CAD Forums => CAD General => Topic started by: AfricaAD on February 01, 2005, 09:36:51 PM
Title: unable to pick endpoints
Post by: AfricaAD on February 01, 2005, 09:36:51 PM
I have a lisp routine that creates wide flange struct steel shapes. It generates these shapes in pline format. For some odd reason now, I am unable to pick endpoints on one end of the object. Once I flatten the object, all is well. I am not sure why or if there is a fix for this.
Could it be a lisp conflicting with this?
Thanks!
Post by: Zydenet on February 02, 2005, 08:51:40 AM
Can you post an example?
Post by: AfricaAD on February 02, 2005, 12:32:35 PM
After the I run the routine, this is what happens.
(http://www.theswamp.org/screens/AfricaAD/no-endpt.gif)
Post by: Zydenet on February 02, 2005, 12:39:53 PM
What does it show if your LIST it.
Post by: AfricaAD on February 02, 2005, 12:46:52 PM
                 POLYLINE  Layer: "0"
                            Space: Model space
                   Handle = 65
            Closed
    starting width    0.0000
      ending width    0.0000
              area    2.6778
         perimeter   26.7908
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 66
                at point, X=   3.1582  Y=  -0.8225  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 67
                at point, X=   4.7932  Y=  -0.8225  Z=   0.0000
Press ENTER to continue:
      ending width    0.0000
             bulge    0.4142
            center X=   4.7932  Y=  -0.5725  Z=   0.0000
            radius    0.2500
       start angle    270
         end angle      0
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 68
                at point, X=   5.0432  Y=  -0.5725  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 69
                at point, X=   5.0432  Y=   4.3975  Z=   0.0000
      ending width    0.0000
             bulge    0.4142
            center X=   4.7932  Y=   4.3975  Z=   0.0000
            radius    0.2500
       start angle      0
         end angle     90
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 6A
                at point, X=   4.7932  Y=   4.6475  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 6B
                at point, X=   3.1582  Y=   4.6475  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 6C
                at point, X=   3.1582  Y=   4.8625  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 6D
                at point, X=   7.0982  Y=   4.8625  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 6E
                at point, X=   7.0982  Y=   4.6475  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 6F
                at point, X=   5.4632  Y=   4.6475  Z=   0.0000
      ending width    0.0000
             bulge    0.4142
            center X=   5.4632  Y=   4.3975  Z=   0.0000
            radius    0.2500
       start angle     90
         end angle    180
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 70
                at point, X=   5.2132  Y=   4.3975  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 71
                at point, X=   5.2132  Y=  -0.5725  Z=   0.0000
      ending width    0.0000
             bulge    0.4142
            center X=   5.4632  Y=  -0.5725  Z=   0.0000
            radius    0.2500
       start angle    180
         end angle    270
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 72
                at point, X=   5.4632  Y=  -0.8225  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 74
                at point, X=   7.0982  Y=  -0.8225  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 75
                at point, X=   7.0982  Y=  -1.0375  Z=   0.0000
      ending width    0.0000
                  VERTEX    Layer: "0"
                            Space: Model space
                   Handle = 76
                at point, X=   3.1582  Y=  -1.0375  Z=   0.0000
      ending width    0.0000
                  END SEQUENCE  Layer: "0"
                            Space: Model space
                   Handle = 78
Post by: AfricaAD on February 02, 2005, 12:51:21 PM
Only the snaps will not work if snapped to it. Grips will work though.
Post by: CADaver on February 02, 2005, 12:56:13 PM
hmmm... where's you say you got this routine??? :wink:
Same thing happened to an old routine of mine, it was originally written for R9, and used the old polyline type.  Somewhere just before the PLINE command is entered add a line something like this:
(setvar "plinetype" 1)
Post by: AfricaAD on February 02, 2005, 01:26:52 PM
I use the stl.lsp from Al rogers. Would setting it to 2 be better?
Thanks!
Post by: Zydenet on February 02, 2005, 03:16:57 PM
Very nice program. Just downloaded and installed it. Check your verison. You may have an older version. It worked fine here. My plinetype is set to 1. You may be able to use this CADaver.
March 2002 tip 1779
http://new.cadalyst.com/code/browseyear.cfm?fullyear=2002
Post by: AfricaAD on February 02, 2005, 04:56:59 PM
I downloaded it from there as well. I may have had another lisp that may have changed the plinetype to 0. It worked fine until last week. I just added the variable setting to the lisp in case it happens again.
Post by: CADaver on February 02, 2005, 06:02:55 PM
Oh I have a pretty extensive steel program.  The reason why I asked, is mine did the very same thing when we moved to R14 from R13, and I was just curious.
Post by: AfricaAD on February 02, 2005, 08:41:56 PM
Which steel prog you got? Is it one of those you have to purchase?
Post by: CADaver on February 03, 2005, 07:03:43 AM
Quote from: AfricaAD
Wrote it for R9, been patchin' it with baling wire and chewing gum ever since.  Someday, when I get the time, I'm gonna re-write it from the ground up.
Post by: t-bear on February 03, 2005, 08:26:09 AM
I don't have a "program" for steel, but I do have an extensive library of 3D steel shapes.  Saved as regions, you drop 'em in and extrude to length or along a path.  Elbows, tees, flanges  etc are saved as blocks. It works purty good too. Kinda like playin' with leggos or sumpin'....
Post by: CADaver on February 03, 2005, 09:08:33 AM
Quote from: t-bear
Mine creates the block 2D or 3D.  For 3D it asks for beam length or column height and adjusts the X-scale or Z-scale accordingly.
Post by: t-bear on February 03, 2005, 10:56:16 AM
Is it quicker/easier than the library?  Can you pick start/end if the dist is unknown? How about along a path (great for tubing)?
Post by: CADaver on February 03, 2005, 12:01:26 PM
Quote from: t-bear
I think so.
Quote from: t-bear
Sure, uses (getdist)
Quote from: t-bear
Well it's a steel program so no it won't extrude along a path.
I've found that blocks are considerably lighter memory-wise than 3dsolids or regions, and less susceptible to errant corners than surfaces. We also have tools in place for changing the length of the shapes, or switching them out for a different shape.
Post by: t-bear on February 03, 2005, 12:48:48 PM
The only thing I use surfaces for is eccentric reducers ... I still can't get those reducers to open!! Arrrrggggggghhhhhh!!!!
Oh well, I've lived without them for all this time.....
Post by: AfricaAD on February 03, 2005, 07:12:12 PM
I have another one I sometimes use as well. It only creates the shapes & more simple to use, but has some errors. What I would like to do is convert the shapes into blocks after it is drawn using the entmake program. Unfortunately, I am no coder.  :cry:
Post by: CADaver on February 03, 2005, 07:45:05 PM
Neither am I.  I used the dreaded
(command...Built the shape with PLINE, then EXTRUDEd it, then BLOCKed it.
