Code Red => AutoLISP (Vanilla / Visual) => Topic started by: andrew_nao on September 04, 2014, 09:59:14 AM
Title: do you have a library of functions saved?
Post by: andrew_nao on September 04, 2014, 09:59:14 AM
this is an odd question but...
do you have a library of lisp function you use often?
if so, how do you save your functions?
do you:
save them in 1 big text file
save them in separate text files
or have some other organized way?
Title: Re: do you have a library of functions saved?
Post by: dgorsman on September 04, 2014, 10:32:07 AM
"Saved" is a bit of a misnomer.  I take an organized library approach to design, building LISP functions to support LISP functions to support LISP functions to support command functions.  They are grouped into files by general function and/or application and/or client, depending how far up the tree they are, where they need/don't need to be loaded.
Post by: JohnK on September 04, 2014, 10:43:27 AM
I don't do lisp any longer but when I did, I kept a library of functions in separate files.
I created a tool in C++ that will allow you to "assemble" a function(s) with all your latest library code files called LiFP (It has many more uses, but this was it's main intention). I even supplied a "starter library" of AutoLisp code for you in that tool.
http://www.theswamp.org/index.php?topic=37700.msg427343#msg427343
Post by: BlackBox on September 04, 2014, 10:44:10 AM
I save them to individual .LSP files by function, and group them into logical VLIDE projects (i.e., 2014_ACAD, 2014_C3D, 2015_ACAD, 2015_C3D, Common, etc.)... Most are demand-loaded into their respective applications via AcadDoc.lsp file.
I am slowly migrating to Autoloader for the ease of maintaining per-[environment[version]] loading of all .CUIx, .LSP, .DLL, etc. components, and the built-in Help file association of same.
Cheers
Post by: kruuger on September 04, 2014, 01:50:33 PM
http://www.theswamp.org/index.php?topic=37700.msg427343#msg427343 (http://www.theswamp.org/index.php?topic=37700.msg427343#msg427343)
still using this one :) it is really helpful.
kruuger
Post by: JohnK on September 04, 2014, 03:13:39 PM
kruuger
That's great! I am super happy that you are using it and it helps!!
Post by: d2010 on September 07, 2014, 07:37:35 PM
yes: i develope a big library witn  1481 functions .autolisp&vlisp........
yes: i extract  from zip'library. Each function is equal wiith a 1 file' or
all functions  saved  to one file source. LSP  or .TXT
 :-P
save them in 1 big text file?
You can  convert  a library functions to one-big-text'file.DTF
Yes. you test
http://lisp2arx.3xforum.ro/post/22/1/DOWNLOADING_vlacompilator_Here_/ (http://lisp2arx.3xforum.ro/post/22/1/DOWNLOADING_vlacompilator_Here_/)
 YOU CLICK ON blue-string, "inregis...."
the VL.exe can  convert the  "append_all_functions_toone_source.txt",
 to source 100%autolisp automatically ......[i/]
 :-o
You  copy&paste with notepad.exe , and you
             save the new-source with notepad.exe <CTRL-S>
Thanks..........
Post by: reltro on September 29, 2014, 01:19:29 PM
Hey People...
I was tired of copying a lot of lisps together to make an application run. Normally I try to reduce the namespace-impact to the global namespace to a minimum. So I developed a routine, in lisp, to stick/to combine my library with the MainRoutine...
What is needed is the function wich will do so ;) (found in \\sys\\combine.lsp), an IndexFile (MSV.csv), a Header in the .lsp-files, and the lib-functions declared in readable form, using defun-q instead of defun (combine.lsp has to know how many arguments a function takes)
NOTE: HEADER.lsp is not the header described above...
I built up a quick application, called 'ModelSpaceViewport' (in the attachment)...
Just open up MSV.lsp and change the Path to match the current location (folder) of the File.
Then load it,Done...
There is just one command loaded, C:MSV... but, u can load others to... Just change the string "GUI" to "CMD" or "ALL" or "API"....
Its V0.1 of the combine-routine, so be nice... ;)
greets reltro
Post by: JohnK on September 29, 2014, 03:31:01 PM
That seems a bit complicated reltro. Have you checked out my LiFP program (it may help)?
