CAD Forums => Vertically Challenged => Topic started by: alanjt on September 25, 2014, 10:26:25 AM
Title: Does anyone have access to arcgis that would convert a SHP file to KMZ for me?
Post by: alanjt on September 25, 2014, 10:26:25 AM
As the subject says...pretty please?
Title: Re: Does anyone have access to arcgis that would convert a SHP file to KMZ for me?
Post by: mjfarrell on September 25, 2014, 10:30:20 AM
one can do this with QGIS......
Or I will do it for you....post your SHP file
Post by: alanjt on September 25, 2014, 10:38:21 AM
Somehow I knew you'd come to the rescue. :)
I'd much rather go the route of being able/knowing how to convert it myself. Downloading now and I'll will post back if I have questions.
Thank you again, Michael.
Post by: mjfarrell on September 25, 2014, 10:46:23 AM
I QGIS
ADD Vector Layer (your SHP file)
Select the layer
Rt-Click
Save as...
Output to KML or KMZ
or a host of formats....enjoy!
Post by: alanjt on September 25, 2014, 11:21:45 AM
Wow.
When it exports to to kml, it creates a folder for each object, which are named based on one of the object fields. Is it possible to specify which field(s) to use?
Post by: mjfarrell on September 25, 2014, 11:26:14 AM
Wow.
suggest that you may be able to create a JOIN and link the information into a single file.....
or verify what KEYFIELD is being used from the SHP file's DBF
you may need to edit that to get desired result.
without seeing your data or results you desire it is tough to offer a blanket solution
Post by: alanjt on September 25, 2014, 11:28:07 AM
Nevermind, it asks you for the name field when you perform a saveas. I just typed it in and it exported perfectly. Thank you so much, Michael. This is pretty damn incredible. I'll have to make a donation.
Post by: mjfarrell on September 25, 2014, 11:28:52 AM
Do you want my PAYPAL details also?    :-D
Post by: Mark on September 25, 2014, 11:36:02 AM
QGIS (A Free and Open Source Geographic Information System) http://www.qgis.org/en/site/
Cool. Thanks!
Post by: alanjt on September 25, 2014, 11:57:05 AM
I can't afford what I'm sure I owe you for all your time.
Post by: mjfarrell on September 25, 2014, 12:02:58 PM
No worries it was (remains) a small joke...at least you are appreciative.  Enough said!
Post by: alanjt on September 25, 2014, 01:07:06 PM
Very appreciative.
Post by: BlackBox on September 25, 2014, 02:25:17 PM
FWIW -
In Civil 3D 2015 I use the new EXPORTKML (http://help.autodesk.com/view/CIV3D/2015/ENU/?guid=GUID-D31F08CA-EFFF-4A04-B426-7ABACCBCB3A8) Command - See Toolspace, Toolbox, Miscellaneous Utilities, Export KML, right click the nested Export KML, select Execute... menu item - to export projects to .KMZ, etc. for our clients.
I also use QGIS & ArcGIS trial installed on VM :wink:; the latter to extract data from .GDB which I've not (yet) found a way to do from QGIS.
Cheers
Post by: Mark on September 25, 2014, 02:27:58 PM
FWIW -
Nice! Glad to see they brought that back. :)
Post by: mjfarrell on September 25, 2014, 02:29:07 PM
FWIW -
Cheers
http://gis.stackexchange.com/questions/22201/how-to-access-file-geodatabase-in-qgis (http://gis.stackexchange.com/questions/22201/how-to-access-file-geodatabase-in-qgis)
Post by: BlackBox on September 25, 2014, 02:34:53 PM
FWIW -
Cheers
Thank you, Michael.
That's why I said 'yet'... I actually have that link saved as bookmark, but when I needed to access .GDB for a strict deadline, I ended up just installing ArcGIS trial. Maybe I'll make time for that QGIS procedure after my trial stops working. :angel:
Cheers
Post by: alanjt on September 25, 2014, 04:58:25 PM
All the more reason to upgrade to 2015.
I am curious, when you bring in a SHP file using mapwspace, you are able to isolate specific data with a polygon, but is it then possible to export that data out to a new shp file?
Post by: BlackBox on September 25, 2014, 05:06:12 PM
I tend to bring in .SHP using MAPIMPORT instead, and only opt for MAPWSPACE if I'm going to modify imported contour (imported as closed polygons with OD), or extract drainage basin data, etc.
I could be mistaken, as I do not often export to .SHP, but I suspect one can export to .SHP so long as the entities selected are valid types supported by .SHP (if that makes sense).
Cheers
Post by: mjfarrell on September 25, 2014, 05:07:12 PM
Actually still no compelling reason to upgrade to 2015 (still no use of Google Earth data)
And you find better results NOT using MAPWSAPCE>>Data Connect to wok with your SHP files.
Rather use MAPIMPORT - be sure to use Import Closed  Shapes as Polygons function or you get hatched areas instead of boundaries
Post by: BlackBox on September 25, 2014, 05:11:48 PM
... still no use of Google Earth data
I thought the new Google Earth API exposed that ability (not natively, albeit), no?
Post by: mjfarrell on September 25, 2014, 05:15:05 PM
sure, but that isn't the same as native support, because Autodesk wants to be pigheaded about paying a license fee to Google.
Post by: BlackBox on September 25, 2014, 05:18:11 PM
I noted that already, and do not disagree with your assessment... One can make use of Google Earth data though, is the point. :angel:
Cheers
[Edit] - You've probably seen this (http://www.theswamp.org/index.php?topic=47908.0;topicseen) already, as example.
Post by: mjfarrell on September 25, 2014, 05:26:00 PM
Cheers
I still stand by my assessment that there is no compelling reason to use 2015 release.  Not really enough NEW and or IMPROVED to justify installation.
Post by: BlackBox on September 25, 2014, 05:34:43 PM
Cheers
:-D
