Code Red => AutoLISP (Vanilla / Visual) => Topic started by: snownut2 on December 28, 2013, 08:44:09 AM
Title: List Functions
Post by: snownut2 on December 28, 2013, 08:44:09 AM
Time for some additional basic List Functions;
       ListSum = Sum of all numbers in a numbered list
       ListMax = Largest number contained in a numbered list
       ListMin  = Smallest "                                                      "
I'm sure there are tons more !!
Title: Re: List Functions
Post by: ribarm on December 28, 2013, 10:06:30 AM
  1. (defun ListSum ( lst / x xx )
  2.   (setq xx 0)
  3.   (while lst
  4.     (setq x (car lst))
  5.     (setq xx (+ x xx))
  6.     (setq lst (cdr lst))
  7.   )
  8.   xx
  9. )
  10.
  11. (defun ListMax ( lst / x xx )
  12.   (while lst
  13.     (setq x (car lst))
  14.     (setq xx (cond (xx) ((cadr lst))))
  15.     (setq xx (max x xx))
  16.     (setq lst (cdr lst))
  17.   )
  18.   xx
  19. )
  20.
  21. (defun ListMin ( lst / x xx )
  22.   (while lst
  23.     (setq x (car lst))
  24.     (setq xx (cond (xx) ((cadr lst))))
  25.     (setq xx (min x xx))
  26.     (setq lst (cdr lst))
  27.   )
  28.   xx
  29. )
  30.
Post by: CAB on December 28, 2013, 10:11:55 AM
(defun ListSum ( lst)
 (apply '+ lst)
 (apply 'max lst)
 (apply 'min lst)
Post by: snownut2 on December 28, 2013, 10:15:21 AM
 (apply '+ lst)
 (apply 'max lst)
 (apply 'min lst)
Thanks CAB, I'm not that familiar with the apply function.  This is a good example though.
Bruce
Post by: Tharwat on December 28, 2013, 10:17:20 AM
CAB , you have localized variables that are not needed .
Post by: Lee Mac on December 28, 2013, 10:22:20 AM
If you have an aversion to the apply function:
  1. (defun listsum ( l ) (eval (cons '+ l)))
  2. (defun listmin ( l ) (eval (cons 'min l)))
  3. (defun listmax ( l ) (eval (cons 'max l)))
Post by: Lee Mac on December 28, 2013, 10:35:51 AM
Or, if you wanted to iterate over the lists...
  1. (defun listsum ( l / r )
  2.     (setq r 0)
  3.     (foreach x l (setq r (+ x r)))
  4.     r
  5. )
  6. (defun listmin ( l / r )
  7.     (setq r (car l))
  8.     (foreach x (cdr l) (setq r (min r x)))
  9.     r
  10. )
  11. (defun listmax ( l / r )
  12.     (setq r (car l))
  13.     (foreach x (cdr l) (setq r (max r x)))
  14.     r
  15. )
Post by: CAB on December 28, 2013, 12:32:57 PM
Yes, I was being lazy, copy & paste from previous post.
Post by: snownut2 on December 28, 2013, 06:54:22 PM
Lee, for the "SUM" result your last post is exactly how I had accomplished it, for the MIN/MAX I had sorted the list </> then selected the 1st element.  I was not real keen on the sort idea.
