Code Red => .NET => Topic started by: Jeff H on December 05, 2014, 09:56:26 AM
Title: -={ Challenge }=- FOB MiniGrid(Bin packing - Subset Sum) Lispers please join in
Post by: Jeff H on December 05, 2014, 09:56:26 AM
If someone can correctly categorize this problem please let me know but thinking its a Bin Packing problem (http://en.wikipedia.org/wiki/Bin_packing_problem) or Subset Sum problem (http://en.wikipedia.org/wiki/Subset_sum_problem)  and maybe a dash of Knapsack problem (http://en.wikipedia.org/wiki/Knapsack_problem)
A real world example of what challenge if needed for.
A temporary military base in the middle of dessert in a foreign country has to generate its own power,  even if it was in a location to connect to a countries power grid the base does not want to rely on the foreign countries power grid.
These bases will have a number of different  components that each require different amount of power.
For example will have
30 Billets  @ 14.4kW each
2 Changing stations @ 12.34kW
4 First Aid @ 15.3kW
etc.....
They will have a number 60kW generators.
Ideally or if the generators were paralleled feeding a grid you would take the total power and divide by 60(add 1 more if remainder) and that would the total number of generators needed.
These generators feed the components directly so unless you combine the components in a way that the sum equals the total generator output you are not using all the generators available power.
The goal is to group components together so they require the least amount of generators.
 Problem.
The challenge is to take a collection of components and put them into groups that total sum is equal to or less the than a Generators Output so that the components will require the least amount generators.
You could use just a list of doubles or reals.
Title: Re: -={ Challenge }=- FOB MiniGrid(Bin packing - Subset Sum) Lispers please join in
Post by: Jeff H on December 05, 2014, 11:00:35 AM
Oh yeah just to throw this in,
Lets say your computer can calculate 1,000,000  different combinations per second.
It only takes 1 sec to calculate all different combinations for 20 items.
It only takes 36 years to calculate all different combinations for 50 items
Post by: gile on December 05, 2014, 03:02:20 PM
Here's simple first fit decreasing bin packing C# implementation.
Code - C#: [Select]
  1.         static List<List<double>> BinPack(IEnumerable<double> source, double packSize)
  2.         {
  3.             var groups = source
  4.                 .GroupBy(x => x)
  5.                 .OrderByDescending(g => g.Key)
  6.                 .Select(g => g.ToList())
  7.                 .ToList();
  8.             var result = new List<List<double>>();
  9.             while (groups.Count > 0)
  10.             {
  11.                 var list = new List<double>();
  12.                 var i = 0;
  13.                 while (i < groups.Count && groups.Count > 0)
  14.                 {
  15.                     if (list.Sum() + groups[i][0] <= packSize)
  16.                     {
  17.                         list.Add(groups[i][0]);
  18.                         groups[i].RemoveAt(0);
  19.                         if (groups[i].Count == 0)
  20.                         {
  21.                             groups.RemoveAt(i);
  22.                         }
  23.                     }
  24.                     else
  25.                     {
  26.                         i++;
  27.                     }
  28.                 }
  29.                 result.Add(list);
  30.             }
  31.             return result;
  32.         }
Post by: Jeff H on December 05, 2014, 04:57:02 PM
Thanks gile!!
Output looks great and need to stare at it a little longer to get it to soak in.
I wish I could borrow your brain 1 or 2 times a week.
Post by: gile on December 05, 2014, 05:35:53 PM
Thanks Jeff.
A F# attempt:
Code - F#: [Select]
  1. let binPack packSize source =
  2.     let rec add lst x =
  3.         match lst with
  4.         | [] -> [[x]]
  5.         | h :: t when x + List.sum h <= packSize -> (x :: h) :: t
  6.         | h :: t -> h :: (add t x)
  7.     source |> Seq.sortBy (~-) |> Seq.fold add []
Post by: gile on December 05, 2014, 05:52:55 PM
A tail recursive one:
Code - F#: [Select]
  2.     let rec loop x acc = function
  3.         | [] -> ([x] :: acc) |> List.rev
  4.         | h :: t when x + List.sum h > packSize -> loop x (h :: acc) t
  5.         | h :: t -> ((x :: h) :: acc |> List.rev) @ t
  6.     source |> Seq.sortBy (~-) |> Seq.fold (fun l x -> loop x [] l) []
Post by: gile on December 06, 2014, 04:04:39 AM
A LISP version:
  1. (defun binPack (packsize source / insert result)
  2.   (defun insert (x lst)
  3.     (cond
  4.       ((null lst) (list (list x)))
  5.       ((<= (+ x (apply '+ (car lst))) packSize)
  6.        (cons (cons x (car lst)) (cdr lst))
  7.       )
  8.       (T (cons (car lst) (insert x (cdr lst))))
  9.     )
  10.   )
  11.   (foreach x (vl-sort source '>)
  12.     (setq result (insert x result))
  13.   )
  14. )
The same with a while loop in the local function to avoid recursivity (AutoLISP doesn't optimize tail recursion).
