CAD Forums => CAD General => Topic started by: kruuger on September 15, 2014, 03:20:28 AM
hi
just start with cad 2015. noticed that sometimes my menu disappear.
is this bug or any variable for this.
this is NOT MENUBAR variable.
thanks
kruuger
There is a known issue that can happen if AutoCAD is installed while logged in as "user1", and then when "user2" starts up AutoCAD, the menus are not present.
But you say that "sometimes my menu disappear", indicating that is has happened more than once, which also means that you've fixed it and it happened again..?
So was it broken since the beginning, or did this just start one day?
Have you ran a repair on the install?
Have you tried to manually reload the stock OOTB menu (cuix file)?
try repair, reload cuix - no luck.
menu is open for a second and than off.
if i be quick and hit big icon at corner than menu stays (image below)
ehh back to 2014. there is to many annoying things in 2015:
like modemacro line moving back and fort, tabs under command line or not able to select multiple layout wit CTRL key - sick.
this release is a big mistake :x
thanks
kruuger