Thanks guys for the quick response's
Bruce
Post by: Lee Mac on December 28, 2013, 07:07:16 PM
Yes - sorting all items in the list is very inefficient if you are only interested in the min/max  ;-)
Post by: David Bethel on December 29, 2013, 08:51:32 AM
Maybe flush out the functions :
;;;Product of a list
  (defun ListProd (l)
    (apply '* l))
;;;Mean or Average of a list
  (defun ListAvg (l)
    (/ (apply '+ l) (float (length l))))
;;;Median of a SORTED list
  (defun ListMed (l / c)
    (setq c (length l))
    (if (= (rem c 2) 1)
        (nth (fix (/ c 2.0)) l)
        (/ (+ (nth (1- (fix (/ c 2.0))) l)
              (nth (fix (/ c 2.0)) l))
           2.0)))
;;;Range of a list
  (defun ListRng (l / c)
    (- (apply 'max l)
       (apply 'min l)))
;;;Mode of a list
  (defun ListMode (l / c r x m)
    (setq c nil)
    (foreach a l
      (setq c (if (assoc a c)
                  (subst (list a (1+ (cadr (assoc a c))))
                         (assoc a c) c)
                  (cons (list a 1) c))))
    (setq r (mapcar ' reverse c)
          x (apply 'max (mapcar 'car r)))
    (cond ((= x 1) (setq m "None"))
          (T
           (foreach a r
             (if (= (car a) x)
                 (setq m (cons (cadr a) m))))))
    m)
Prime Factors & Least Common Multiple would be cool
-David
Post by: Lee Mac on December 29, 2013, 10:25:16 AM
Another for mode:
http://www.theswamp.org/index.php?topic=45195.msg503882#msg503882
Post by: Lee Mac on December 29, 2013, 10:46:37 AM
A possible candidate for LCM:
  1. (defun lcm ( l / f )
  2.     (defun f ( a b / m )
  3.         (if (apply '= a)
  4.             (car a)
  5.             (progn
  6.                 (setq m (apply 'min a))
  7.                 (f (mapcar '(lambda ( a b ) (if (= a m) (+ a b) a)) a b) b)
  8.             )
  9.         )
  10.     )
  11.     (f l l)
  12. )
  1. _$ (lcm '(22 16 31))
  2. 5456
Post by: Lee Mac on December 29, 2013, 11:03:58 AM
Another:
  1. (defun lcm ( l )
  2.     (/ (apply '* l) (apply '* (mapcar 'gcd l (cdr l))))
  3. )
Post by: David Bethel on December 29, 2013, 11:11:26 AM
Another:
  1. (defun lcm ( l )
  3. )
That'a a good 1 !
PS
On second look, I don't think this 1 works
  (setq lst '(2 5 5 5 6 7 10 10 10 12))
  (lcm lst)
  25200
Post by: Lee Mac on December 29, 2013, 11:22:10 AM
That'a a good 1 !
Thanks David  :-)
This version might be more efficient:
  1. (defun lcm ( l )
  2.     (if (cdr l)
  3.         (* (/ (car l) (gcd (car l) (cadr l))) (lcm (cdr l)))
  4.         (car l)
  5.     )
  6. )
Post by: Lee Mac on December 29, 2013, 11:52:26 AM
  (lcm lst)
  25200
Back to the drawing board on that one :-(
Post by: David Bethel on December 29, 2013, 12:02:12 PM
I tried removing the duplicate atoms to no avail.  -David
Post by: Lee Mac on December 29, 2013, 12:20:30 PM
New method:
  1. (defun lcm ( l )
  2.     (if (cddr l)
  3.         (lcm (list (car l) (lcm (cdr l))))
  4.         (/ (apply '* l) (apply 'gcd l))
  5.     )
  6. )
Post by: Lee Mac on December 29, 2013, 12:24:51 PM
Or perhaps more efficiently:
  1. (defun lcml ( l )
  2.     (if (cddr l)
  3.         (lcm (car l) (lcml (cdr l)))
  4.         (apply 'lcm l)
  5.     )
  6. )
  7. (defun lcm ( a b ) (* b (/ a (gcd a b))))
  1. _$ (lcml '(2 5 5 5 6 7 10 10 10 12))
  2. 420
Post by: Lee Mac on December 29, 2013, 12:30:45 PM
And an iterative version:
  1. (defun lcml ( l / r )
  2.     (setq r (lcm (car l) (cadr l)))
  3.     (foreach x (cddr  l) (setq r (lcm r x)))
  4.     r
  5. )
  6. (defun lcm ( a b ) (* b (/ a (gcd a b))))
Post by: gile on December 29, 2013, 06:13:09 PM
Inspired by the F# List.reduce function (http://msdn.microsoft.com/en-us/library/ee370239.aspx).