  2.   (defun insert (x lst / done acc)
  3.     (while (not done)
  4.       (cond
  5.         ((null lst)
  6.          (setq acc  (reverse (cons (list x) acc))
  7.                done T
  8.          )
  9.         )
  10.         ((> (+ x (apply '+ (car lst))) packSize)
  11.          (setq acc (cons (car lst) acc)
  12.                lst (cdr lst)
  13.          )
  14.         )
  15.         (T
  16.          (setq acc  (append (reverse (cons (cons x (car lst)) acc)) (cdr lst))
  17.                done T
  18.          )
  19.         )
  20.       )
  21.     )
  22.     acc
  23.   )
  24.   (foreach x (vl-sort source '>)
  25.     (setq result (insert x result))
  26.   )
  27. )
Post by: gile on December 06, 2014, 05:47:37 AM
A simpler C# implementation:
Code - C#: [Select]
  1.         private static List<List<double>> BinPacking(IEnumerable<double> source, double packSize)
  2.         {
  3.             var result = new List<List<double>>();
  4.             foreach (var item in source.OrderByDescending(x => x))
  5.             {
  6.                 var done = false;
  7.                 for (int i = 0; i < result.Count; i++)
  8.                 {
  9.                     var list = result[i];
  10.                     if (item + list.Sum() <= packSize)
  11.                     {
  12.                         list.Add(item);
  13.                         done = true;
  14.                         break;
  15.                     }
  16.                 }
  17.                 if (!done)
  18.                 {
  19.                     var list = new List<double>() { item };
  20.                     result.Add(list);
  21.                 }
  22.             }
  23.             return result;
  24.         }
Post by: Lee Mac on December 06, 2014, 07:22:35 AM
Good stuff gile  :-)
A minor point, but I think:
  1. (loop x (cdr lst))
should be
  1. (insert x (cdr lst))
Post by: gile on December 06, 2014, 07:55:47 AM
Oopss!...
Thanks Lee. Corrected now.
Post by: It's Alive! on December 06, 2014, 05:31:01 PM
How about a data set?
Post by: It's Alive! on December 06, 2014, 05:32:33 PM
double dbls[] ={ 80, 26, 57, 18, 8, 45, 16, 22, 29, 5, 11, 8, 27, 54, 13, 17, 21, 63, 14, 16, 45, 6, 32, 57, 24, 18, 27, 54, 35, 12, 43, 36, 72, 14, 28, 3, 11, 46, 27, 42, 59, 26, 41, 15, 41, 68};
Enter Bin size: 80
Test = TRUE
BinNum = 1, BinSize = 80.000000 (80.000000 )
BinNum = 2, BinSize = 80.000000 (45.000000 35.000000 )
BinNum = 3, BinSize = 80.000000 (54.000000 26.000000 )
BinNum = 4, BinSize = 80.000000 (54.000000 26.000000 )
BinNum = 5, BinSize = 80.000000 (59.000000 21.000000 )
BinNum = 6, BinSize = 80.000000 (63.000000 17.000000 )
BinNum = 7, BinSize = 80.000000 (68.000000 12.000000 )
BinNum = 8, BinSize = 80.000000 (27.000000 24.000000 18.000000 11.000000 )
BinNum = 9, BinSize = 80.000000 (72.000000 8.000000 )
BinNum = 10, BinSize = 80.000000 (45.000000 29.000000 6.000000 )
BinNum = 11, BinSize = 80.000000 (57.000000 18.000000 5.000000 )
BinNum = 12, BinSize = 79.000000 (43.000000 36.000000 )
BinNum = 13, BinSize = 79.000000 (57.000000 22.000000 )
BinNum = 14, BinSize = 79.000000 (41.000000 27.000000 11.000000 )
BinNum = 15, BinSize = 78.000000 (46.000000 32.000000 )
BinNum = 16, BinSize = 78.000000 (42.000000 28.000000 8.000000 )
BinNum = 17, BinSize = 78.000000 (16.000000 16.000000 15.000000 14.000000 14.000000 3.000000 )
BinNum = 18, BinSize = 68.000000 (41.000000 27.000000 )
BinNum = 19, BinSize = 13.000000 (13.000000 )
Post by: Lee Mac on December 06, 2014, 07:06:43 PM
