Code Red => .NET => Topic started by: Jeff_M on March 21, 2013, 10:18:51 AM
Title: 2 Projects, 1 Solution, CommandMethods in both?
Post by: Jeff_M on March 21, 2013, 10:18:51 AM
I have a VS2010 Solution with multiple Projects, 2 of which contain multiple [CommandMethod()] definitions. The commands in the main project work fine. Those defined in the secondary project, which is referenced into the main project, are not recognized. Is there something I need to do (well, obviously there is...but what?) in order for these additional commands to be 'seen' by Autocad?
Title: Re: 2 Projects, 1 Solution, CommandMethods in both?
Post by: WILL HATCH on March 21, 2013, 11:11:34 AM
the easy way would be to netload the dll from the second project.
the nice way (maybe, haven't tried) might be to add the line
Code - C#: [Select]
  1. [assebly: CommandClass(typeof(the.namespace.of.the.external.commands))]
into the first project, so when it is loaded by autocad it actually registers the commands (note if you do this anywhere in your project you will need to do it everywhere... it signals to autocad that you (the programmer) has explicitly separated command classes and only looks in those places for CommandMethods)
I think it's because of how netload actually functions
Post by: Jeff_M on March 21, 2013, 11:31:46 AM
OK, I guess I'm confused, again....doesn't take much :-) If the second project is referenced by the first, shouldn't that mean the second gets loaded when the first is loaded? That's what I thought happens, since the public classes, properties, and methods, that I have in other projects are all available and used as needed. But if I manually load this one project's DLL, even though it is referenced by the first, only then are the commands available. I can go ahead and force it to load, it just seems like I shouldn't need to do so.
Post by: WILL HATCH on March 21, 2013, 12:05:20 PM
I think it has to do with class definitions.  Since your classes are instance classes then when AutoCAD looks through your assembly for the CommandMethod attribute it doesn't look through the referenced project.
Did you try the CommandClass assembly attribute? That may force AutoCAD to load up and examine your other project.
You could also just register the commands in the second project for demand loading.  If you look into the guts of the RegistForDemandLoading that Kean has posted you could tweak it to register the commands from the second project along with the first.
Post by: huiz on March 21, 2013, 12:29:11 PM
Is the class in the second project public (or c# equivalent)? For commands it must be public.
Post by: BlackBox on March 21, 2013, 12:40:50 PM
As I understand it, Jeff... Only the first CommandClassAttribute is recognized, meaning that your CommandMethodAttribute definitions need to reside within the same Class/Type the CommandClassAttribute is targeting.
Disregard.
Post by: BlackBox on March 21, 2013, 01:10:59 PM
... Starting to wonder if anything I was taught during my recent contract position was actually correct. I really hate wasting my time.  :|
Just tried a quick project with two CommandClassAttributes, and both register just fine regardless of being in the same Namespace, or targeting different public Types.
Post by: Jeff_M on March 21, 2013, 01:20:22 PM
I don't utilize any CommandCLassAttributes....
Trying to change everything to use [assembly: CommandClass(....)] is not something I would like to implement. We tried this a few years ago, when we had about half the commands we now do, and it was difficult, at best, to keep the list of commands up to date.
What I just tested, and seems to be working with the one command I tested with, is to move the command call from the second project into it's own class in the main project. So this new class has nothing more than [CommandMethod()] and a method to call the actual method in the second project, for each of the 7 commands in that second project. Seems a bit convoluted but, as I said, it seems to be working.
Post by: Jeff H on March 21, 2013, 01:21:52 PM
CommandClassAttribute is metadata at the assembly level and you can have many and add them anywhere in any class file, but placing them in  AssemblyInfo file is probably a good practice AutoCAD .NET CommandClass and Some Clarifications (http://spiderinnet1.typepad.com/blog/2012/07/commandclass-and-some-clarifications.html)
you will see that it is added to assembly Manifest if you look at it with IL Disassembler.