F# doesn't have an OOTB 'gcd' function, but it's easy to implement.
Code - F#: [Select]
  1. let rec gcd x y = if y = 0 then x else gcd y (x % y)
  2.
  3. let lcm = List.reduce(fun a b -> a * b / gcd a b)
With AutoLISP, using a reusable 'gc:reduce' function:
  1. ;; gc:reduce
  2. ;; (gc:reduce 'f '(i0 i1 i2 ... in)) computes: (f ... (f (f i0 i1) i2) ... in)
  3. (defun gc:reduce (fun lst)
  4.   (setq fun (eval fun))
  5.   (while (cdr lst)
  6.     (setq lst (cons (fun (car lst) (cadr lst)) (cddr lst)))
  7.   )
  8.   (car lst)
  9. )
  10.
  11. (defun lcm (lst) (gc:reduce '(lambda (a b) (/ (* a b) (gcd a b))) lst))
You can find some others List Functions here (http://gilecad.azurewebsites.net/LISP/gc_List.lsp) (sorry for the french comments)
Post by: Lee Mac on December 29, 2013, 07:09:31 PM
Prime Factors would be cool
Not quite as easy:
  1. (defun pf ( n / c i p r )
  2.     (setq p 2)
  3.     (while (< 1 n)
  4.         (if (< 0 (rem n p))
  5.             (progn
  6.                 (setq c (fix (1+ (sqrt n)))
  7.                       i 3
  8.                       p n
  9.                 )
  10.                 (while (< i c)
  11.                     (if (zerop (rem n i))
  12.                         (setq p i
  13.                               i c
  14.                         )
  15.                     )
  16.                     (setq i (+ i 2))
  17.                 )
  18.             )
  19.         )
  20.         (setq r (cons p r)
  21.               n (/ n p)
  22.         )
  23.     )
  24.     (reverse r)
  25. )
Or, recursively:
  1. (defun pf ( n / f )
  2.     (defun f ( n p / c i )
  3.         (if (< 1 n)
  4.             (if (zerop (rem n p))
  5.                 (cons p (f (/ n p) p))
  6.                 (progn
  7.                     (setq c (fix (1+ (sqrt n)))
  8.                           i 3
  9.                           p n
  10.                     )
  11.                     (while (< i c)
  12.                         (if (zerop (rem n i))
  13.                             (setq p i
  14.                                   i c
  15.                             )
  16.                         )
  17.                         (setq i (+ i 2))
  18.                     )
  19.                     (cons p (f (/ n p) p))
  20.                 )
  21.             )
  22.         )
  23.     )
  24.     (f n 2)
  25. )
  1. _$ (pf 360315)
  2. (3 3 3 5 17 157)
Post by: gile on December 30, 2013, 06:24:01 AM
A more efficient implementation of gc:reduce (I forgot I posted this (http://www.theswamp.org/index.php?topic=37362.msg423677#msg423677))
  1. ;; gc:reduce
  3. (defun gc:reduce (fun lst / acc)
  5.         acc (car lst)
  6.   )
  7.   (foreach n (cdr lst) (setq acc (fun acc n)))
  8. )
Post by: Lee Mac on December 30, 2013, 06:31:43 AM
Look back at our prime factorisation thread (http://www.theswamp.org/index.php?topic=42965.0), this would be more efficient:
  1. (defun pf ( n / m p r )
  2.     (setq p 2)
  3.     (while (< 1 n)
  4.         (while (zerop (rem n p))
  5.             (setq r (cons p r)
  6.                   n (/ n p)
  7.             )
  8.         )
  9.         (if (< 1 (setq m (sqrt n)) (setq p (if (= p 2) 3 (+ 2 p))))
  10.             (setq r (cons n r)
  11.                   n 0
  12.             )
  13.             (while (and (<= p m) (< 0 (rem n p)))
  14.                 (setq p (+ 2 p))
  15.             )
  16.         )
  17.     )
  18.     (reverse r)
  19. )
Post by: David Bethel on December 30, 2013, 09:01:21 AM
Maybe like thus ?