Still using the first-fit decreasing algorithm, some slightly shorter code, but slower than gile's variant:
  1. (defun binpack ( l s / a b c x )
  2.     (foreach x (vl-sort-i l '>)
  3.         (setq c nil
  4.               x (nth x l)
  5.               a (vl-member-if '(lambda ( b ) (cond ((<= (+ x (apply '+ b)) s)) ((not (setq c (cons b c)))))) b)
  6.               b (append (reverse c) (cons (cons x (car a)) (cdr a)))
  7.         )
  8.     )
  9. )
(setq l '(80 26 57 18 8 45 16 22 29 5 11 8 27 54 13 17 21 63 14 16 45 6 32 57 24 18 27 54 35 12 43 36 72 14 28 3 11 46 27 42 59 26 41 15 41 68)
      s  80
_$ (binpack l s)
((80) (8 72) (12 68) (17 63) (21 59) (22 57) (5 18 57) (26 54) (26 54) (32 46) (35 45) (6 29 45) (36 43) (8 28 42) (11 27 41) (11 27 41) (3 18 24 27) (14 14 15 16 16) (13))
_$ (length (binpack l s))
19
gile, beware of vl-sort if testing with integers  :wink:
Post by: It's Alive! on December 06, 2014, 10:06:55 PM
here's my entry
Code - C: [Select]
  1. #include <map>
  2. #include <vector>
  3. #include <algorithm>
  4.
  5. class BinKey;
  6. typedef std::vector<double> Bin;
  7. typedef std::multimap<BinKey,Bin> BinMap;
  8.
  9. class BinKey
  10. {
  11. private:
  12.   double m_size;
  13.   bool m_isFull;
  14. public:
  15.   BinKey()
  16.     : m_size(0),m_isFull(false){}
  17.   BinKey(double val)
  18.     : m_size(val),m_isFull(false){}
  19.   bool operator<(const BinKey & rhs ) const
  20.   {
  21.     return this->size() > rhs.size();
  22.   }
  23.   double size() const { return m_size; }
  24.   bool isFull() const { return m_isFull; }
  25.   void isFull(bool val) { m_isFull = val; }
  26. };
  27.
  28. class BinPacker
  29. {
  30. private:
  31.   Bin m_bin;
  32.   BinMap m_binMap;
  33.   const size_t m_binSize;
  34.
  35. public:
  36.   BinPacker(const Bin &bin, size_t binSize) : m_bin(bin),m_binSize(binSize)
  37.   {
  38.   }
  39.
  40.   ~BinPacker(void)
  41.   {
  42.   }
  43.
  44.   void eval()
  45.   {
  46.     std::sort(m_bin.begin(), m_bin.end(),std::greater<double>());
  47.     double minVal = m_bin.back();
  48.
  49.     for(auto vecIter = m_bin.begin(); vecIter != m_bin.end() ; ++vecIter)
  50.     {
  51.       if(m_binMap.size() == 0)
  52.         m_binMap.insert(std::make_pair(BinKey(),Bin()));
  53.
  54.       bool erase = false;
  55.       BinMap::iterator lastIter;
  56.
  57.       for(auto mapIter = m_binMap.begin(); mapIter != m_binMap.end(); ++mapIter)
  58.       {
  59.         const double siz = m_binSize - mapIter->first.size();
  60.         if(!mapIter->first.isFull() &&  siz >= *vecIter && *vecIter <= m_binSize)
  61.         {
  62.           lastIter = mapIter;
  63.           erase = true;
  64.           break;
  65.         }
  66.       }
  67.       if(erase)
  68.       {
  69.         BinKey newKey(lastIter->first.size()+*vecIter);
  70.         if(m_binSize - newKey.size() < minVal)
  71.           newKey.isFull(true);
  72.         auto thisIter = m_binMap.insert(std::make_pair(newKey,Bin()));
  73.         lastIter->second.push_back(*vecIter);
  74.         thisIter->second.swap(lastIter->second);
  75.         m_binMap.erase(lastIter);
  76.       }
  77.       else
  78.       {
  79.         if(*vecIter <=  m_binSize)
  80.         {
  81.           auto thisIter = m_binMap.insert(std::make_pair(BinKey(*vecIter),Bin()));
  82.           thisIter->second.push_back(*vecIter);
  83.         }
  84.       }
  85.     }
  86.   }
  87. };
  88.