If you look at first if statement AutoCAD checks the assembly for CommandClassAttribute if at least one exists then it adds them.
If no CommandClassAttribute are found then it will start looking at metadata for the types in the assembly.
So if you add one CommandClassAttribute then you have to do it for all types that contain methods with CommandMethodAttribute
Code - C#: [Select]
  1. [return: MarshalAs(UnmanagedType.U1)]
  2. public unsafe bool Initialize(Assembly assembly)
  3. {
  4.     bool flag;
  5.     ManageGApp app;
  6.     ManageGApp.{ctor}(&app);
  7.     try
  8.     {
  9.         Type[] exportedTypes;
  10.         PerDocumentCommandClass class2;
  11.         object[] objArray2;
  12.         this.m_commandClasses = new List<CommandClass>();
  13.         CommandClass item = null;
  14.         object[] customAttributes = assembly.GetCustomAttributes(typeof(CommandClassAttribute), false);
  15.         int length = customAttributes.Length;
  16.         if (length > 0)
  17.         {
  18.             exportedTypes = new Type[length];
  19.             int num4 = 0;
  20.             if (0 < length)
  21.             {
  22.                 do
  23.                 {
  24.                     CommandClassAttribute attribute = (CommandClassAttribute) customAttributes[num4];
  25.                     exportedTypes[num4] = attribute.Type;
  26.                     num4++;
  27.                 }
  28.                 while (num4 < customAttributes.Length);
  29.             }
  30.         }
  31.         else
  32.         {
  33.             exportedTypes = assembly.GetExportedTypes();
  34.         }
  35.         int index = 0;
  36.         if (0 >= exportedTypes.Length)
  37.         {
  38.             goto Label_0185;
  39.         }
  40.     Label_007B:
  41.         class2 = null;
  42.         if (exportedTypes[index] == null)
  43.         {
  44.             goto Label_0176;
  45.         }
  46.         MethodInfo[] methods = exportedTypes[index].GetMethods(BindingFlags.Public | BindingFlags.Static | BindingFlags.Instance);
  47.         int num = 0;
  48.         if (0 >= methods.Length)
  49.         {
  50.             goto Label_0165;
  51.         }
  52.     Label_00A3:
  53.         objArray2 = methods[num].GetCustomAttributes(typeof(ICommandLineCallable), false);
  54.         if (objArray2.Length != 0)
  55.         {
  56.             CommandClass class4;
  57.             object[] objArray = methods[num].GetCustomAttributes(typeof(ICondition), false);
  58.             int num7 = objArray.Length;
  59.             if (num7 != 0)
  60.             {
  61.                 int num2 = 0;
  62.                 if (0 < num7)
  63.                 {
  64.                     do
  65.                     {
  66.                         if (!((ICondition) objArray[num2]).Evaluate())
  67.                         {
  68.                             break;
  69.                         }
  70.                         num2++;
  71.                     }
  72.                     while (num2 < objArray.Length);
  73.                 }
  74.                 if (num2 < objArray.Length)
  75.                 {
  76.                     goto Label_0159;
  77.                 }
  78.             }
  79.             if (methods[num].IsStatic)
  80.             {
  81.                 if (item == null)
  82.                 {
  83.                     item = new CommandClass();
  84.                 }
  85.                 class4 = item;
  86.             }
  87.             else
  88.             {
  89.                 if (class2 == null)
  90.                 {
  91.                     class2 = new PerDocumentCommandClass();
  92.                 }
  93.                 class4 = class2;
  94.             }
  95.             int num5 = 0;
  96.             if (0 < objArray2.Length)
  97.             {
  98.                 do
  99.                 {
  100.                     class4.AddCommand((ICommandLineCallable) objArray2[num5], methods[num]);
  101.                     num5++;
  102.                 }
  103.                 while (num5 < objArray2.Length);
  104.             }
  105.         }
  106.     Label_0159:
  107.         num++;
