Code Red => .NET => Topic started by: Keith Brown on October 31, 2012, 05:13:23 PM
Title: The Master's Example Classes
Post by: Keith Brown on October 31, 2012, 05:13:23 PM
I see some links on this forum and on the official forum to some classes that Tony created and shared with the community.  Unfortunately those links all point to his website which is no longer available.  Are those classes still available for public download?  I would really love to use them as a learning experience of the power of dotnet and the Autocad API.  Thanks.
Title: Re: The Master's Example Classes
Post by: Jeff H on October 31, 2012, 05:28:05 PM
There are links to a couple of them here
http://www.theswamp.org/index.php?topic=39109.msg444119 (http://www.theswamp.org/index.php?topic=39109.msg444119)
Post by: TheMaster on November 01, 2012, 05:16:28 AM
Let me know what links you're referring to and I'll see what I can do
Post by: Keith Brown on November 01, 2012, 10:53:05 AM
Hi Tony,
I was mainly thinking of your commandline class and your overrule example.  Your localsystemvariables class is available on this forum.  That one has already been a great help just in thinking about the bigger picture and making sure that you can see the forest even when you are standing among the trees.  Thanks again.
Post by: TheMaster on November 01, 2012, 11:40:33 AM
Hi Tony,
CommandLine.cs was written before Autodesk added the RunCommand method to the Editor class (it's a non-public method, so you have to use reflection to call it, which is quite simple to do).  I'll try to get the original Overrule sample code posted, if I can find it.
This can be used in lieu of CommandLine.cs:
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using System.Text;
  5. using System.Reflection;
  6. using Autodesk.AutoCAD.Runtime;
  7. using Autodesk.AutoCAD.EditorInput;
  8. using Autodesk.AutoCAD.ApplicationServices;
  9.
  10. namespace Autodesk.AutoCAD.EditorInput
  11. {
  12.    public static class MyEditorExtensions
  13.    {
  14.       static MethodInfo runCommand = typeof( Editor ).GetMethod(
  15.          "RunCommand", BindingFlags.Instance | BindingFlags.NonPublic | BindingFlags.Public );
  16.
  17.       public static PromptStatus Command( this Editor ed, params object[] args )
  18.       {
  19.          if( Application.DocumentManager.IsApplicationContext )
  20.             throw new InvalidOperationException( "Invalid execution context for Command()" );
  21.          if( ed.Document != Application.DocumentManager.MdiActiveDocument )
  22.             throw new InvalidOperationException( "Document is not active" );
  23.          return (PromptStatus) runCommand.Invoke( ed, new object[] { args } );
  24.       }
  25.    }
  26. }
  27.
  28.
Post by: Keith Brown on November 02, 2012, 08:31:04 AM
Thanks for sharing Tony.
Post by: Andrey Bushman on December 26, 2012, 10:07:02 AM
Code - C#: [Select]
  1. static MethodInfo runCommand = typeof( Editor ).GetMethod(
  2.          "RunCommand", BindingFlags.Instance | BindingFlags.NonPublic | BindingFlags.Public );
  3.
Why is the "RunCommand" not public?
Post by: Andrey Bushman on December 26, 2012, 11:31:58 AM
I have wrote a simple code:
Code - C#: [Select]
  1. public class TestClass {
  2.     [CommandMethod("test")]
  3.     public void Test() {
  4.         Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  5.         ed.Command("Filedia", 0);
  6.         ed.Command("(princ \"Hello from the Command [1]\")");
  7.         ed.Command("_line", "0,0", "100,100", "");
  8.         ed.Document.SendStringToExecute("(princ \"Hello from the SendStringToExecute [2]\") (princ) ",
  9.             true, false, true);
  10.         ed.Command("Filedia", 1);
  11.         ed.Command("(princ \"Hello from the Command [3]\")");
  12.         // some operations
  13.         ed.WriteMessage("Hello from the WriteMessage [4]");
  14.         ed.Document.SendStringToExecute("(princ \"Hello from the SendStringToExecute [5]\") (princ) ",
  15.             true, false, true);
  16.     }
  17. }
  18.
Result:
Command: netload
Command: test
Filedia
Enter new value for FILEDIA <1>: 0
Command: (princ "Hello from the Command [1]") LISP command is not available.
Command: _line Specify first point: 0,0
Specify next point or [Undo]: 100,100
Command: Filedia
Enter new value for FILEDIA <0>: 1
Command: (princ "Hello from the Command [3]") LISP command is not available.
Command: Hello from the WriteMessage [4]
Command: (princ "Hello from the SendStringToExecute [2]") Hello from the
SendStringToExecute [2]"Hello from the SendStringToExecute [2]"
Command: (princ)
Command: (princ "Hello from the SendStringToExecute [5]") Hello from the
SendStringToExecute [5]"Hello from the SendStringToExecute [5]"
Command: (princ)
I have a little problem: ain't working LISP functions through the Command method. How can I solve it (if I can...)?
Post by: TheMaster on December 27, 2012, 03:24:59 AM
The Command() method doesn't execute LISP.
There are several ways to execute LISP functions from .NET.
You can P/Invoke acedInvoke() (there's a sample I wrote floating around)
You can P/Invoke acedEvaluateLisp()
You can use VL.Application.
Forget about using SendStringToExecute().
Post by: Andrey Bushman on December 27, 2012, 03:39:33 AM
Thank you.
Post by: MexicanCustard on December 27, 2012, 01:36:01 PM
This was taken from Tony's example
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
private static extern int acedInvoke(IntPtr args, out IntPtr result);
public ResultBuffer InvokeLisp(ResultBuffer args, ref int stat)
            IntPtr rb = IntPtr.Zero;
            stat = acedInvoke(args.UnmanagedObject, out rb);
            if (stat == (int)PromptStatus.OK && rb != IntPtr.Zero)
                return (ResultBuffer)DisposableWrapper.Create(typeof(ResultBuffer), rb, true);
            return null;
private void PrintResbuff(ResultBuffer res)
            string s = "\n--------------------";
            foreach (TypedValue val in res)
                s += string.Format("\n{0}->{1}", val.TypeCode, val.Value.ToString());
            s += "\n---------------------";
            Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(s);
Call it like this
var args = new ResultBuffer();
int stat = 0;
args.Add(new TypedValue((int)LispDataType.Text, "Lisp_Function"));
args.Add(new TypedValue((int)LispDataType.ObjectId, myObject.ObjectId)); //// My fake LISP routine needs an ObjectId and A Point3d
args.Add(new TypedValue((int)LispDataType.Point3d, new Point3d(0, 0, 0)));
ResultBuffer res = InvokeLisp(args, ref stat);
if (stat == 5100 && res != null)
       PrintResbuff(res);
res.Dispose();
Post by: Andrey Bushman on December 27, 2012, 01:39:15 PM
Yes, I already found this decision. Thanks. Not to forget, I added it here (https://sites.google.com/site/acadhowtodo/net/command-line).
Post by: gile on December 27, 2012, 03:52:40 PM
No more need to P/Invoke acedInvoke() since A2011 as the Application.Invoke() managed method wraps it.
Post by: Andrey Bushman on December 28, 2012, 12:54:11 AM
Thank you
Post by: TheMaster on December 29, 2012, 09:52:50 PM
Thanks Gile, I forgot about that one.
It may also be worth noting that with acedInvoke(), the LISP function that is called must be previously-registered using the (vl-acad-defun) function or must have a C: prefix.