Post by: gile on December 07, 2014, 04:57:36 AM
Nice, Daniel (even I'm not really able to read C).
I also thought of a way more OOP, but I did not go further because I thought it did not much compared to a simple method and I tend in these challenges, to choose conciseness.
Code - C#: [Select]
  1. using System.Collections.Generic;
  2. using System.Linq;
  3.
  4. namespace BinPacking
  5. {
  6.     public class Bin
  7.     {
  8.         private double _size;
  9.         public double FreeSpace { get; private set; }
  10.         public List<double> Content { get; private set; }
  11.         public Bin(double size, double value)
  12.         {
  13.             _size = size;
  14.             FreeSpace = size - value;
  15.             Content = new List<double>() { value };
  16.         }
  17.         public bool TryInsert(double value)
  18.         {
  19.             if (value > FreeSpace)
  20.                 return false;
  21.             FreeSpace -= value;
  22.             Content.Add(value);
  23.             return true;
  24.         }
  25.     }
  26.
  27.     public class BinPacker
  28.     {
  29.         private double _size;
  30.         public List<Bin> Content { get; private set; }
  31.         public BinPacker(IEnumerable<double> source, double size)
  32.         {
  33.             _size = size;
  34.             Content = new List<Bin>();
  35.             Fill(source.OrderByDescending(x => x));
  36.         }
  37.
  38.         private void Fill(IOrderedEnumerable<double> source)
  39.         {
  40.             foreach (double item in source)
  41.             {
  42.                 bool inserted = false;
  43.                 foreach (Bin bin in Content)
  44.                 {
  45.                     if(bin.TryInsert(item))
  46.                     {
  47.                         inserted = true;
  48.                         break;
  49.                     }
  50.                 }
  51.                 if (!inserted)
  52.                 {
  53.                     Content.Add(new Bin(_size, item));
  54.                 }
  55.             }
  56.         }
  57.     }
  58. }
  59.
Post by: Lee Mac on December 07, 2014, 06:41:07 AM
A brute force approach:
  1. (defun binpack-brute ( l s / b q r )
  2.     (setq l (LM:permutations l)
  3.           r (binpack (car l) s)
  4.           q (length r)
  5.     )
  6.     (foreach x (cdr l)
  7.         (if (< (length (setq b (binpack x s))) q)
  8.             (setq r b q (length b))
  9.         )
  10.     )
  11.     r
  12. )
  13.
  14. (defun binpack ( l s / a b c x )
  15.     (foreach x (vl-sort-i l '>)
  16.         (setq c nil
  17.               x (nth x l)
  18.               a (vl-member-if '(lambda ( b ) (cond ((<= (+ x (apply '+ b)) s)) ((not (setq c (cons b c)))))) b)
  19.               b (append (reverse c) (cons (cons x (car a)) (cdr a)))
  20.         )
  21.     )
  22. )
  23.
  24. ;; Permutations  -  Lee Mac
  25. ;; Returns a list of all permutations of elements in a list
  26.
