third Dimension => Topic started by: Master_Shake on April 13, 2017, 08:19:04 AM
Starting with an AutoCAD 2017 drawing, what is the best way to end with a rendered, 1:1 scale version of the model?
Define "1:1 scale version" - are you talking an image? Or 3D printing? The former usually involves perspective and is sized in pixels so getting "true scale" images is reaaally difficult.
It will be a top-down "plan" view of an assembly. The rendering will end up being placed on the floor for a graphical, accurate representation of something we cannot show without tearing up concrete, kind of like you had x-ray vision.
Huh - interesting thought. Kind of a hard copy version of augmented reality.
Rather than rendering, I'd switch to one of the shaded visual styles then do a straight print with 1:1 scaling. If this is bigger than a letter size you'd better switch background to white first, otherwise all that black ink will ripple the paper.
Let me go try that one...The final size is about a 26" x 41" with maybe 25% of that box being filled in with "stuff".
That was the money ticket! It's not perfect like a rendering but for what I need, it's perfect.