  108.         if (num < methods.Length)
  109.         {
  110.             goto Label_00A3;
  111.         }
  112.     Label_0165:
  113.         if (class2 != null)
  114.         {
  115.             this.m_commandClasses.Add(class2);
  116.         }
  117.     Label_0176:
  118.         index++;
  119.         if (index < exportedTypes.Length)
  120.         {
  121.             goto Label_007B;
  122.         }
  123.     Label_0185:
  124.         if (item != null)
  125.         {
  126.             this.m_commandClasses.Add(item);
  127.         }
  128.         flag = (bool) ((byte) (this.m_commandClasses.Count > 0));
  129.     }
  130.     fault
  131.     {
  132.         ___CxxCallUnwindDtor(ManageGApp.{dtor}, (void*) &app);
  133.     }
  134.     ManageGApp.{dtor}(&app);
  135.     return flag;
  136. }
Post by: WILL HATCH on March 21, 2013, 01:48:04 PM
A working method of not thinking about the dependency:
First project initialization method calls second project
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Threading.Tasks;
  6. using Autodesk.AutoCAD.ApplicationServices;
  7. using Autodesk.AutoCAD.DatabaseServices;
  8. using Autodesk.AutoCAD.Runtime;
  9. using Autodesk.AutoCAD.EditorInput;
  10. using Autodesk.AutoCAD.Interop;
  11. using System.Reflection;
  12. using System.IO;
  13. //using project2;
  14. [assembly: CommandClass(typeof(_2ProjectSolution.Class1))]
  15. [assembly: CommandClass(typeof(_2ProjectSolution.Class2))]
  16. namespace _2ProjectSolution
  17. {
  18.     public class Class1
  19.     {
  20.         [CommandMethod("FirstProjectClass1")]
  21.         public void test1()
  22.         {
  23.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  24.             ed.WriteMessage("\nWe've reached the first class");
  25.         }
  26.     }
  27.     public class Class2
  28.     {
  29.         [CommandMethod("FirstProjectClass2")]
  30.         public void test2()
  31.         {
  32.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  33.             ed.WriteMessage("\nWe've reached the second class");
  34.         }
  35.     }
  36.     public class InitializationTest : Autodesk.AutoCAD.Runtime.IExtensionApplication
  37.     {
  38.         public void Initialize()
  39.         {
  40.             Document doc = Application.DocumentManager.MdiActiveDocument;
  41.             Editor ed = doc.Editor;
  42.             int filedia = System.Convert.ToInt32(Application.GetSystemVariable("FILEDIA"));
  43.             try
  44.             {
  45.
  46.                 ((AcadDocument)doc.GetAcadDocument()).SendCommand("FILEDIA 0 ");
  47.                 ((AcadDocument)doc.GetAcadDocument()).SendCommand(string.Format("NETLOAD {0}\\project2.dll\n", Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location)));
  48.                 ((AcadDocument)doc.GetAcadDocument()).SendCommand(string.Format("FILEDIA {0} ", filedia));
  49.             }
  50.             catch (System.Exception e)
  51.             {
  52.                 throw e;
  53.             }
  54.         }
  55.         public void Terminate()
  56.         {
  57.
  58.         }
  59.     }
  60. }
Code - C#: [Select]
  1. using System;
  10.
  11. [assembly: CommandClass(typeof(project2.Class3))]
  12.
  13. namespace project2
  14. {
  15.     public class Class3
  16.     {
  17.         [CommandMethod("SecondProjectClass1")]
  18.         public void test3()
  19.         {
  20.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  21.             ed.WriteMessage("\nWe've reached the second project's first class");
  22.         }
  23.     }
  24. }
  25.
Tried just adding a command class attribute to the first project referencing the class in the second but got an error  :-(
Post by: BlackBox on March 21, 2013, 01:57:38 PM
It was about ten months ago since I worked with this firm on a part-time basis, but one of the first things I recall was that they had an issue similar to Jeff's where all CommandMethod definitions ended up being located in a single class (of +/-30 different classes for this particular project)... I could have sworn that the CommandClass attribute was used, but clearly I am mistaken given my earlier test to confirm what I am posting.