  27. (defun LM:permutations ( l / f g )
  28.     (defun f ( l )
  29.         (if l (cons (car l) (f (vl-remove (car l) (cdr l)))))
  30.     )
  31.     (defun g ( a l )
  32.         (if l (if (= a (car l)) (cdr l) (cons (car l) (g a (cdr l)))))
  33.     )
  34.     (if (cdr l)
  35.         (f (apply 'append (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) (cons a b)) (LM:permutations (g a l)))) l)))
  36.         (list l)
  37.     )
  38. )
Don't even try it for lists longer than ~7  :evil:
Post by: Lee Mac on December 07, 2014, 07:39:36 AM
Another, using a best-fit decreasing algorithm:
  1. (defun bestfit-binpack ( lst cap / acc bin dif rtn spc tmp )
  2.     (foreach  itm (vl-sort-i lst '>)
  3.         (setq itm (nth itm lst)
  4.               spc cap
  5.               tmp nil
  6.               acc nil
  7.         )
  8.         (while (setq bin (car rtn))
  9.             (if (<= itm (setq dif (- cap (apply '+ bin))) spc)
  10.                 (setq tmp (append (reverse acc) (cons (cons itm bin) (cdr rtn)))
  11.                       spc dif
  12.                 )
  13.             )
  14.             (setq rtn (cdr  rtn)
  15.                   acc (cons bin acc)
  16.             )
  17.         )
  18.         (if tmp
  19.             (setq rtn tmp)
  20.             (setq rtn (reverse (cons (list itm) acc)))
  21.         )
  22.     )
  23. )
Post by: Gasty on December 08, 2014, 06:48:41 PM
Interesting problem, if you need a more pro approach, you should try a solver, as the problem lies inside the boundaries of linear programming, and there are several solutions in the market (Gurobi, Lindo, etc), some for free, like MS Solver Foundation(http://msdn.microsoft.com/en-us/library/ff524509(v=vs.93).aspx (http://msdn.microsoft.com/en-us/library/ff524509(v=vs.93).aspx)). But the non free solutions are very expensive, in the range of multi thousand to hundred of thousand bucks. Even the MS free solution has a commercial version that cost 100.000 or something like that. Any way the problem is exact the same as 1D Cutting Stock Problem (1DCSP), that have multiple applications in the industry, like paper roll cutting, steel bar material calculation and optimization, etc. This paper from Amsterdam Optimization has a lot of examples and even a solution for the 1DCSP:http://amsterdamoptimization.com/models/msf/oml.pdf  (http://amsterdamoptimization.com/models/msf/oml.pdf) .
Gaston Nunez
edit:
kdub-> pdf link amended.
Post by: Jeff H on December 09, 2014, 07:36:53 PM
Thanks again everyone for your input.
Post by: ymg on January 31, 2015, 11:19:47 AM
lee,
Gile's FFD binpack could also be transformed into
a BFD by ordering the returned acc values
in decreasing order of bin total value.
(vl-sort acc (function  (lambda(a b)(> (apply '+ a) (apply '+ b)))))
Although I did not check your way is probably more efficient.
According to Korf's paper BFD tends to be closer to optimal.
A New Algorithm for Optimal Bin Packing  (http://aaaipress.org/Papers/AAAI/2002/AAAI02-110.pdf)
ymg
Post by: ymg on February 02, 2015, 03:52:18 PM
Here's my entry for a Best Fit Decreasing binpack
  1. ;; BFD-binpack         by ymg                                                 ;
  2. ;; Best Fit Decreasing                                                        ;
  3. ;; Arguments: l  List of items to put in bins                                 ;
  4. ;;            c  Capacity of a bin                                            ;
  5. ;;        ;
  6.
  7. (defun BFD-binpack (l c / i bin tmp)
  8.    (foreach  i (vl-sort-i l '>)
  9.        (setq i (nth i l)  tmp nil)
  10.        (cond
  11.           ((not bin) (setq bin (list (list i))))
  12.           (t (while (and (> i (- c (apply '+ (car bin)))) bin)
  13.                (setq tmp (cons (car bin) tmp)  bin (cdr bin))
  14.              )
  15.              (setq tmp (cons (cons i (car bin)) tmp)
  16.                    bin (append (reverse tmp) (cdr bin))
  17.                    bin (vl-sort bin (function (lambda (a b) (> (apply '+ a) (apply '+ b)))))
  18.              )
  19.           )
  20.        )
  21.    )
  22. )
  23.
For a First Fit Decreasing, simply delete line 17 in above code.
ymg
Post by: ElpanovEvgeniy on February 18, 2015, 10:20:24 AM
if i have arguments:
(setq l '(62 20  9 8 12 17 9 6)
      s 80
no code gives me the solution:
'(62 9 9)  :-(
Post by: ymg on February 18, 2015, 02:55:17 PM
Evgenyi,
What the binpack function does is minimize the number
of bin used.
What you are after is minimizing the waste in each bin.
If you use the 1d-csp routine shown  here (http://www.theswamp.org/index.php?topic=48889.msg540140#msg540140) and gives as argument :
         d'(1 1 1 1 1 1 1 1)
         s 80
The routine will return:
((1 (1 0 0 1 0 0 0 1) 0) (1 (0 1 1 0 1 1 1 0) 17))
Since your l list gets sorted in descending order of l
l is now equal to:
(62 20 17  12 9 9 8 6)
The first pattern (1 0 0 1 0 0 0 1) means (62 0 0 12 0 0 0 0 6)
Which is an equivalent answer to (62 9 9)
L: (62 20 17 12 9 9 8 6)
   Nb of Stock used: 2
 Nb of Parts Cutted: 8
Total Length Wasted: 17.00
ymg
Post by: ymg on March 07, 2015, 02:26:57 PM
The binpack algorithm of Gile's could be made faster by
keeping and updating the remainder value in every bin.
