Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Spike Wilbury on December 29, 2008, 08:44:31 PM
Title: What's the maximum number of vertex for a Polyline?
Post by: Spike Wilbury on December 29, 2008, 08:44:31 PM
First time, I see this....
I know I did a kind of extreme test by drawing a lightweight polyline using 100,000 vertex's, the polyline is drawn, but if I tried to do a zoom extents, AutoCAD just freezes... and even the PC.... not even with ctrl+alt+del ...
Any ideas?
Thanks,
Luis.
Title: Re: What's the maximum number of vertex for a Polyline?
Post by: Andrea on December 29, 2008, 08:53:08 PM
is your vertex close anough to maybe SPLINE ?
Post by: Kerry on December 29, 2008, 08:55:39 PM
Andrea, Luis wants a polyline, not a Spline ..
Luis, must admit I've never built a polyline that big :)
Post by: Andrea on December 29, 2008, 09:01:51 PM
I mean....did you try to see if there is any difference to convert your Pline to a Spline before zooming ?
Post by: Spike Wilbury on December 29, 2008, 09:03:22 PM
Thank you Kerry.
But, I needed to run an extreme test (since the command will be used for a Civil and Topo jobs), maybe is not frozen, but it takes forever, that's why I have to turn off my PC.
Post by: Spike Wilbury on December 29, 2008, 09:06:51 PM
Thank you Andrea,
The command it is an ObjectARX and has the options to connect points (using LwPolyline or 3Dpolyline), that the user reads from a file, using different formats....
Post by: Spike Wilbury on December 29, 2008, 09:16:54 PM
I see also, that it is a problem with the AutoCAD object highlight feature - maybe that's the problem too.....  :ugly:
Post by: Spike Wilbury on December 29, 2008, 09:27:24 PM
Well.... I found the problem
It is the SELECTIONPREVIEW feature and also it is  needed to turn off the HIGHLIGHT variable too.... That way I can do/get the zoom extent that I have as part of my command.
so...
False, alarm then with the number of vertices.... :)
Post by: Spike Wilbury on December 29, 2008, 10:04:16 PM
Now, is this variable available from AutoCAD 2006, no ?
Post by: Kerry on December 29, 2008, 10:09:14 PM
yes, SELECTIONPREVIEW was  NEW in AutoCAD 2006
Post by: Spike Wilbury on December 29, 2008, 10:17:56 PM
Thanks! - problem solved !