Post by: VovKa on September 29, 2014, 05:17:22 PM
i store my lisps in libraries. that is around 30 files
in case i need a standalone application i have this 'assembling" function
(defun vk_GetAuthorPrefix (/) "VK_")
(defun vk_ReadTextStream (FileName Charset / ADODBStreamObj Result)
  (if (and (setq FileName (findfile FileName))
   (setq ADODBStreamObj (vlax-create-object "ADODB.Stream"))
    (progn (setq Result
  (vl-catch-all-apply
    (function (lambda ()
(vlax-put ADODBStreamObj "Charset" Charset)
(vlax-invoke ADODBStreamObj "Open")
(vlax-invoke ADODBStreamObj "LoadFromFile" FileName)
(vlax-invoke-method ADODBStreamObj "ReadText" -1)
   (vlax-release-object ADODBStreamObj)
   (if (not (vl-catch-all-error-p Result))
     Result
(defun vk_Assemble (Dir WorkFunctionNamesList
    OutFileName /     AllFunctionsList
    FoundFunction FunctionTail     WorkFunctionNamesList*
    WorkFunctionsList OutFile     vk_FindFunction
    vk_TraceFunction
  (defun vk_FindFunction (Name FunctionsList / Result)
    (if FunctionsList
      (if (and (= (car FunctionsList) 'DEFUN) (= (cadr FunctionsList) Name))
FunctionsList
(if (or (atom (car FunctionsList))
(not (setq Result (vk_FindFunction Name (car FunctionsList))))
  (if (atom (cdr FunctionsList))
    nil
    (vk_FindFunction Name (cdr FunctionsList))
  Result
  (defun vk_TraceFunction (FunctionDefun FunctionTail / Found)
    (if FunctionTail
(if (atom FunctionTail)
  (setq FunctionTail (list FunctionTail))
(if (= (car FunctionTail) 'DEFUN)
  (vk_TraceFunction FunctionTail (cdr FunctionTail))
  (if (listp (car FunctionTail))
    (append (vk_TraceFunction FunctionDefun (car FunctionTail))
    (vk_TraceFunction FunctionDefun (cdr FunctionTail))
      (and (= (type (car FunctionTail)) 'SYM)
   (wcmatch
     (vl-symbol-name (car FunctionTail))
     (strcat (vk_GetAuthorPrefix) "*,C:" (vk_GetAuthorPrefix) "*")
   (not (vl-position (car FunctionTail) WorkFunctionNamesList*))
   (not (vl-position
  (car FunctionTail)
  (cdr (member '/ (caddr FunctionDefun)))
   (not (vk_FindFunction (car FunctionTail) FunctionDefun))
       (append
(if (setq
       Found (vk_FindFunction (car FunctionTail) AllFunctionsList)
   (progn (setq WorkFunctionNamesList*
(cons (car FunctionTail)
(vk_TraceFunction (car FunctionTail) Found)
   (prompt (strcat "    '"
   " not found\n"
  (setq WorkFunctionNamesList* WorkFunctionNamesList)
  (prompt "Reading source files...\n")
  (foreach FileName (mapcar (function (lambda (FileName) (strcat Dir FileName)))
    (vl-directory-files Dir "*.lsp" 1)
    (prompt (strcat "  reading \"" FileName "\"...\n"))
    (setq AllFunctionsList
   (append
     AllFunctionsList
     (cdr (read
    (strcat "(progn\n"
    (vk_ReadTextStream FileName "windows-1251")
    "\n)"
    nil
  (prompt "Source files read.\n")
  (prompt "Tracing fucntions.\n")
  (foreach WorkFunction WorkFunctionNamesList*
    (prompt (strcat "  tracing '" (vl-symbol-name WorkFunction) "...\n"))
    (setq FoundFunction (vk_FindFunction WorkFunction AllFunctionsList))
    (vk_TraceFunction FoundFunction (cdr FoundFunction))
  (prompt "Functions traced.\n")
  (prompt "Saving output file...\n")
  (setq OutFile (open OutFileName "W"))
  (princ "(VL-LOAD-COM)" OutFile)
    (prompt (strcat "  writung function '" (vl-symbol-name WorkFunction) "...\n"))
    (princ "\n" OutFile)
    (prin1 (vk_FindFunction WorkFunction AllFunctionsList) OutFile)
    (princ (strcat "\n(VL-DOC-EXPORT '" (vl-symbol-name WorkFunction) ")")
   OutFile
  (close OutFile)
  (prompt "Output file saved.\n")
which is called like this
(setq LibraryDir "X:\\VisualLisp\\"
       '(C:command1 C:command2)
      OutFileName
       (strcat LibraryDir "SomeFile.lsp")
(vk_Assemble LibraryDir WorkFunctionNamesList OutFileName)
then it recursively traces down all dependant functions and saves the result in a separate file