Routines as modified should run about 4x faster
It also simplify the job if you want Best Fit Decreasing
or Worst Fit Decreasing.
Here are my version:
  1. ;; FFD-binpack         by ymg                                                 ;
  2. ;; First Fit Decreasing                                                       ;
  5. ;;        ;
  6.
  7. (defun FFD-binpack (l c / i b tb)
  9.        (setq i (nth i l) tb nil)
  10.        (cond
  11.           (b (while (and (> i (cadar b)) b)
  12.                (setq tb (cons (car b) tb)  b (cdr b))
  13.              )
  14.              (setq b (append (reverse (cons (list (reverse (cons i (reverse (caar b))))(if (cadar b) (- (cadar b) i) (- c i))) tb)) (cdr b)))
  15.           )
  16.           (t (setq b (list (list (list i) (- c i)))))
  17.        )
  18.    )
  19.    ;(mapcar 'car b) ;Add this if you want bins without remainder              ;
  20. )
  21.
  22. ;; BFD-binpack         by ymg                                                 ;
  23. ;; Best Fit Decreasing                                                        ;
  24. ;; Arguments: l  List of items to put in bins                                 ;
  25. ;;            c  Capacity of a bin                                            ;
  26. ;;        ;
  27.
  28. (defun BFD-binpack (l c / i b m tb)
  29.    (foreach  i (vl-sort-i l '>)
  30.        (setq i (nth i l)  tb nil)
  31.        (cond
  32.           (b (while (and (> i (cadar b)) b)
  33.                (setq tb (cons (car b) tb)  b (cdr b))
  34.              )
  35.              (if (setq m  (mapcar '(lambda (a) (if (minusp (- (cadr a) i)) 0 (cadr a))) b))
  36.                 (repeat (vl-position (apply 'max m) m)
  37.                    (setq tb (cons (car b) tb)  b (cdr b))
  38.                 )
  39.              )
  40.              (setq b (append (reverse (cons (list (reverse (cons i (reverse (caar b))))(if (cadar b) (- (cadar b) i) (- c i))) tb)) (cdr b)))
  41.           )
  42.           (t (setq b (list (list (list i) (- c i)))))
  43.        )
  44.    )
  45.    ;(mapcar 'car b) ;Add this if you want bins without remainder              ;
  46. )
  47.
  48.
  49. ;; WFD-binpack         by ymg                                                 ;
  50. ;; Worst Fit Decreasing                                                       ;
  51. ;; Arguments: l  List of items to put in bins                                 ;
  52. ;;            c  Capacity of a bin                                            ;
  53. ;;        ;
  54.
  55. (defun WFD-binpack (l c / i b m maxi tb)
  56.    (setq maxi 1.7e308)
  57.    (foreach  i (vl-sort-i l '>)
  58.        (setq i (nth i l)  tb nil)
  59.        (cond
  60.           (b (while (and (> i (cadar b)) b)
  61.                (setq tb (cons (car b) tb)  b (cdr b))
  62.              )
  63.              (if (setq m  (mapcar '(lambda (a) (if (minusp (- (cadr a) i)) maxi (cadr a))) b))
  64.                 (repeat (vl-position (apply 'min m) m)
  65.                    (setq tb (cons (car b) tb)  b (cdr b))
  66.                 )
  67.              )
  68.              (setq b (append (reverse (cons (list (reverse (cons i (reverse (caar b))))(if (cadar b) (- (cadar b) i) (- c i))) tb)) (cdr b)))
  69.           )
  70.           (t (setq b (list (list (list i) (- c i)))))
  71.        )
  72.    )
  73.    ;(mapcar 'car b) ;Add this if you want bins without remainder              ;
  74. )
  75.
Also note that if you don't mind the bins in reverse order the following line:
could be simplified to this:
(setq b (append (reverse (cons (list (cons i (caar b)) (if (cadar b) (- (cadar b) i) (- c i))) tb)) (cdr b)))
Which is very similar to what Gile had.
ymg
Post by: Jeff H on November 02, 2015, 10:37:59 AM
Thanks guys these things will be on National Geographic.
  :-D