Least Common Multiple - Product of the prime factors
using Lee's pf prime_factor's:
(defun pf ( n / m p r ) ; LeeMac
  (setq p 2)
  (while (< 1 n)
                (setq r (cons p r)
                      n (/ n p)))
             (setq r (cons n r)
                   n 0)
                         (< 0 (rem n p)))
                    (setq p (+ 2 p)))))
  (reverse r))
(defun ListLCM (l / pl fl)
  (foreach a l
    (setq pl (pf a))
    (foreach f pl
       (if (not (member f fl))
           (setq fl (cons f fl)))))
  (apply '* fl))
-David
Post by: Lee Mac on December 30, 2013, 09:19:20 AM
Maybe like thus ?
I could be wrong, but I thought:
LCM = product of distinct prime factors with the highest powers
So the function may need to be something like:
(defun listlcm ( l / a n p r x )
    (while l
        (setq x (car l)
              l (vl-remove x (cdr l))
              p (pf x)
        (while p
            (setq x (car p)
                  n (length p)
                  p (vl-remove x (cdr p))
                  n (- n (length p))
                  a (assoc x r)
            (if a
                (if (< (cadr a) n)
                    (setq r (subst (list x n) a r))
                (setq r (cons (list x n) r))
    (apply '* (mapcar '(lambda ( x ) (apply 'expt x)) r))
_$ (listlcm '(2 5 5 5 6 7 10 10 10 12))
420
Post by: roy_043 on December 30, 2013, 10:08:19 AM
Are negative integers allowed in the input list for the LCM function?
(listlcm '(-24  18  10)) =>  90
(listlcm '( 24 -18  10)) => 120
(listlcm '( 24  18 -10)) =>  72
(listlcm '(-24 -18  10)) =>  10
(listlcm '(-24  18 -10)) =>  18
(listlcm '( 24 -18 -10)) =>  24
(listlcm '(-24 -18 -10)) =>   0
Post by: David Bethel on December 30, 2013, 10:22:37 AM
http://en.wikipedia.org/wiki/Least_common_multiple (http://en.wikipedia.org/wiki/Least_common_multiple)
The LCM of more than two integers is also well-defined: it is the smallest integer that is divisible by each of them
Looks like mine is it working properly.........  -David
Post by: Lee Mac on December 30, 2013, 10:37:41 AM
Testing yours:
  1. _$ (ListLCM '(2 5 5 5 6 7 10 10 10 12))
  2. 210
  3. _$ (/ 210 12.)
  4. 17.5
Correct LCM is 420 (http://www.wolframalpha.com/input/?i=lcm%282+5+5+5+6+7+10+10+10+12%29)
Post by: David Bethel on December 30, 2013, 12:27:35 PM
I meant to say NOT working properly.  Sorry.  -David
Post by: Lee Mac on December 30, 2013, 01:17:05 PM
No worries!  :-)
Post by: edata on December 31, 2013, 10:19:52 AM
About "eval" .if (length > 255),An error will occur. :-)
Post by: snownut2 on December 31, 2013, 01:34:18 PM
to Mark or other Mod.  any way to create a reference section, where threads like this one can be posted, due to its large amount of "reference material" maybe to help limit the amount of future duplicate type threads. Maybe not allow anyone to post new threads but moved there by moderators when a good reference thread is developed.  I am not saying lock the actual threads themselves, but to only have good reference threads there.
There are many such threads and searching for them sometimes becomes a challenge if the searcher does not use the exact right search words.
Bruce