Jeff (M) has already arrived upon the answer I mistakenly thought I was offering; I just need a better memory (firstly), and to learn a great deal more to stop making these silly mistakes... Apologies for the unintentional distraction, guys.  :-(
Thanks for reminding me of the use/limitations/requirements of CommandClass attribute, as well Jeff (H). I'll have to dedicate some time to digesting the code you posted.
Cheers
Post by: Jeff_M on March 21, 2013, 03:19:33 PM
Trying something new...I added the [assembly: CommandClass()] entries for all commands, including those in the second project, into one class in the main project. At load time in Autocad I got an eDuplicateKey error. I went back and commented out the 3 lines that point to those in the second project, then it loaded without error. But then, of course, those commands didn't work. So I added just those 3 lines into the AssemblyInfo for the second project, everything still loads fine, but those commands in the second project still no worky. It looks like I need to keep all of the CommandMethods in the main project and just call the methods in the second project. Not ideal, and it's only 7 commands, but it makes me wonder what others do in a Solution with many others working in different projects. It looked like the link JeffH gave might go into that, but I think it fell short of describing what to do...or maybe I missed it.
Post by: Jeff_M on March 21, 2013, 03:58:25 PM
So, I think that what is happening is Autocad only checks for Command s when the DLL is actually loaded into Autocad. So even the the DLL is referenced by the first project, and all of the public methods & properties are available to the first project, Autocad doesn't automatically load the same dll in order to look for those commands. Which means that I should be able to just add a line to load  the second dll, which won't hurt anything (you can load manually load the same dll into Autocad with no repercussions that I know of), this allowing Autocad to 'see' those commands. Or, just do what I did originally and place the commands in the main project and forget about it.
Will, instead of SendCommand I would use something like this code since both project's dll's will be in the same location:
string dllName = "Secondproject.dll";
string dllPath = System.IO.Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location) + dllName;
System.Reflection.Assembly.LoadFrom(dllPath);
Post by: WILL HATCH on March 21, 2013, 04:12:31 PM
Not sure if that would work for us in this case because we would need the CommandMethods to be registered inside AutoCAD.  If you try it let me know the result please
Post by: Jeff_M on March 21, 2013, 04:22:49 PM
Actually I determined that I couldn't use either method to load the dll, as this dll is actually linked into the main DLL before it gets released for customers. So there is just the one DLL that physically can be loaded. This forced me to go with the 'all commands in one project' approach.
Btw, I think that the loading via Reflection would work if I did have the 2 dll's exposed. We use this method to load the main dll after verifying that the Autocad Session is running as Civil3D, which then allows all of the commands to be seen by Autocad.
Post by: TheMaster on March 21, 2013, 11:16:22 PM
Assemblies with CommandMethods or LispFunctions must be registered for demand-loading in the registry (or via Autodesks' auto-loader).
Referencing an assembly with CommandMethods or LispFunctions from another assembly that is registered for demand-loading, will not cause those commands or LISP functions in the referenced assembly to be defined or demand-loaded, because the referenced assembly will not be loaded until a method from the referencing assembly that references a type in the referenced assembly executes for the first time.
The bottom line is that any assembly that contains CommandMethods must be registered for demand loading if you want those commands to be recognized on first use.
Post by: BlackBox on March 22, 2013, 12:25:59 AM
The ease with which you clarify development issues, never fails to impress; thanks for continuing to share your expertise for the betterment of others, Tony.
Post by: Jeff H on September 04, 2013, 10:20:18 AM
Was testing this for another reason and remember this thread and I know this is not what you after and not a answer to your solution,
BUT taking the question literally the CommandMethods are technically in 2 different assemblies.
