Code Red => VB(A) => Topic started by: ML on March 09, 2005, 02:38:44 PM
Title: LISP AND VBA
Post by: ML on March 09, 2005, 02:38:44 PM
Does anyone know if there is a way to call up and use a lisp routine from within THe VBA Editor?
I wanted to use this layer merge (laymrg) lisp routine from Express Tools  along with my VBA Macro but I don't really want to send a number of commands to the AutoCAD command Line from within THe VBA Module.
This is the only way that I know of to use a LISP routine from within VBA
Any help is appreciated
Title: LISP AND VBA
Post by: David Hall on March 10, 2005, 08:40:29 AM
What about a VBA Layer Merge dvb file?
Title: LISP AND VBA
Post by: ML on March 10, 2005, 09:00:49 AM
That would be great!
Do you have such a project?
Title: LISP AND VBA
Post by: David Hall on March 10, 2005, 09:34:30 AM
Try this (http://www.theswamp.org/lilly_pond/cmdrduh/MergeLayers.dvb?nossi=1) link
Title: LISP AND VBA
Post by: David Hall on March 10, 2005, 09:35:35 AM
It needs some work on the form design, but the functionallity is there.  The cancel button should be renamed to Exit or Quit
Title: LISP AND VBA
Post by: ML on March 10, 2005, 09:39:41 AM
My proxy here at work won't seem to let me get to it.
Anyway you could post the code?
Thanks again
Title: LISP AND VBA
Post by: ML on March 10, 2005, 09:40:02 AM
I'm not real concerned about the form
Title: LISP AND VBA
Post by: David Hall on March 10, 2005, 10:13:48 AM
Form Code
Private Sub CancelButton_Click()
End
'ends program
Private Sub MergeButton_Click()
Dim BlkCol As Object
Dim BlkObj As Object
Dim Obj As Object
Dim Lay As Object
Dim AttObj As Variant
Dim item As Object
Dim FromLay As String
Dim ToLay As String
Dim reLay As Object
Dim I As Integer
Dim intCount As Integer
FromLay = FromLayerList.Text
ToLay = ToLayerList.Text
Set Lay = ThisDrawing.Layers(FromLay)
Set BlkCol = ThisDrawing.Blocks
For Each BlkObj In BlkCol
    If BlkObj.IsLayout = True Then
        For Each Obj In BlkObj
            If Obj.ObjectName = "AcDbBlockReference" Then
                If Obj.HasAttributes = True Then
                    AttObj = Obj.GetAttributes
                    For I = LBound(AttObj) To UBound(AttObj)
                        If AttObj(I).Layer = FromLay Then
                            AttObj(I).Layer = ToLay
                        End If
                    Next
                    AttObj = Obj.GetConstantAttributes
                        End If
                    Next
                End If
            End If
            If Obj.Layer = FromLay Then
                Obj.Layer = ToLay
            End If
        Next
    Else
        For Each item In BlkObj
            If item.Layer = FromLay Then
                item.Layer = ToLay
            End If
        Next
    End If
Next
If FromLay <> ToLay Then
    If FromLay <> "0" Then
        Lay.Delete
    End If
End If
intCount = FromLayerList.ListCount - 1
For I = intCount To 0 Step -1
If FromLayerList.Selected(I) = True Then
FromLayerList.RemoveItem I
End If
Next
'ThisDrawing.Regen
Private Sub UserForm_Initialize()
Dim Lay As Object
For Each Lay In ThisDrawing.Layers
    FromLayerList.AddItem Lay.Name
    ToLayerList.AddItem Lay.Name
Next
Module code
Sub MergeLayers()
Dialog1.Show
Title: LISP AND VBA
Post by: Amsterdammed on June 03, 2005, 09:13:43 AM
I just tried the VBA Layer Merge dvb, it's great.
But i would like to join the question: is there a way to start a lisp out of VBA?
Bernd
Title: LISP AND VBA
Post by: David Hall on June 03, 2005, 09:35:18 AM
Do you mean Have a vba routine start a lisp routine?
Title: LISP AND VBA
Post by: Amsterdammed on June 03, 2005, 10:59:48 AM
Yes, exactly.
to be honest, i need to start some lisp at the "BeginQuit" event and have no clue yet how to do
Title: LISP AND VBA
Post by: David Hall on June 03, 2005, 11:06:11 AM
I am not a LISP guru, but I think it can be done.  I think you might have to use SendCommand though, which is frowned upon, but sometimes necessary.
Title: LISP AND VBA
Post by: David Hall on June 03, 2005, 11:08:10 AM
my thought would be something like
sendcommand "(lispcmd)"
You would probably need to make the LISP non-command version (i hope that makes sense)
Title: LISP AND VBA
Post by: Amsterdammed on June 03, 2005, 12:37:01 PM
:) Thanks,
it might be not the most sophisticated solution, but it works. Commands in the lisp do not bother at all.
Do you know anything about how to trigger de event handler for leaving Acad?
Bernd
Title: LISP AND VBA
Post by: ML on June 04, 2005, 12:51:17 AM
Hey CMD, I was able to load The Layer Merge dvb file, it is real nice. Thank you
As far as The calling up a LISP routine from VBA, the solution you guys found is exactly how I started the post :)
I was trying not to use The Send Command over and over
Title: LISP AND VBA
Post by: ML on June 04, 2005, 12:53:19 AM
Amster,
What did you need to know exactly?
You can access that event at drawiing level (Thisdrawing)
Title: LISP AND VBA
Post by: Amsterdammed on June 15, 2005, 09:23:14 AM
Thanks Mark,
The BeginQuit event was what i needed.