 ;D
Code - C#: [Select]
  1. using System;
  5. using Autodesk.AutoCAD.ApplicationServices;
  6. using Autodesk.AutoCAD.EditorInput;
  9. namespace ReferencedAssembly
  10. {
  11.     public abstract class ReferencedAssemblyCommandClass
  12.     {
  13.         [CommandMethod("Fart")]
  14.         public void Fart()
  15.         {
  16.             Application.ShowAlertDialog("Fart");
  17.         }
  18.     }
  19. }
  20.
  21.
Code - C#: [Select]
  1. using System;
  8. using ReferencedAssembly;
  9. using Autodesk.AutoCAD.Runtime;
  10. [assembly: CommandClass(typeof(DemandorNetLoadedAssembly.DemandorNetLoadedAssemblyCommandClass))]
  11. namespace DemandorNetLoadedAssembly
  12. {
  13.     public class DemandorNetLoadedAssemblyCommandClass : ReferencedAssemblyCommandClass
  14.     {
  15.         [CommandMethod("Poo")]
  16.         public void Poo()
  17.         {
  18.             Application.ShowAlertDialog("Poo");
  19.         }
  20.     }
  21. }
  22.
  23.
Post by: WILL HATCH on September 04, 2013, 02:53:08 PM
 :lmao:
Post by: MickD on September 05, 2013, 06:58:18 PM
Just as an aside, I have been doing a lot of work with reflection of late and as Tony mentioned, AutoCAD doesn't know about the other dll until it's loaded.
What's happening is it won't be loaded because of JIT compilation, with my reflection work all I did was create an instance of a class from the referenced assembly which demand loaded the dll, from there I was set to 'reflect' all I wanted.
I also noticed this with the same command situation with commands in another dll, I have a main dialog that loads a form from another dll via a menu, this dialog can also be called by it's own command method if needed. If I called the command only before using the menu the form wouldn't show, once I used the menu the command was loaded and available for use from then on.
So, one solution is to load the dll manually from the main dll or as a quick hack have an empty 'load' class in the referenced dll and create an instance of it at start up to load it. It will be created and disposed of quickly but the dll's will be loaded and all commands should be registered.
Post by: Jeff H on September 16, 2013, 11:55:10 AM
Thanks MickD,
Did this change when they added the AutoLoader Functionality?
Looking with reflector it is done through events AssemblyLoad and AssemblyResolve events.
I thought in the past it was not done through event handling and just whatever assembly where in registry or loaded via Netload.
Anyways I kinda like that and just done a little testing, but created a Addin-Loader that gets information to check certain folders if the files are newer than the ones in current and if so copy them over and then do a Assembly.LoadFrom.
Makes easier to keep people in office up to date without having to do a reinstall will have latest version on startup, and for testing just rebuild close AutoCAD and start it back up.
Post by: MickD on September 16, 2013, 06:51:50 PM
Thanks MickD,
Not sure Jeff, I think that while an auto loader may load 'referenced' assemblies, the function being called is what triggers the auto load.
With commands, AutoCAD knows nothing about your commands until you load your assembly, that is it doesn't even know it has to resolve a reference as the callback (calling function) for the command doesn't even exist in the running process yet (it's not loaded or compiled into it).
I did see something on the board here from Dan that mentioned implementing a method that will be found to autoload .net dll's(?).
If this is the case it may be that when a command is called and the command is not registered it calls a default method which searches unloaded assemblies in the support path and if you have declared the function it will load the assembly, just thinking out load here though.
Either way you need to have a bit of code in the main process to call to make the process look for the method and resolve the reference, for plug ins in AutoCAD this is done using Netload and CommandMethod attributes to load the callbacks into the main process.
Basically what TonyT said a few posts ago :)
Post by: Jeff H on September 16, 2013, 07:46:59 PM
Thanks MickD,
I understand that I just thought in the past the only assemblies AutoCAD parsed were ones passed via NETLOAD or were stored in the registry.
So no matter what implementation used that required a referenced assembly to be loaded AutoCAD did not search those assemblies. I do not have earlier version installed to see a difference.
